RV.Net Open Roads Forum: Class A Motorhomes: Equalizing batteries
 > Equalizing batteries
Oilman
Long Island NY
Posted: 05/21/12 10:46pm Link  |  Print  |  Notify Moderator
Mr.Mark wrote:
Ok, I guess I'll ask, how do you equalize the batteries?
MM.
Check the manual for your 3 stage battery charger. It should have instructions on how to equalize the batteries.
Its just a matter of putting the charger into equalization mode.
Mr.Mark
California/Tennessee
Posted: 05/21/12 10:56pm Link  |  Print  |  Notify Moderator
Oilman wrote:
MM.
Ok, I'll check it tomorrow. Thanks,
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
full_mosey
Oklahoma
Posted: 05/22/12 09:12am Link  |  Print  |  Notify Moderator
Mr.Mark wrote:
Have never done it. Our 8 house batteries are 5 yrs. old, wet cell and seem ok so far. I wouldn't know how to do it anyway. When mine start not holding a charge, I'll get new ones.
MM.
Interesting! I have a theory that simply traveling will agitate the batteries sufficiently to keep the electrolyte equalized.
HTH;
John
dons2346
Sioux Falls, SD, formerly of So. CA
Posted: 05/22/12 09:38am Link  |  Print  |  Notify Moderator
My Lifeline 8D AGMs are going on 9 years old and I have never equalized them.
Mr.Mark
Posted: 05/22/12 09:40am Link  |  Print  |  Notify Moderator
full_mosey wrote:
MM.
HTH;
John
If your theory is correct, then we should be OK. We have almost 52,000 miles and I drive the coach monthly giggling the batteries. LOL!
I'm going to see what my manual says about equalization. I clicked on the link you posted about equalization, read it, and I hate to mess with batteries besides just filling with distilled water.
Last fall, our neighbor in Bar Harbor, ME, was messing with his batteries on his 'new to him' late model Tiffin Phaeton when he first purchased it. One of the batteries exploded and the acid ate through his shirt but didn't get in his eyes. His neighbor heard an explosion, came over and doused him with water so he didn't get burnt.
Honestly, I'm very leery working around batteries.
MM.
* This post was edited 05/22/12 12:06pm by Mr.Mark *
full_mosey
Oklahoma
Posted: 05/22/12 08:13am Link  |  Print  |  Notify Moderator
MM.
Equalization.
HTH;
John
2oldman
Winchester WA
Posted: 05/22/12 09:45am Link  |  Print  |  Notify Moderator
It might, but ....
From Trojan Website:" Equalizing also helps to remove sulfate crystals that might have built up on the plates. If left unchecked, this condition, called sulfation, will reduce the overall capacity of the battery."
I doubt it would do that..
full_mosey
Oklahoma
Posted: 05/22/12 10:02am Link  |  Print  |  Notify Moderator
Nor should you! In the context of this topic, equalization means to deliberately charge at a voltage that would cause wet/flooded battery cells to hiss, fizz, bubble and sizzle. That is DEATH for your AGMs.
HTH;
John
full_mosey
Oklahoma
Posted: 05/22/12 10:34am Link  |  Print  |  Notify Moderator
2oldman wrote:
It might, but ....
I agree that simply driving will not address sulphation or balancing cell voltages. Regular charging will though.
The key word in the Trojan cited above is also. Heck, the cell voltages might be balanced as well, right? This high voltage stirring of the electrolyte topic is related to wet cells.
I don't believe that these higher wet cell de-stratification voltages are required to control sulphation or to balance cell voltages for wet or AGM.
HTH;
John
2oldman
Winchester WA
Posted: 05/22/12 10:52am Link  |  Print  |  Notify Moderator
Hard to say.. it's not as if you can visually inspect for it. If you're paying close attention you can notice a decrease in battery capacity.
Equalization is way more important for boondockers. Our batteries are almost always in a non-fully-charged state, and therefore susceptible to the above conditions.
