RV.Net Open Roads Forum: Class A Motorhomes: serpentine belt
 > serpentine belt
John&Joey
Some Location
Posted: 06/10/12 05:29pm Link  |  Print  |  Notify Moderator
On my car it is 18 years old and my mechanic just looked at it. Saw no cracking and said it was good to go. Drove out to Yellowstone and back without an incident.
Belts and hoses are made with better material then back in the old days. If you have a quality belt or hose it should last a long time. It's those cheap autopart store items that concern me more.
Ivylog
Blairsville, Ga. USA
Posted: 06/10/12 06:56pm Link  |  Print  |  Notify Moderator
Earier to change it when you have the tools and the engine is not hot. Save the old one and then do not worry about it for ten years. Draw a diagram on the box that the new one came in, that way you will never need it.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Heir Max
membership 1/16/2001, Bay Minette, AL
Posted: 06/10/12 07:11pm Link  |  Print  |  Notify Moderator
I have the 3126 300 CAT. Don't know where the ten year deal is coming from. With rear radiator, there is a lot of heat over the belt. I have replaced one at 104,000 and another at 175,000. Both of them on the side of the road. The first one was inspected the day before it went out. The MH is a 99 with 185,000 miles now.
99 Tradewinds
2000 Explorer Toad
wolfe10
Posted: 06/10/12 07:26pm Link  |  Print  |  Notify Moderator
RayChez wrote:
It is a job and a half to change it on the 3126-E Cat engine. Once I see cracks on the rubber I will take it to Freightliner to change it out. I believe they will have to remove the air cleaner and part of the duct to be able to get to it on mine. That is what is bad about rear radiators.
Ray,
Really depends on whether it is rear or side radiator. I can change my serpentine belt (Caterpillar with side radiator) in under 3 minutes.
So, it is less and engine issue and more an access to engine issue.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
randallb
On the road
Posted: 06/10/12 07:54pm Link  |  Print  |  Notify Moderator
Steve,
Our 08 6.7 ISB threw the belt on the ground (literally) at 11,000 miles. Just like anything that is man made an unexpected failure can occur. Usually a serp belt will last a long time (50,000 easily). Cracks across the ribs are nothing to panic about but the belt(s) should be replaced prior to any long trip. The replacement is more for peace of mind than it is to prevent a failure. I always use the old adage, "If you are thinking about it. Replace it". This is something I learned in my late teens in relation to the tires on my motorcycle.
Randy
Greginsd
San Diego CA
Posted: 06/10/12 07:56pm Link  |  Print  |  Notify Moderator
We just replaced ours, before we took a trip to Las Vegas last week. The belt had just started to crack after 12 years and 78,645 miles. Did all the hoses at the same time. 2000 Winnebago Journey with the Cumming 275 rear radiator.
Greg & Kate
3 great kids and 2 dumb dogs
2000 Winnebago Journey 36L DP
275 Hp Cummins on a Freightliner Chassis
Always drink upstream from the herd.
jpajax
North Carolina
Posted: 06/10/12 08:38pm Link  |  Print  |  Notify Moderator
The cooling fan is driven by the this belt, miles, time and heat affects it. Change it put it up for spare.
Galvanizd
Looking at the Mogollon Rim ...... For a bit.
Posted: 06/10/12 10:39pm Link  |  Print  |  Notify Moderator
Mine lasted 35000, 4 years before it broke. I inspect mine before trips and when I change the oil. I have 74000 miles total now and will replace it next year.
Its rubber. They wear out.
Better than that, they cost all of about $35.00 so forget using the old one as a spare. Throw it away. Carry a new one for a spare.
Sully2
Cincinnati
Posted: 06/11/12 06:00am Link  |  Print  |  Notify Moderator
STEVEP220 wrote:
I would like to know about how long a serpentine belt should last before it needed to be replaced. I have 2005 cummins ISB 300hp with 21,000 miles.
Mine is a 2000....getting ready to replace it in the very near future. Mine is an ISC engine
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
SpurHntr
Northeast PA
Posted: 06/11/12 08:07am Link  |  Print  |  Notify Moderator
othertonka wrote:
Regardless of when you should change the serp. belt, it is imperative that you find the belt routing diagram for your engine. If you can't find the diagram draw one up yourself and/or take a picture now before the belt breaks. After the belt is gone it is real hard to figure out the routing. Just a thought, I drew a diagram for mine.
good advice
'08 Newmar Kountry Star 3916, 400ISL Cummins
'11 Jeep Wrangler Unlimited Sahara
'07.5 LMM 2500HD Duramax Crew 8'
Blue Ox, BB, PP TPMS, BB Buggy, Ranger EV
FMCA 427040
 > serpentine belt
