RV.Net Open Roads Forum: Beginning RVing: Size limit in campgrounds?
 > Size limit in campgrounds?
ffpm
Boonies
Posted: 04/13/12 11:51pm Link  |  Print  |  Notify Moderator
Is there a size limit for a 5th wheel toy hauler with slide outs in campgrounds in CA, OR, AZ, ID, NV? I heard it was 33 feet at some places, and that some places wont allow slide outs?
Is there any truth to that? I am sure it just depends on the campground, and will call ahead before, but before I buy a trailer, I want to make sure I am not limiting myself if I buy a 35 footer. We are looking at going for a 28-35 foot 5th wheel toy hauler, with a slide out or two.
SeattleFire
Snohomish, WA
Posted: 04/13/12 11:59pm Link  |  Print  |  Notify Moderator
Have a 33' FW in WA State. I know of a few CG's that have "limits" and have been just fine writing them off. Only way to know is to contact any CG's you think you would frequent and ask.
Jackthewonderdog
United States
Posted: 04/14/12 12:16am Link  |  Print  |  Notify Moderator
No too many, have seen 42 and 45 ft units in many. It is a campground specific issue, not a state issue. Most campgrounds post their limits online.
fla-gypsy
North Florida
Posted: 04/14/12 12:26am Link  |  Print  |  Notify Moderator
Every indiviidual campground has it's own set of limitations based on it's unique characteristics. There is no "one size fits all" limitation for all campgrounds in a geographic region.
steeleshark
Georgia
Posted: 04/14/12 02:52am Link  |  Print  |  Notify Moderator
State parks and other government campgrounds may have some.
2011 Nissan Armada SL w/Tow Package
2012 Coachmen Freedom Express (292BHDS) Liberty Edition
Admiral
Upstate Ohio
Posted: 04/14/12 04:43am Link  |  Print  |  Notify Moderator
There seems to be alot of variance with posted length limits in campgrounds. You may be able to fit into a shorter posted site if your tail overhangs the pad and you can tuck the bed under the pin while parked. Length aside, the most neglected maintenance in campgrounds seems to be tree trimming. 5th wheels, due to their extra height, are least likely to get spots with overhead branches on the sites.
That said, don't back up without a spotter!!
2004 Damon Daybreak 2960F V-10
05 Honda Element LX
Compassion should be voluntary, not mandatory.
Ivylog
Blairsville, Ga. USA
Posted: 04/14/12 05:53am Link  |  Print  |  Notify Moderator
A lot depends on how well you can maneuver your rig and if it's a find you're own site type of CG. I like them better than ones where you are told to go to sit #21 as I can usually get into a site that is only big enough for a 38'. I started with a 36' DP because of posts on here that said that was the max for most CG's. Did not take very long to realize that was not true so next a 40' and now I have a 42'. Sure the bigger the rig the fewer sites that are big enough, especially if you show up Friday afternoon at a CG that does not take reservations. Just because it says 35' max does not mean there are not any sites that will fit a longer unit. Yes, I have some scratch's on the upper sides of my MH from getting into USFS, BLM, and even some SP CG but those are the types I like the best. The back of a 5er is higher off the ground so hopefully you will be able to back over the rocks that some CG's use at the back of the site.
Buy more RV than you think you need, ONE TIME... not like me.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Tothill
BC
Posted: 04/14/12 07:46am Link  |  Print  |  Notify Moderator
In BC Provincial Parks you can get site info on the website, but you also have to take into consideration that many of the park were developed years ago. Thus the roads may have tight turns that can limit rig size.
Eurocamper
Salt Lake City, Utah
A lot depends on what kind of camping you want to do.
Most commercial campgrounds will not have a problem accommodating you. But if you plan on exploring rustic Forest Service campgrounds and some older National Park campgrounds, a 35-foot trailer is going to be way too big.
2008 Fleetwood Evolution E1
2011 Dodge Ram 2500 Crew Cab 4x4 Hemi
2007 Nissan Xterra 4x4
Ex 1997 Volkswagen Eurovan Camper
korbe
Northern California
Posted: 04/14/12 08:42am Link  |  Print  |  Notify Moderator
And those rustic Forest Service campgrounds don't have a way to find out the length limitations. We have a 25' 5er and can't fit into some of the nicer spots. We have even had trouble maneuvering within the access road.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
