RV.Net Open Roads Forum: Beginning RVing: Winterizing and fabric
 > Winterizing and fabric
mcewena
Canada
Posted: 09/19/11 12:04pm Link  |  Print  |  Notify Moderator
I can't find anything that covers this in the FAQ so here goes:
Is there a need to do anything to protect the fabric and foam in the furniture from getting damp/dank over the Canadian winter? I know we sometimes will get a few freeze/thaw cycles. We could take the dinnette cushions inside but not the sofa or the overhead bed.
I've notice some of the "anti damp" crystals on sale look suspsiously like cat litter, I'm wondering if a tray of that would do as much good as anything.
Thanks,
Art.
extremis
BC
Posted: 09/19/11 01:46pm Link  |  Print  |  Notify Moderator
Actually, the drying crystals are the same as some "ice melter" that you can buy for your sidewalks in winter. If I recall its Calcium Carbonate or something like that. Definitely not Kitty Litter
I use the drying crystals. I bought it originally with a little circular tray that suspends above a circular type bowl. The tray is all vented. The crystals absorb the moisture in the air and it drops into the bowl. About 2 cups every couple months in my 19ft trailer. And it rains lots here in the winter time (Vancouver BC). I don't heat my trailer or anything in winter, its just stored.
Not sure how much this really helps but it wasn't terribly expensive, and each dish full of stuff in maybe a half cupful? It lasts a long time and I bought a big gallon jug of it.
Beverley&Ken
Tottenham,Ontario
Posted: 09/19/11 03:52pm Link  |  Print  |  Notify Moderator
We have never done anything extra for the inside, PUP, HTT and now c-class. We just make sure everything is dry before putting away. Never had any problems.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
mcewena
Canada
Posted: 09/19/11 04:20pm Link  |  Print  |  Notify Moderator
If it works in Vancouver weather it should work in Kingston, thanks
You can't take the Fisherman out of this Camper
Ontario, Canada
Posted: 09/19/11 06:02pm Link  |  Print  |  Notify Moderator
Beverley and Ken
X 2. The only thing I can add is that I always place cardboard between the window frames and day/night shades to prevent the sun from bleaching the furniture. Many years ago I had a trailer that was left exposed to the sun over the winter (my fault) and the furniture cloth and foam disintegrated where the sun dried it out while stored, particularly.. the back of the couch. Now I even put a sheet of cardboard under the bathroom skylight. It's dark in there now!!
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS; 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4;(Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
MWTT
Sandy OR
Posted: 09/20/11 09:58pm Link  |  Print  |  Notify Moderator
Damp-rid works well and is cheap.
Depending on your size of rig you may need two on either end. Check the box.
Make sure you clean out ALL food. Mice love a warm, dry, well stocked home for the winter, but don't we all.
Motorized Whiskey Tango Tango
it's pronounced "Ore-gun"
