RV.Net Open Roads Forum: Truck Campers: **Update on steering and sway **
 > **Update on steering and sway **
billyray50
Dallas
Posted: 08/09/12 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Found out this morning that passager side outer tie rod,upper and lower ball joints, and F center link need replacing. Also weighed my 2006 Dodge 2500 CTD 4x4 qaud cab longbed with 1 ton axle at cat scale today. Steer axle : 4340 lb..Drive axle :2740 Lb. Gross weight: 7080 lb. Going to weight truck/camper tomorrow. Will update.
d3500ram
colorado
Posted: 08/09/12 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Get those components replaced and you should notice a difference...
...also, was your weigh-in with a full fuel tank and tailgate off? I usually do these 2 things when getting a base weigh before putting a camper on.
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
2008 NorthStar Arrow short bed.
billyray50
Dallas
Posted: 08/09/12 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yes full tank, tailgate off, and me at 180lb...
the tc life
colbert wa.
Posted: 08/09/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
hey thanks for the update! i always wonder on some of these posts what happened.
you should have her in tip top shape in no time.
2010 adventurer 810ws
1999 c3500 dually 12' flatbed
THE TC LIFE
billyray50
Dallas
Posted: 08/09/12 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Hope so..will see the total weight tomorrow.We really like the new Adventurer 86 FB. Thanks.
BradW
Mayor of Flat Rock
Posted: 08/09/12 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Lance claimed a "dry weight" on our 9' 10" camper of 2,600 lbs. Ready for a two trip to Yellowstone its about 4,000 lbs. Seems like its about a 90% /10% split between the rear and front axles. If yours is an 8' 6" camper, a higher percentage of weight (>10%) will be carried by the front axle. I would guess it will be more like 25% / 75%.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
woodhog
NS
Posted: 08/09/12 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
These trucks always have something happening in the front end that affects the steering and handling.
They eat ball joints for desert, chop on the universal joints, and use sway bar bushings and end links for tooth picks...
Also they love to destroy their track bar bushings, flex their steering boxes for exercise and grind up their front wheel bearings.
Mine is waiting for its latest meal, 2 juicy front sway bar end links...
If you have the little 5.9 diesel its worse, under designed front end components can't take the strain.
After market people love them...
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow Longbox 200 Watts Solar, LED lights.
12 Volt DC Fridge.
d3500ram
colorado
Posted: 08/09/12 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
woodhog wrote:
...They eat ball joints for desert, chop on the universal joints, and use sway bar bushings and end links for tooth picks...
Also they love to destroy their track bar bushings, flex their steering boxes for exercise and grind up their front wheel bearings...
Yes, it is the cross we must bear to have the best powerplant under the bonnet (LOL)
billyray50
Dallas
Posted: 08/09/12 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
HAHA!!! Great analogy!! But I too Love that 5.9 Cummins Turbo diesel!!
billyray50
Dallas
Posted: 08/09/12 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Good viewpoint Bradw. My model does have the optional comfort step bumper and it also has new foward wet bath that does have different weight distribution. The COG looks good though on my truck.
