RV.Net Open Roads Forum: Class A Motorhomes: Replacing a Batwing with a Jack
 > Replacing a Batwing with a Jack
pitchindad1
Dickinson, TX
Posted: 07/12/12 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
I am considering replacing my batwing antenna with a fixed mount Jack antenna. How do the holes match up from the old antenna to the Jack. Is the bolt pattern similar or will I have to figure out how to keep the holes from the old antenna from leaking?
I can't seem to keep the rubber cover that goes over the wires that go through the roof from working itself off the little nipple and letting rain in.
Any ideas or how did you deal with this?
Thanks for any ideas. Just a little back ground, 2004 Holiday Rambler DP.
mph_medic
Southaven, MS (Outside Memphis, TN)
Posted: 07/12/12 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced the oldbatwing with the Jack and reused the lifting arms.. and I works great... up down round and round.. that way you can get the best picture..
Never do anything you wouldn't want to explain to the Paramedics...
1993 Damon Frontier Flyer
Lobstah
Northeast
Posted: 07/12/12 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, holes line up perfectly. Great antenna.
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
sljkansas
Miami Co. Kansas
Posted: 07/12/12 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Raise the boot, put enough calking around hole and coax so when you slide the boot down all is sealed.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter can now be called a Teacher.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
rgatijnet1
Posted: 07/12/12 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
If you replace the batwing with the Jack and keep the antenna arms, to raise and lower it, you do not need to worry about breaking the seal.
If your existing batwing has a powered amplifier, DO NOT use the transformer/power supply that comes with the Jack. The Jack antenna will get it's 12 volt power through the coax cable.
wildtoad
Blythewood, SC
Posted: 07/12/12 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
I did the simple replace the head swapout. Took 5 minutes tops and works great.
Tom Wilds
Blythewood, SC
2000 Hurricane 30Q
luvlabs
Frederick, MD
Posted: 07/12/12 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
I did a total replacement of my bat wing after a neighborhood tree destroyed it. It was pretty straight forward - remove the bat wing, clean up the old caulk (a heat gun helps), install the Jack over the existing hole, caulk any old holes that aren't covered and around the Jack. You will need to determine which shaft extension to use for the Jack, mount the inside ceiling plate, and replace the old Winegard amplifier with the Jack model.
The outside work took less time than the inside but overall, less than an hour.
2012 Tiffin Allegro 32CA
2012 Honda Fit
the_armadillo
SE Texas
Posted: 07/12/12 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what the OP means by fixed mount. When I was considering the Jack antenna, I liked the swivel mount that the Jack had that did not require elevating and retracting as on my Winegard Sensar IV. Did some testing with the Jack head only as a replacement and stuck with my Sensar IV because of the way it handled better on the Sensar arms, smoother elevating and rotating.
However, when researching swapping out the entire antenna, King Controls does offer an adapter plate to cover the previous holes.
Jack adapter plate
George Beggs
Homosassa, FL.
Posted: 07/18/12 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my batwing with a Jack. It was very easy the problem came about the fifth time I used it. I had a weak signal and turned off the 12 V DC and then back on. That killed my Jack. Luckily I had the old batwing and put it back on. The Jack did get digital signals better; before it died.
George & Linda
1999 Pinnacle F53 6.8L V10
Banks Transcommand
bobmacc
Ontario
Posted: 07/19/12 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my batwing completely with the Jack roof mount unit. The toughest part was removing the existing Winegard. On my Winnebago, the base was glued to the roof with an epoxy type glue that created a very secure bond. I ended up taking part of the fiberglass off as the expoxy wouldn't separate from the roof. I used a small sheet of aluminum to cover the old antenna mounting and mounted the Jack to the alumiminum. Works great.
* This post was edited 07/21/12 06:38am by bobmacc *
