Thanks for the replies here folks.
Where does one find the Eternabond? I can't say I have ever seen it in the stores I prowl around when I'm in the US. Any opinions on painting the roof with soome sort of coating to help protect it more and to give it some reflectivity? I like the idea of the white color on the top.
Thanks for the help.
Stay safe out there.
Ken
The inherent vice of capitalism is the unequal sharing of blessings;
the inherent virtue of socialism is the equal sharing of miseries. Winston Churchill
If you are just using it for a reflective properties you might look at a product called Seal A Flex. It is a paint type product designed to cover waterproof decks and used on pool decks. My guess is your trying to get something close to white for the cooling effect.
Doc Eagle wrote: If you are just using it for a reflective properties you might look at a product called Seal A Flex. It is a paint type product designed to cover waterproof decks and used on pool decks. My guess is your trying to get something close to white for the cooling effect.
Pretty much it. I think it will help to keep the temps down in the sun and also look cleaner when it's washed. Does that stuff stick to metal? Realistically I don't think there would be any product to be rolled or sprayed on that would have any insulating effect. I want to be able to make it good and right when I'm done and something that will last for a number of years. Next time this needs to be done it should be my son's issue to work on.
