JenniferandJosh
texas
I'm wanting to get that rounded curtain rod so that we can have more room in the shower as well as get rid of the liner that came with our Jayco 24T. I want a new shower liner as well as a shower curtain but of course I can't find one that isn't residential. How did you bypass this?
Did wives hem a shower curtain to fit? Wondering if this is the only thing I'm able to do. NEver heard of trailer sized shower curtains before.
“Our battered suitcases were piled on the sidewalk again; we had longer ways to go. But no matter, the road is life.” -Jack Kerouac
CamperWill
Massachusetts
We took a normal shower curtain and cut it to the right size.
2007 GMC Envoy 4.2L I6
2012 KZ Sportsmen S242SBH
Prodigy P3 & Reese Dual Cam
Dick_B
Palos Heights, IL USA
Do a Google search for Clearview Shower Curtain which is much heavier than the standard one and has a clear top for light. It won't get sucked in by the water flow. We cut a couple of inches off the bottom. They are 6 ft. x 6 ft.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
sandersmr
CamperWill wrote: We took a normal shower curtain and cut it to the right size.
X2
Maggie
Sportsmen Classic 16BH
2002 F150 Supercrew 4.6 L V8
301TBS
Ontario, Canada
I have the shower track with the wheeled hangers and wanted more room, so i removed the centre bracket and bowed the rail out and put the bracket in the new location. Fill the holes with white caulk. As for cheap curtain, i like the idea of cutting one short.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
goducks10
Keizer OR
x2, we also put a curved rod in also.
old guy
Oregon (pronounced Or e gun)
RV dealers who sell RV accessories have them in the catalogs and they are not the expensive. I only give advise, you do the leg work.
YnotTurbo
Waldorf Maryland
Measure and cut very carefully. Instant hem.
Navy Chief (Ret.)Still working 2012 Ram 3500 Laramie w/6.7 High Output
2011 Mobile Suites Lexington 43
http://s176.photobucket.com/user/YnotTur........l?&_suid=1366572875209011068766924960799
skipnchar
Topeka or somewhere else
How is your curtain different in size than a residential one? When we had curtains around our showers we were always able to just bunch up the curtain a little more and use standard residential versions with no problems. Just had a few extra pleats.
Good luck / Skip
edited 03/02/12 06:33pm by skipnchar *
mobeewan
Hampton, Va
I use a nylon curtain I bought at Walmart. It was 5 inches too tall. I was able to get someone to fold and sew a 2-1/2 inch pleat at the top right at the existing seam below the holes for the hooks. Makes a nice looking fasle valance at the top and the fold used up the excess length. As far as the width, I just bunch up the excess at the back of the tub when showering then spread it out evenly to dry.
