RV.Net Open Roads Forum: Tech Issues: Duotherm to hunter 42999 wiring?
 > Duotherm to hunter 42999 wiring?
ceeyahd1
Camarillo, CA
Posted: 03/01/12 10:38am Link  |  Quote  |  Print  |  Notify Moderator
I tried the hunter to replace my duotherm and got everything to work except for my furnace, I took it to a garage and they could not get the hunter 42999b to work either, what they found was the thermostat was not sending 12V to furnace and no way this would work. Are there any non programmable thermostats I can use to replace the Duotherm with hi/low fan that would send 12V to the furnace?
Thanks
Chris Bryant
DeLand, Florida, USA
Posted: 03/01/12 10:51am Link  |  Quote  |  Print  |  Notify Moderator
What DuoTherm thermostat are you replacing? On the old standard analog, the furnace does not hook to the thermostat, it hooks to the air conditioner, and the thermostat tells the circuit board in the air conditioner to turn on the furnace.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
ceeyahd1
Camarillo, CA
Posted: 03/01/12 10:59am Link  |  Quote  |  Print  |  Notify Moderator
This is what I have, I spent hours trying to get the furnace to work then I took the trailer to garage and for $75.00 they told me that the furnace needs 12V to work:
Models 39115.601, 39115.602, 39115.616 & 39115.626
The thermostat is a 12V DC controlled system and is a
bimetal type. It has three (3) switches on the face of the
thermostat. On the left side there is a SYSTEM switch and
on the right side there are two FAN switches. The top switch
is for HI or LOW FAN and the bottom one is for ON or
AUTO. This thermostat will operate and air conditioner and
burdicda
Melbourne Florida My home
Posted: 08/13/12 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
If you only have 6 wires
Red from furnace to RH
White from furnace to W
Red from AC to RC
Yellow from AC for compressor to Y
Blue from AC for Hi Fan to G
Green from AC for Lo Fan to G
and NO OTHER WIRES AT ALL
Then where are you supposed to get the Ground
that you hook to the jumpered RC and RH in all
the Hunter Mod pictures ?????
CT_WANDERER
E. Lyme, CT
Posted: 08/13/12 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a Honeywell P/N RTH111. In my instalation I ran Black wire(fan low) to the G terminal. Blue wire(fan high) to a switch than connecting to the same terminal the the black is on. Yellow wire (compresser-cool) to the y terminal. White wire (furnace) to a single terminal screw RH. Red wire is blocked off. System is powered by the AA battery. Green wires (ground) goes to the terminal that has a jumper on RH to RC. Hope this might help you. Gary
ryanallie1
Magalia, Calif
Posted: 08/14/12 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
At least you are lucky, as you can do this Mod. We can't. As our Motorhome has a Pulse-Air_System, that controls the two A/C's in our Motorhome.
We have a 5.5 Generator, which is more than enough power to run our 13,500 BTU A/C and our 11.000 BTU A/C at the same time. But with a "Pulse-Air-System, you can only run one A/C at a time.
With the Pluse-Air-System, it lets you run the Front A/C for 10 minutes then automatically switches to the Rear A/C and runs for 7 minutes. According to the Manufactor, this is the cheapset way to run two A/C's.
So the only choices we have is to either run just the Front A/C, or the Rear A/C, or to run the "Pulse-Air-System", and have the Front and Rear A/C keep switching back and forth.
On Shore Power, we can only run the Front A/C, Period. No other Choices.
Hope you get it figured out. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
burdicda
Posted: 08/18/12 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I looked everywhere for clarification on this mod
All the tips have RW + RC jumpered with a "BLACK OR GREEN" wire ground going to them....that didn't make any sense electronically to me so I put together a schematic diagram and just installed the mod last night...it works perfectly in cool, heat, fan speeds, everything.
http://burdick.home.digital.net/ke4ozd/RVstat.jpg
RC and RW are unjumpered in mine since each could theoretically have a different power source, otherwise you could be working on one alone and the darn thing energize on you from the other units power source.
