RV.Net Open Roads Forum: Tech Issues: WATER FILTER
 > WATER FILTER
Tech Issues Related Tips
I am still wayne_tw
everywhere
Posted: 11/14/09 08:04am Link  |  Quote  |  Print  |  Notify Moderator
SKIPPERS_1 wrote:
What does the water filter do ??
It filters the water! Depending what type of filter is installed, it will remove different impurities from the water.
mikestock
Vestavia Hills, AL, USA
Posted: 11/14/09 08:15am Link  |  Quote  |  Print  |  Notify Moderator
steelpony5555 wrote:
white, green, black they all taste like a hose!
Absolutely correct. I must have bought 20 or more white hoses in the past 30 years and they all have some taste.
I have found it makes more sense to just filter the water that I plan to drink. I use a PUR filter on the faucet. The shower, toilet, dishwashing and washing machine water is unfiltered.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Honda EU2000i, Porta Bote with 6HP Nissan and sail kit, S&W security system
wolfe10
Posted: 11/14/09 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Until we hear back from the OP, we really don't know what filter he is talking about.
From his signature, he will have a water filter on his engine and POSSIBLY one on his potable water system.
Sure don't want to mix the two!
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Golden_HVAC
Fulltime, CA, USA
Posted: 11/14/09 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Wolfe,
Maybe the original post was about a water filter for the engine.
That filter helps remove sediment and minerals from the radiator water. It also helps keep abrasive materials out of the water, so the seals might last a lot longer. I put a Napa #4070 water filter on my motorhome when it was new, and a year later it was plugged with what looked like sand. So I keep installing a new coolant filter each year.
Even though I have a gas engine, I use the same water coolant filter that is a requirement on 2 stroke diesel engines to prevent cavitation in the engine cylinder walls.
Good Luck,
Fred.
wolfe10
Posted: 11/14/09 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Golden_HVAC wrote:
Hi Wolfe,
Fred.
YUP, and there is a lot more to choosing the correct coolant filter than just replacing with the current part number, as they come with different "units" of SCA, which are CRITIAL to his linered diesel engine.
Just because a 4 unit filter was the correct filter last time does NOT mean it is the correct one to fit THIS TIME.
IF that is the water filer he is talking about, we can go into detail.
He must be out enjoying his coach.
SKIPPERS_1
INDIANA
Posted: 11/14/09 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Fred answered my question, the filter I WAS ASKING ABOUT IS THE ONE ONE THE ENGINE.
I switched to a heavy duty coolant that doesnt require adding or testing the sca.
I was wondering what the filter , filtered ,do to the use of no silicate and distilled water.
Now I use a blank with no additive in it.
Thanks, Rich
PS Sorry I wasnt clear on mu original post.
1999 DUTCHSTAR DP
38`
8.3 ISC CUMMINS
SPARTAN CHASSIS
1994 TRACKER 4X4 TOAD
BLUE OX TOW BAR
ol Bombero-JC
Posted: 11/14/09 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
So, I guess you don't want to drink from that ONE ONE, huh huh!
Not a bad conclusion in only 2 pages.
Inspector Clouseau would be proud.
wolfe10
Posted: 11/14/09 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, if you are using an OAT based long life coolant, you use a ZERO unit SCA water filter. And change it every two-three years.
 > WATER FILTER
