RV.Net Open Roads Forum: Tech Issues: Fluctuating Oil Pressure
 > Fluctuating Oil Pressure
TurnThePage
North ID
Posted: 07/13/12 02:17pm Link  |  Print  |  Notify Moderator
'97 F150 with the 4.6L V8. It's not very noticeable except when towing. The gauge starts to bounce around and the oil light will momentarily come on. I was hoping it was the sending unit, but I guess not. Any thoughts?
2015 Ram 1500
2004 Pioneer 18T6
enblethen
Moses Lake, WA
Posted: 07/13/12 02:29pm Link  |  Print  |  Notify Moderator
It is possible on some rigs that the check valve behind the oil filter is bypassing.
Have you changed your oil since problem has developed? They may have put the wrong filter in.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
TurnThePage
North ID
Posted: 07/13/12 03:10pm Link  |  Print  |  Notify Moderator
The problem has been popping up for over a year. But was very inconsistent, until this week. I've had multiple oil changes since it started and did the last one myself, while changing the sending unit.
path1
Varies with weather
Posted: 07/13/12 03:24pm Link  |  Print  |  Notify Moderator
My best guess. Wiring, make sure it is good to include grounding. Does it act the same in cold weather? Since your oil changes, are you using same brand of oil filter? Just my opinion but some oil filters restrict oil flow during "high pressure" times like when towing or cold start ups. Try using a oil filter from your car dealer is see if any differance just one time.
(did a google search on "Fluctuating Oil Pressure" I was surprized to see what turn up, more than I thought.
* This post was edited 07/13/12 03:38pm by path1 *
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 07/13/12 03:33pm Link  |  Print  |  Notify Moderator
Check beneath the engine oil pan where you may find a wire harness running laterally across near a cross-member. Look at the convoluted black plastic wire harness sheathing to see if it has chafed through and into the wires.
skipnchar
Topeka or somewhere else
Posted: 07/13/12 03:48pm Link  |  Print  |  Notify Moderator
Install an actual pressure gauge so you KNOW what is happening. Lights are truly idiot lights and tell you next to nothing.
enblethen
Moses Lake, WA
Posted: 07/13/12 05:11pm Link  |  Print  |  Notify Moderator
If the pressure is in fact, flucuating, it is not an electrical problem. Sounds like a filter or bypass valve problem.
TurnThePage
North ID
Posted: 07/13/12 04:42pm Link  |  Print  |  Notify Moderator
I used a Motorcraft filter bought at Walmart. Yesterday specifically, while towing if I was on the gas the gauge danced around and would finally dip. That's when the light would come on. If I lifted off the gas pedal, the needle would go right back to where it belongs. After unhooking and driving around, no problem. I had the pressure tested, and it is definitely fluctuating.
Home Skillet
Pearland Texas
Posted: 07/13/12 05:05pm Link  |  Print  |  Notify Moderator
On the right side of the engine compartment, behind the battery-look for chaffed wires on the A/C accumulator. Very common issue where the wire harness rubs through and shorts out.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Home Skillet
Pearland Texas
Posted: 07/13/12 05:32pm Link  |  Print  |  Notify Moderator
The oil pressure guage is basically a dummy light. Its either on or off.
