RV.Net Open Roads Forum: Class C Motorhomes: Interior Carpet
 > Interior Carpet
TimFromMaine
Maine
Posted: 07/16/12 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I have some stains on the interior roof carpet from some prior leakage.
Instaed of ripping it all out, I would like to carpet right over the top of that as well as some of the surrounding woodwork.
Has anyone ever done carpet over carpet?
Is so...any suggestions?
What is the best glue to use, etc.?
Best way to hold it in place while it attaches?
Thanks
webhannet
Southern Coastal Maine
Posted: 07/16/12 11:23am Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking you'll create an odor problem due to the old carpet.
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 07/16/12 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Not knowing how bad the stains are and integrity of your ceiling material (guessing it's carpet like fabric ? )
Have you tried the Oxy-Clean Method ?
Clean ceiling stains:
QUOTE:
"I've had some success removing ceiling stains using OxyClean with Woolite made for carpet cleaning. The only trouble was spraying upwards, it's made for spraying downwards. I did just a small area at a time, sprayed, let set for about 5 minutes, then blotted with clean towel, just as the directions tell you. Does clean it, but very slowly. I'll have to go over some areas.
The Oxy-clean suggestion is a good one. Let it soak a while though. Oxy Clean is a mild bleach and doesn't work quickly, but it is quite safe, even when used in strong concentrations." END QUOTE
-NOTE: I have not personally tried this (Only saving it for a rainy day), but have gathered the information from RV.NET and there seems to be a lot of Positive experiences with this method.
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
Jagtech
Sunny Southern Alberta, Canada
Posted: 07/16/12 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think you would be happy with the finished product of carpet over carpet. Very difficult to trim the edges nicely, and it will almost certainly sag in places if it doesn't adhere properly. This could be a real disaster! Is it really all that difficult to remove the old carpet? Some upper cabinets are installed after the ceiling is done, so you might need to cut around the cabinets to get it off. Replacing with carpet is fine, but also consider a heavy grade vinyl, if the ceiling is relatively smooth.
BTW, the Oxyclean sounds like it might clean your old ceiling. I've used vinegar and water in a spray bottle, and a wet vac to remove it after cleaning, with some success.
If you decide to proceed with carpet over carpet, I suggest contact cement would be your best option.
Good Luck!
1998 Triple E F53 with 460 Ford
1995 Jeep Wrangler toad
dying2fish
new egypt,new jersey
Posted: 07/16/12 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have used the OxyClean method and it works . Just mixed it up and put it in a spray bottle, to be able to spray it up into the ceiling. Also used a small scrub brush to work it in let it soak, then draw it out with a wet vac.
Dakzuki
Carnation, Wa, USA
Posted: 07/16/12 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
I Have had great luck with Oxyclean. Best bet is to lose the carpet and you will lose that issue.
2011 Itasca Navion 24J
95 Chinook Premier
Calisdad
groveland, ca
Posted: 07/17/12 08:03am Link  |  Quote  |  Print  |  Notify Moderator
We took some carpet out and were pleasantly surprised to find perfectly good vinyl underneath.
Coach-man
Posted: 07/17/12 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
X2, get rid of the carpet, even "clean" looking carpet has a lot of dirt and "stuff" in it! You would be surprised as to the amount of weight that carpeting adds to your vehicle. Vinyl flooring or other flooring can reduce weight keep the RV cleaner and smelling great and looks real nice as well! Good luck!
 > Interior Carpet
