bsjones11
pensacola, Florida
I have two tvs on my coach. Both are new and have been working fine with the antenna setting. The coach has been in storage for a month and we picked it up to get a few things straight before a trip. I tried to get local stations on the front tv to no avail. It keep saying no signal. Went to the back tv and it says the same. Nothing has changed. Anyone have a suggestion for what to check. Gets sat on both tvs fine. I am not somewhere that I can check the cable. Both tvs always pick up the antenna channels even with searching. HELP
sch911
Rochester Hills, MI
Make sure the antenna booster switch is turned on, and the antenna is aimed in the correct direction!
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
bsjones11
pensacola, Florida
Everything is on. Nothing changed since last used it. But it will usally pick up a channel or two even without searching. now it just says NO SIGNAL
352
Oxfofd, Fl
Try rescaning the channels. Every time I disconnect shore power I have to rescan.
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters
just a good ole southern redneck country boy
Come visit with us and swim with the Manatees
jrlibbie09
Colleyville
do you have a splinter box in the front? Maybe a button not pushed in all the way, or the antenna cable coming in the back came loose or got damaged somehow. Maybe get on roof and make sure connections all good.
Coachmen Encounter 37FW 2012
bsjones11
pensacola, Florida
I always have to scan channels also. So that is the first thing I did. But it tells me NO SIGNAL. First time it has done that. And not one, but both tvs. I will go on the roof and check the antenna conection tomorrow. Maybe something is disconnected. Thanks for all the help. Keep um comming
rvrepairnut
bc
bsjones11 wrote: I always have to scan channels also. So that is the first thing I did. But it tells me NO SIGNAL. First time it has done that. And not one, but both tvs. I will go on the roof and check the antenna conection tomorrow. Maybe something is disconnected. Thanks for all the help. Keep um comming
U did switch the TV to the correct setting ? I will assume.
When I use cable verses FTA I have to change the input signal location on my TV via the remote.your TV uses a different input,s for antenna verses cable verses satilite
Jim Cindy
Northcentral, PA
Did you actually check the booster switch, maybe got turned off while cleaning etc.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
rvten
Crossville,TN
Visio selector box switches set correctly?
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
Captain_Happy
Abilene, Texas
There is something else to check when all else fails. Up on the roof where the coax cable comes up through the roof there is probably a cover plate on the roof that's covering the coax cable. If you have this setup, romove the decor caulking and all the screws that hold it to the roof. What I found on mine is underneath the plate is a coax cable coupling fitting. Take it apart. I'll bet you that it's all rusted inside. This is what I found on my rig a few years ago. After I replaced the coupler/ clean the cable center wire I got more signals then I ever got at the house before. What I did was, run a new cable from the switcher box right to the antenna itself. The new cable fixed the problem with the signals. Then I just figured I'd replace the whole cable from the antenna righ to the switcher box, that's when I found the rusted fitting underneath this roof plate. Just something else to try.
