RV.Net Open Roads Forum: THE HEAVY DUTY F150 HAS ARRIVED - First report ...
 > THE HEAVY DUTY F150 HAS ARRIVED - First report ...
Page of 8
Dragonfly
Ohio
Posted: 05/19/12 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Billtex
I will buy the truck camper as soon as the cash flow catches up (ie selling my VW Thing). In the meantime I am getting a cap for when the camper is off the truck and plan to sleep in that for short trips. This has been the most pleasant spring that I remember. I have done two road trips with just the truck, look forward to having a cap to sleep in and, hope that it doesn't go straight to hot humid summer as soon as the cap gets here.
DRAGONFLY - F-150, 4WD, extended cab, long bed, Ecoboost engine, max payload & tow pkg, 17", 7 lug wheels, 10 ply "E" tires, upgraded radiator, shocks & springs, transmission cooler, stabilizer bars, 8200 lbs GVWR, payload 2,280 lbs, 21/16 mpg unloaded.
Dragonfly
Ohio
Posted: 05/19/12 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Since this thread focused upon the selection of a new "heavy duty" half ton truck, and it has run its course, I opened a new thread about choosing an appropriate and safe camper for the "HD" F 150. New information will be posted there. If you missed it, you can find it at the below link ...
NEW THREAD ON CHOOSING A SAFE CAMPER TO MATCH THE "HEAVY DUTY" FORD F 150.
TZtraveler
Hong Kong SAR China
Posted: 05/20/12 12:28am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for this thread and the detailed, accurate information you have given us. I am in the early research stages for a truck and camper and you have been extremely helpful. I look forward to reading the new thread and finding out how camping in the topper works, what camper you find, and how camping in that works!
parkerjt
Jacksonville, FL
Posted: 05/20/12 05:18am Link  |  Quote  |  Print  |  Notify Moderator
I thoroughly agree, this has been a very interesting thread!
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/20/12 09:04am Link  |  Quote  |  Print  |  Notify Moderator
elkhornsun wrote:
The manufacturers distinguish between cargo capacity and payload capacity. The former includes a 150# per seat passenger load to the truck. The payload capacity is the amount of weight that the rear can handle with the provided axle, springs, and wheels.
Payload capacity is determined by subtracting the truck's actual scale weight from the GVWR. This is the number also printed on the yellow payload sticker. It is printed at the factory, so it does not include the weight of any dealer installed options or other aftermarket equipment added to the truck after it leaves the factory.
Rear axle load capacity is determined by subtracting the truck's actual rear axle scale weight from the RGAWR.
Camper loading weight as listed by the manufacturer may or may not account for driver weight and passenger weight for each seating position.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
stevenal
Newport, OR, USA
Posted: 05/21/12 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Dragonfly wrote:
I GOT THE WEIGHTS FOR THE HEAVY DUTY F 150
I finally found a scale and weighed the truck, here are the results.
GVWR = 8200 lbs
Weight of empty truck with full tank of gas = 5920 lbs
Difference 2,280 lbs
Sounds about right. I posted a link to the towing and camper guide earlier, showing a cargo (sorry, not payload as I said in my post) weight of 1539. That works out to about 5 150 lb passengers, 3 in the front and 2 in the back.
'98 Bigfoot 1500
with low loss control on the Fantastic, Dino board on the Dometic.
Torklifts and Fastguns
'04 F350 V10 Crew SRW SB 4X4 6 speed
with tow hook replacement, dual rate charging, Line-X, Timbrens.
Page of 8
