patt4you
Can anyone tell me why a propane detector will just go off in the middle of the night. Mine does. I have to turn the ac poer and the dc power off and wait. if i hook the dc up first it wont set. i have to turn the ac on before the dc then it will reset. its got me stumped. Help
Johnworth914
USA!
1) some cleaning products will cause the detector to go off.
2) I have heard reports that certain emmissions from pets also have caused some detectors to go off.
Not saying these are causing yours, just what I have heard about over the years.
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
patt4you
I have no pets and not cleaning at 2am so keep thinking guys thanks If it was propane it wouldn't reset i wouldn't think...
D.E.Bishop
Eagle Rock, CA
I don't know what type of detector you have but if it is the type that has to be on to run the gas like mine, I think you're up a creek. Lots of things including the fridge starting or stopping or the WH turning on or off could give a momentary drop or surge in power. Some detectors are set to go off with the slightest change in power or gas level. I know I want to change mine out but when the detector was installed, there was no allowance for changing the solinoid out and my detector is an orphan and I have to change everything out but the wiring and gas lines. If I remember right it's about $300 for a complete detector. I understand the need for safety but that's a lot of monry when a detector is about $20 bucks.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
Carvin Marvin
Livingston, Texas, USA
Aerosol products under the sink caused ours to sound off. Removed the products and all is quiet. I didn't clean after dark either.
patt4you
I wonder if my battery could be going bad?? what do you think? its really agrivating to wake up in the middle of the night. about ready to cut the wires. it happens at different times. 1 week 1-3 months who knows.
rrupert
NW PA
I have heard that they have limited life and can start to give false alarms as they get older. And, as you mentioned, low battery voltage can cause them to trip. We had one that would chirp when the battery got low, much like when a smoke detector battery gets low.
Rich and Joyce
2010 HiLo 2310H
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
Dieseldave
Forney, TX
I've had that problem on my last 2 fivers after a couple of years of use. Usually it's just a sign the detector is going bad. I replaced both of them and then no more problems.
patt4you
My unit is 2 yrs old so it could need replacing. if its not the battery im going to try a new one. thanks all for your help
rrupert
NW PA
Normally they should last much longer than that. But there can always be a bad pea in the pod. There could be some other problem. I would check the 12 volt system voltage when it does that to see if it dropped all of a sudden. I think most reasons have already been covered above.
