RV.Net Open Roads Forum: Tech Issues: Slideout Problem
 > Slideout Problem
grammygiel
Eagan, MN
Posted: 05/26/12 09:04am Link  |  Quote  |  Print  |  Notify Moderator
I recently retracted the bedroom slideout without closing the electric access door below it. Needless-to-say, I caused some damage to the trim at the lower edge of the slideout and to the access door itself. My question is this, before I get the damage fixed, would anyone recommend opening the slideout? Is it possible that there is more damage to the slideout unit than I can see and I won't be able to retract the slideout again? I have a 2004 Itasca Sunrise 30W. I really get some helpful advice from experienced RVers. It makes being a novice palatable! Thank you.
donn0128
Pronounced Ore-gun
Posted: 05/26/12 09:20am Link  |  Quote  |  Print  |  Notify Moderator
BTDT. Rookie mistake. and sometimes a not so rookie mistake. Without actually inspecting what damage you already have there is no way to say for sure if you would be safe or not.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 05/26/12 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I've knocked some trim loose by leaving the arm of a chair in the way, no big deal. A few small ringed panel nails is a small DIY job.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
powderman426
ohio
Posted: 05/26/12 11:59am Link  |  Quote  |  Print  |  Notify Moderator
If your concerned about damage you can't see, it may be wise to hand crank it open. It you feel it binding, stop and check it out. JMO
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
pulsar
Lewisville, NC
Posted: 05/26/12 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
 > Slideout Problem
