RV.Net Open Roads Forum: Truck Campers: Casette Toilet
 > Casette Toilet
big whitey
raleigh,nc
Posted: 07/03/12 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
can anyone with a CASETTE TOILET recommend a good holding tank chemical that will eliminate odors and where it can be purchased.the ones i have tried at wally world are less than adequate,regardless of quantity used or price.
Old-Biscuit
Across the USA
Posted: 07/03/12 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Super Dijest It
This product does work.......pricy but works.
I personally don't use any chemicals, cause we fill dump every week and don't have an odor problem. But I have used this product in past years when we only camped occasionally. It wasn't as pricy back them....but it goes a long way.
Then there is this product......
Happy Camper
Don't know anything about it other than I read about folks recommending it here at RV.Net
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
xnorp
Spokane Washington
Posted: 07/03/12 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
I use Happy Camper also have been for years have not had a order problem while using it. What I like about it is there is no perfume smell to it. And you only have to use a scoop per 30 gallons so it goes a long way.
xnorp
2000 F-250 SD PS 04 Snowriver 9'6" Rancho 9000X Super Springs Vision 19.5 w/Toyo M608Z
Hey there
Pendergrass, GA
Posted: 07/04/12 12:32am Link  |  Quote  |  Print  |  Notify Moderator
The chemical that I have found that works best for me is baking soda. I just put 1/2 cup in after I drain the holding tank. No odors at all.
Kurt
2001 Silverado 3500 DRW CC LB 6.0
1993 Lance Squire Lite 150 (8'6")
2001 Fleetwood Caribou 11J (11'6")
joerg68
Ueberherrn, Germany
Posted: 07/04/12 02:05am Link  |  Quote  |  Print  |  Notify Moderator
We have installed an SOG. No chemicals neccessary whatsoever anymore.
It is a small fan that engages as soon as you hit the lever. Vents all gases to the outside through a carbon filter before the toilet valve opens.
No smell, no chemicals, and you can dump in any toilet facility.
It is a fairly easy DIY job.
Here is a link with a product description:
http://www.campervanstuff.com/shop_stuff/index.php?mod=product&id_prd=1048
-J
"Pickups are very handy cars. One step on the brakes, and everything you need is right behind you!"
weymard
NORMANDY
Posted: 07/04/12 02:24am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Joerg, the SOG is the best product et so far for cassette. Very efficient and easy to put on, just no cheap....
Lance 815 2007
France, Normandy
woodhog
NS
Posted: 07/04/12 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Really like the SOG system, as usual the Europeans have upstaged us in RV Innovation.
In the meantime we use Thetford Campa-Chem .A very small amount poured into the water tank fill spout. Then dump the water into the C2 Thetford.
It just barely turns the water in the sight glass bluish.
It is biodegradable also.
Time to dump now, love it, no hoses, no fuss, turn her up , push the button and the 20 second dump procedure is finished.
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow Longbox 200 Watts Solar, LED lights.
12 Volt DC Fridge.
big whitey
raleigh,nc
Posted: 07/04/12 09:10am Link  |  Quote  |  Print  |  Notify Moderator
thanks for the suggestions.guess i will have to look on line or at the dealer to purchase as none of the brands mentioned are available at wally world.
Hey there
Pendergrass, GA
Posted: 07/04/12 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Big Whitey,
Hi,
Try the baking soda before you spend any money. What's it cost? Ten minutes of your time? Then you will actually know whether or not it does the trick.
Kurt
Nemo667
Louisiana
Posted: 07/04/12 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
What kind of cassette toilet do you have?
2007 F-350 SRW 6.0L CC SB 4X4
2006 Outfitter Apex 8, 220W Solar and 3 AGM's
2008 Jeep Rubicon
 > Casette Toilet
