09FLSTC
Out West
$250? Wow, I was expecting $100. I need a lift or a skinny contortionist next time. Whew!
wolfe10
The chassis maker specs the filter, not the engine maker. The engine maker just gives them the CFM requirements.
How much was the part? Labor?
What chassis do you have and what filter part number-- perhaps others with the same filter can tell you if this is reasonable.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Deen
Vancouver, WA
I paid less than $80 for my filter and installed it myself. That way I make $150/hr!
The Texan
Summer: Cascade, Idaho - Winter: A Warm Climate
Speedco installed my air filter for $59.99 plus tax, the cost of the filter, no additional labor. I am very satisfied with Speedco for routine annual service, at a very reasonable rate.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03 & FT Class of 2002
'05 HR Endeavor 40PRQ, 400 Cummins -With-'05 GMC Sierra SLT, CC, Z-71, the pusher & our '07 Arctic Cat 500A & '08 Suzuki KQ 400A, riding in the pusher.
Where the wheels are stopped
Economical Handyman
S. California
Good Sam RV Club
Our friend with a 03' Pheaton just paid $93. for his filter, no labor.
DeWayne & Judy
04 3810 Dutch Star
ISL 370 9.3 mpg
Frank's autoformer
01 Sahara Jeep-toad
Blue Ox Aventa II
F 374382
This is not the "GOLDEN-YEARS", it is the "RUSTY-YEARS" !
wagonmaster2
northcentral oklahoma
I have a Meridian 2004 C-7 on the Freightliner chassis and those air filters are a terror to replace. The only thing that competes with this job is the air system filter replacement, also a wrestle underneath the back end of the coach. If I remember right the engine air filter was around $85 and my auto front end alignment and brake shop helped me install the filter charging me $35 for his part. Both of us spent 30-45 minutes under the back end together wrestling that thing down and back up. Sure glad this is just a 3-4 year project.
Wagonmaster2
orgelmo
Full timing since Mar 2004
Good Sam RV Club
You can see from my signature what I have.
The 1st time, I had a cat service do mine. After I saw how it was done I started doing mine. The first time I did it, it took awhile, not I am pretty good at it. Inside the rear compartment is a door. remove the screws and you now see the filter, unbolt it you have about 1 inch of play. It took longer the first time, now I am rather good.
Cat was something like $200.00, my cost was like $70.00 for the filter and a small amount of time. If you aren't signed up for tiffinrv.net, you should be. Alot of good information there.
Elmer & Sharon
USN-(62-66)
05-40 QDH Tiffin Phaeton
05 Explorer Sport Trac
FMCA # 124188
Good Sam Life Member
Hacksaw, Congo Gray Parrot
Aries, Himalayan Pussy Cat
M Herky
Northern Illinios
I have a 2004 Fleetwood with a CAT C7 on a Freightliner. We have a trucking company, so I have good access to discounted parts. I shopped around and found the cheapest to be $280 and I installed it myself. It is all moulded plastic with the filter inside. I'm going to wait for the indicator to get to the red before replacing next time.
2005 Fleetwood Expedition
Towing 2008 Honda CRV
wolfe10
M Herky wrote: I'm going to wait for the indicator to get to the red before replacing next time.
EXCEPT, that the filter elements are made of paper and degrade with time.
Three years is about the max before the glue/paper begin to break down.
Yes, yours sounds like an expensive filter, but LOTS CHEAPER than having a broken pleat in the filter cause the engine to ingest a lot of dirt and fail.
wny_pat
Western NYS
wolfe10 wrote: M Herky wrote: I'm going to wait for the indicator to get to the red before replacing next time.
Yes, yours sounds like an expensive filter, but LOTS CHEAPER than having a broken pleat in the filter cause the engine to ingest a lot of dirt and fail. But if he keeps a close eye on that filter-minder, it will tell him that to. Far to many change air filters way before necessary.
And I've seen brand new expensive filters with broken pleats. That made me a believer in the filter-minders. Can tell if they are leaking and can tell if their plugged.
