RV.Net Open Roads Forum: Beginning RVing: Winterizing and batteries
 > Winterizing and batteries
mcewena
Canada
Posted: 09/19/11 12:00pm Link  |  Print  |  Notify Moderator
Hi, I can't find anything in the FAQ that covers this so:
If you live in the freezing areas (ie Canada) do you leave your house batteries in the rig over winter or bring them inside?
2oldman
Winchester WA
Posted: 09/19/11 12:07pm Link  |  Print  |  Notify Moderator
Thanks for checking the faq. This may help..
Winterize batteries Oct2009
pianotuna
Regina, SK, Canada
Posted: 09/19/11 12:13pm Link  |  Print  |  Notify Moderator
Hi,
Where I live it gets to -40. I never bring in the house batteries.
Fully charge them, disconnect the negative side and they will be fine.
Or add a modest solar system, for extra insurance.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
AlamsoaBorn
Colorado
Posted: 09/19/11 01:11pm Link  |  Print  |  Notify Moderator
Unless you get to -60F or so, a fully charged battery will not freeze. Disconnect the negative cable to keep the CO alarm and other loads from discharging the battery. If you feel better about having it inside, it doesn't hurt, but mine is heavy enough, it is more than I care to lift and carry.
Wherever I happen to park
Posted: 09/19/11 02:39pm Link  |  Print  |  Notify Moderator
Well: Yes.
I have taken a fully charged battery to -40 on more than one occasion,, The key phrase here is FULLY CHARGED, and no damage.
However if you wish, bring them in. BUT FIRST:
Take two small cans of spray paint, Testor's brand from the local hobby shop is good.. On the Positive end (most positive if six volt pairs) spray RED
Black on the Negative end
If you over spray onto the batteries.. Not a bad thing
Spray all the wires that hook to the post.
Now, when it comes next spring.. You won't be asking where this WHITE wire goes cause it will be painted the proper color.. Black wires to the black end red to the red end.
Finally: no matter where you keep them a Battery Minder Plus is a good thing.
Also if you bring them indoors I suggest some scrap plywood to set them on.. NOT because of any "leaching property of concrete" but because if there is any acid on the outside of the battery, Scrap wood is cheap, easily replaced and can be considered "Sacraficial" as opposed to very expensive flooring.
You can't take the Fisherman out of this Camper
Ontario, Canada
Posted: 09/19/11 06:24pm Link  |  Print  |  Notify Moderator
I never bring mine in. I have my Cougar connected to shore power with a timer that is on one hour per day. 8 months of storage every year and my batteries last 7-8 years before needing replacement. I have a switch on my propane detector and turn it off while in storage.
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS; 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4;(Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
Chuck&Gail
In the Colorado Mountains
Posted: 09/19/11 07:04pm Link  |  Print  |  Notify Moderator
As I recall Trojan says a fully charged battery freezes at MINUS 92 degrees F. If it gets that cold, I will not be worrying about my TT battery, which stays in place connected to a solar BatteryMINDer.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
MWTT
Sandy OR
Posted: 09/20/11 09:50pm Link  |  Print  |  Notify Moderator
The is no harm in pulling them and keeping them warmer then outside. If you have the space and strength.
As you can see you can leave them in but them require more maintance and a close eye. If you forget and the batteries get low during a cold snap there is trouble.
To me it is just easier to pull them but I tend to get forgetfull of monthly maintance on the rig.
You have to decide for yourself based on your style.
Enjoy
Motorized Whiskey Tango Tango
it's pronounced "Ore-gun"
FLY 4 FUN
Alberta
Posted: 09/20/11 10:42pm Link  |  Print  |  Notify Moderator
I pull mine, top up the fluid level if required and put them on a battery tender once a month. I could just charge them up my last trip and disconnect using the onboard switch. I want to eliminate theft by removing everything that is behind a 751 keyed lock.
Daryll
2009 Colorado 29BHS
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
Prodigy BC Reese 16K slider
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
