RV.Net Open Roads Forum: Travel Trailers: going to a state park
 > going to a state park
quickrod66
Chestertown
Posted: 07/14/12 04:03am Link  |  Quote  |  Print  |  Notify Moderator
Planning our ist trip to a state park, I am seeing they have elec.hookup but no water hookup.there are some water symbols around the circle on the web site at stratigic spots. Question is can we fill our fresh water tank when we get there,or should we do it before we leave home ? suggestions appreciated.
greende
Syracuse,NY
Posted: 07/14/12 04:37am Link  |  Quote  |  Print  |  Notify Moderator
We do almost exclusive New York State Park camping. I always stop at one of the areas you mention and fill up. Sometimes on a busy weekend it backs things up but generally not too bad.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
Opie431
Bellevue, MI
Posted: 07/14/12 04:54am Link  |  Quote  |  Print  |  Notify Moderator
Have not been to New York parks but other state parks who have the same thing have places where you can fill up with water as well as dump. Ask when you come in where you fill up. The symbols are usually for tent campers to get water in the campground. Not that you cannot but you would probably have to sit in the middle of the road while you filled up.
Go Dogs
South of Pittsburgh, PA
Posted: 07/14/12 05:36am Link  |  Quote  |  Print  |  Notify Moderator
In Ohio, there is a special spot to fill with fresh water, as well as a dump station. Usually clearly marked but ask at check-in. I have been hauling my water from home as I saw signs of hard water at one of the parks. You still have to use your white hose to fill up. Bring disenfectant wipes to use at the dump station-faucet, chain, hose, etc.
RGar974417
Robesonia,Pa 19551
Posted: 07/14/12 05:40am Link  |  Quote  |  Print  |  Notify Moderator
You can use the hydrants located in the loop to fill up.I do not stop in the middle of the road to fill up my tank because I don't want to block the road for others.I usually put enough water in the tank before leaving to make sure we have enough for bathroom breaks.When we get there,if my hoses reach the hydrant,I fill up that way.If not,I use a 5 gallon portable tank and carry water back to the camper and use a hose and funnel to fill it up.Some have battery operated pumps they use to transfer water from the portable tank to the RV.Others use a rubber bladder that they can put on the roof of their TV or in the bed of their pick up and fill it at the dumpstation or restrooms.
dlos
raleigh, nc
Posted: 07/14/12 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I carry 7 gallon jugs and fill up using them when there are crowds at the fresh water fill areas. They are also useful for refilling if you stay a while and run out.
2010 Nissan Armada Titanium w/BT Mirrors
2010 KZ Spree 240BHS LX
Prodigy 2 Controller
Equal-i-zer Sway Control Hitch
Nights Camped in 2012: 24
sndman7
Solomons Island MD
Posted: 07/14/12 06:13am Link  |  Quote  |  Print  |  Notify Moderator
We always fill up at the hydrant provided, sometimes there is no choice but to block the road and that's OK.
When traveling long distances we always have a little water on board.
2006 Titanium 36E41 MPRV
2006 F350 6.0 PSD QC King Ranch
sch911
Rochester Hills, MI
Posted: 07/14/12 06:35am Link  |  Quote  |  Print  |  Notify Moderator
In Michigan the SP water spigots are specifically designed so that you cannot hook up and fill. You would need jugs and then hoof it to your rig. There are fresh water fill stations at the dump site areas, you would need to swing through there to fill up when you get there.
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
eric james
Sioux Falls, SD
Posted: 07/14/12 06:38am Link  |  Quote  |  Print  |  Notify Moderator
I fill up at home. Never get funky well water surprises. 8.3 lbs per gallon I can handle 240 lbs.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
crimmps49
Wisconsin
Posted: 07/14/12 06:55am Link  |  Quote  |  Print  |  Notify Moderator
We fill at home for the same reason eric james does--we know our water is good. The little weight that the water adds is minimal and I don't have to mess around at the campground.
