RV.Net Open Roads Forum: Class A Motorhomes: GPS mounting
 > GPS mounting
ryanallie1
Magalia, Calif
Posted: 08/16/12 06:14am Link  |  Quote  |  Print  |  Notify Moderator
RognBon wrote:
docj on 08/15/12 09:20pm wrote:
Mine is attached to the driver's side window using the suction cup; that puts it where it is easy to see and program. I installed an additional 12V power port on the left side of the dash so I didn't have a wire strung across in front of the driver.
Same here.
Hi All.
X3. I installed a Multi Power Port, on the drivers side just for the same reasons. It also makes it easy to mount our TST #507 Tire Monitoring System,
It keeps everything tidy and neat, and easy to see. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
Effy
MD
Posted: 08/16/12 06:28am Link  |  Quote  |  Print  |  Notify Moderator
I have the same issue with my RVND. Ended up using Velcro figuring I would clean it with alcohol or gu gone if I ever I decide another approach. The thing that really bothers me about most GPS mounts is that they don’t work. You end up paying another $30 for something to assist the mount. Why don't they just make or provide a mount on the unit that works in the first place? And MH manufacturers know that 99% of us want to mount a GPS somewhere, yet they put finishes that make it all but impossible for a suction mount on any place that you might want to put a GPS.
2012 Thor ACE 29.1
rockhillmanor
On the Road
Posted: 08/16/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
TGarrett wrote:
This was posted earlier. I have several of these, most of them broke. If you have to move it occasionally or sits in the sun a lot it will weaken the arm. The locking mechanism for the phone/gps is shoddy at best. However, I have yet to find a better way to do it. Just be aware that they are fragile and you should be ok.
As a side note due to bouncing they make horrible Iphone dash cam holders when offroading(the stabilizing software will make it look like a bad acid trip).
That was a stock photo. Apparently the 'brand' you bought must have been the problem. I have misused and abused mine for years and it works the same as the day I bought it.
I have had THIS set up, same GPS, Same holder and same mount for over 6 years now!!
Does NOT bounce one iota. The bouncing is THE one thing I could not take with these GPS's in the MH which sent me on my quest for one that did not.
I have bent and twisted that arm a million times for different views depending on what vehicle it is in and the sun and its as rigid as when it was new and the suction cup hasn't come off in 6 years!
And sadly,k yes, over the years I have been lacking on bringing it in out of the sun and it has sat in the Florida sun all day several times.
Just can't say enough about how pleased I am with this set up. Every one I have RV'd with have agreed also and went out and bought one.
Just saying, just sharing a good thing I found for RV'ing.
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
jassrnj
Bath, PA
Posted: 08/16/12 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I used velcro and attached it directly to my dashboard. It doesn't move at all, it is out of the way and in easy reach. I routed the wired to the lighter outlet, used small wire ties, and hooked them to the screws already holding the front plate of the dashboard to the dashboard. Did the same thing to my Tire Pressure Monitor and my ScanGuage.
pkunk
Questa, NM
Posted: 08/16/12 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Fortunately (or unfortunately) I have the old CRT TV in the dash that makes a perfect place for the stock suction cup mount. Out of the sun and can either be on the drivers side or the copilots.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
F1bNorm
Gardena, CA
Posted: 08/16/12 10:28am Link  |  Quote  |  Print  |  Notify Moderator
I suction cupped my GPS to a can of beans and put it in a cup holder. Works fine!
- Norm
F1BNorm
Effy
MD
Posted: 08/16/12 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
- Norm
LOL - That's awesome ! Funny but genious !
CG Dawson
Miamisburg, Ohio USA
Posted: 08/16/12 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
I've used the bean-bag/donut for several years now, works great and I can easily move it from vehicle to vehicle.
Happy RV'ing!!
Greg & Jackie
2003 Bounder, 32W / Ford V10 / 2 Slides
Toad: 2004 Saturn L300, Brake Buddy
rumrunnerxx
Calgary, The Wild West
Posted: 08/16/12 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
I just mounted mine on the side window as well. Works really well and I already had a 12v outlet there. I like the can of beans idea in the cup holder though. That's great.
Bruce Brown
Northern NY
Posted: 08/16/12 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
Same here.
x4
Works great, easy to see, easy to mount.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
 > GPS mounting
