RV.Net Open Roads Forum: Tech Issues: Replacing Atwood Lp gas control unit
 > Replacing Atwood Lp gas control unit
64Wildcat
Wa
Posted: 05/27/12 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
I am having a heck of a time trying to replace the gas control on this tank. It wont come out. I have a new control. I wrenched it and the old unit broke. I cant get the thermo. out of the tank. Aluminum tank with iron pipe treaded in. Its the original 94 unit. In my 94 Itasca Passage Any ideas besides a new water tank, which may be the next process. Its a G6A7 pilot only 6 gallon tank.
Any help is appreciated. My wife needs her hot water
Thanks Gary and Carol
enblethen
Moses Lake, WA
Posted: 05/27/12 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
If the bulb came out when you broke it, you could use a hacksaw to cut the steel pipe. Takes a frameless short saw. careful not to cut into tank threads. Cut the steel portion in thirds, bend the steelp inward.
Could try a large easy out. Reverse thread style works better.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
64Wildcat
Wa
Posted: 05/27/12 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Bud
I think the copper themo bulb is still in there, It broke with 3/4 inch of steel pipe out and I have tried the pipe wrench and drilling into the steel. The age of the unit probably and what corrosion has happened over the years has welded it in tight. I will get a hacksaw in there and try that
enblethen
Moses Lake, WA
Posted: 05/27/12 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
You will need to get the bulb out to use the hacksaw method.
Nicks in aluminum hub can be taken care with teflon tape.
Where in WA are you?
pulsar
Lewisville, NC
Posted: 05/27/12 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
64Wildcat
Wa
Posted: 05/27/12 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Im over in Port Orchard near Bremerton
64Wildcat
Wa
Posted: 05/29/12 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Well I got it out. What fun! The new one went in fine, it was a replacement for the old White Rodgers unit and much easier to work. but it fired right up. But the thermo coupler gas tube dont fit as good as the old one did to the gas inlet. Mainly the sliding air adjustment that goes to the gas inlet.
I left the pilot on and went inside and came out and there was a small fire which I blew out and turned off the gas. I was sure that all fittings were sealed for leaks but I guess not. Any suggestions? I would hate to torch off the motor home.
Thanks
Gary
enblethen
Moses Lake, WA
Posted: 05/29/12 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Did you put yellow teflon tape on the threads for the orifice adapter?
Did you clean it out good so no spider webs left in it?
Are you talking the 3/4 inch tube or the small pilot light tube? Pilot light tube on some take an adapter to change thread style or from flare to pipe.
64Wildcat
Wa
Posted: 05/30/12 07:15am Link  |  Quote  |  Print  |  Notify Moderator
I redid all the fittings with new teflon tape to be sure of having a good seal. Double checked all. Turned on gas did all the proper steps. Now I cant even get the pilot to light.
The heat did melt the plastic heat adjustment and gas pilot and off and on switch. They still turn, just warped. I guess something internal may have have been damaged?? Trying to save $$.
