RV.Net Open Roads Forum: Travel Trailers: Rookie mistake -forgot to pull the plug
 > Rookie mistake -forgot to pull the plug
H2oboy22
Posted: 05/14/12 08:41pm Link  |  Print  |  Notify Moderator
Ok so I pulled out of the site without unplugging shore power cord. The cord pulled out of the shore power without any obvious problems. Did I get lucky? I plugged it back in and everything still worked but I didn't know if it was running off of shore power or battery. How do I tell which one it is running off of? And anything I need to check to make sure I didn't mess anything up? My power cord is one that is built into the trailer.
Thanks for the help. You can bet I won't do this again. Will be making a full walk around the trailer before pulling out.
Sloop Smitten
San Marcos, CA
Posted: 05/14/12 08:52pm Link  |  Print  |  Notify Moderator
Unless you have a built in inverter you should be able to check any AC appliance. Microwave or Air Conditoner for instance. If you have an inverter you can turn it off. I keep a cast-off list in the driver's door pocket I refer to anytime I am leaving a camp site. Removing the AC power cord is one of the items listed.
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
fla-gypsy
North Florida
Posted: 05/14/12 08:54pm Link  |  Print  |  Notify Moderator
Sounds like you got lucky. I would still take a look at the terminal connections where the power cord hooks up to be sure.
Terryallan
Foothills NC
Posted: 05/14/12 08:55pm Link  |  Print  |  Notify Moderator
The AC won't work off the battery, nor will the microwave.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
brirene
midwest
Posted: 05/14/12 08:59pm Link  |  Print  |  Notify Moderator
If there is no obvious damage to the plug or the cord, maybe you did indeed get lucky! Can you get to the other end of the cord to check those connections also? No pedestal attached to the plug end, right?
BTW, welcome to forum! We all live and learn!
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
Mark and Linda
Smyrna, Tennessee
Posted: 05/14/12 09:01pm Link  |  Print  |  Notify Moderator
Might want to make you a laminated check list to use. I try to do a walk around before pulling out of the spot. I made me a little flag to hang on my antenna crank just to make sure it is down. It sounds like someone was looking out for you.......
hallock5
Posted: 05/14/12 09:02pm Link  |  Print  |  Notify Moderator
Yup, we physically have a checklist, sort of aviation style. We don't care who is watching--the way we figure it, what's funnier--the folks with the clipboard or the RV'er towing their power cord behind them.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
SDcampowneroperator
South Dakota
Posted: 05/14/12 09:08pm Link  |  Print  |  Notify Moderator
try your tv or microwave, a/c unit. Glad to hear your rig was not damaged.
You did not mention if there was damage to the camp equipment. Did it fare as well?
Intheloonybin
Twin Cities, Minnesota
Posted: 05/14/12 09:38pm Link  |  Print  |  Notify Moderator
I have a night light plugged in right inside the door. It's what I use to tell if there is 120 volt power in the trailer after plugging in- in addition to providing a little light at night
HVAC/R tech.
2006 GMC Envoy XL 4.2 I6 1999 Coleman Niagara
2 Great girls 18 and 15
1 Great wife
1 Wonderful Goldendoodle
garym114
Bluff Dale, Texas
Posted: 05/14/12 09:45pm Link  |  Print  |  Notify Moderator
I always walk around twice. Look up, look down
