RV.Net Open Roads Forum: Pic of my 08 Freightliner Chassis: do U know what's this?
 > Pic of my 08 Freightliner Chassis: do U know what's this?
univmd
Maryland
Good Sam RV Club
Posted: 11/15/09 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 Gulfstream Tourmaster on a Freightliner chassis. I looked behind the front bumper today out of curiousity and found a linkage arm with two rubber joints that seem crooked. Do U know what this is, and is this crookedness normal? The coach seems to drive fine. With warm regards, James
(The wheels are pointing straight now but I did a lot of turning right before straightening it out after parking. This linkage is only on the driver's side of my yellow generator.)
* This post was edited 11/15/09 11:19pm by an administrator/moderator *
2008 Gulfstream Tourmaster T40C
jocat54
Leakey, Texas
Good Sam RV Club
Posted: 11/15/09 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
It's hard to tell from the picture but it appears to be some sort of idler linkage for your steering. The crookedness is normal for the type of joint it is.
John
John & Kathy & Gizmo (maltipoo)
1999 38ft Monaco Diplomat DP
Leakey, Tx (Texas Hill Country)
wolfe10
Posted: 11/15/09 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like the drag link. No problem being cocked. You can use pliers to temporarily straighten it if you like.
DO have someone turn the steering wheel back and forth (engine off) while you look and make sure there is no play in the BELL CRANK (top of the vertical arm the back of the drag link is attached to.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
FXSTOHIO
Ohio
Good Sam RV Club
Posted: 11/15/09 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Its fine you can move it with your hand to temporarily straighten it. I have never seen one that would stay straight. It moves every time you turn your wheels
2008 Pilgrim Lite 21LRB
2004 Chevy Silverado Extended Cab 4x4 5.3 Tow Pkg 3.73
Yamaha EF2400IS
marvmarcy
Polson, MT, USA
Good Sam RV Club
Posted: 11/15/09 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
I agree that it looks like the steering drag link. It also looks to have zerk fittings on it, and that is great because you can lube it. Some drag links are "lifetime" (no zerks) and can come apart at the worst time, leaving you with no steering - dangerous at 60mph in heavy traffic. I recently replace the one on my truck.
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK (20K GVWR, tandem duals)
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
Deen
Vancouver, WA
Good Sam RV Club
Posted: 11/15/09 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Marv
And from the looks of it it needs lubing pretty soon.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor and Recruiter
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
52nd yr of RV'ing
mdanielson55
frankston texas
Posted: 11/15/09 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
look like the pitman arm pointing straight down with some steering arm horizontal the pitman should be hooked up to the steering box above it. should be ok to keep driving just grease the zerts when needed
texasbaskets
Frisco, TX
Good Sam RV Club
Posted: 11/16/09 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Look on page 12 although the whole thing might be a good read for you.
Knowing your Freightliner Chassis.
Michael, Kay, and Prissy (The vicious Malti-Poo)
'05 Coachmen SportsCoach SE 372DS a.k.a. "Mana's Cabana"
