RV.Net Open Roads Forum: General RVing Issues: Refridge Tube ??
 > Refridge Tube ??
MALE*RN*777
Western MD, USA
Posted: 08/17/12 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
I pulled the vent cover off the camper today for the first time and noticed a white tube with a black plug like thing on it which ended by sitting in a small black water catch that had some water in it. Is this the but from the drain catch inside the fridge? I see alot of them coming out of the vented areas on campers. Why is this? Do some have trays and some don't?
03 Ford F150 XLT
Good-bye old friend --- 01 Coleman Sante Fe Pop-up
Hello new friend --- 09 KZ Coyote 23CR Hybrid
Me ,The Wife,The Boy,Girl 1 ,Girl 2
We are Blessed.
mlts22
Austin, Texas
Posted: 08/17/12 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Dometics have this slobber tube, which carries water from a tray under the fins outside, which is of immense help with defrosting.
The downside is that the slobber tube has to be sticking out of the vent, or else the water winds up in the interior and causes rot.
To boot, the tube is very brittle. To keep the insects out and the end cap on, I resorted to using some silvered tape to keep it in place.
skipnchar
Topeka or somewhere else
Posted: 08/17/12 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Poorly routed or broken slobber tubes have caused a LOT of floor damage over the years
Dutch_12078
Great Sacandaga Lake, NY
Posted: 08/17/12 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
The drain tube on my Norcold fridge terminates in a drip pan near the burner where the water evaporates. I've never seen enough water in the pan to worry about it running over.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
pkunk
Questa, NM
Posted: 08/17/12 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
I drilled a hole in the outside floor of the fridge compartment and routed the tube down to drain underneath. Then screened the fridge access door to keep the wasps out.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
Wherever I happen to park
Posted: 08/17/12 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
You have a Norcold,, The ones where it comes out the vent are Dometics.
The theory is the heat of the burner will evaporate the water in the catch basiin.. Hopefully.. On my Dometic they did not subscribe to that theory.
edatlanta
Panama City Beach, FL
Posted: 08/18/12 06:21am Link  |  Quote  |  Print  |  Notify Moderator
I have a Norcold and out of curiosity I just looked to see how much moisture was in the drain cup. We have had 100% humidity here for the past several weeks and this should be a real test to see how this system works. The cup maybe had a teaspoon full of moisture in it. Not completely dry, but very very close to it.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
MALE*RN*777
Western MD, USA
Posted: 08/18/12 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
Valkyriebush
Yuma/Port Townsend
Posted: 08/19/12 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I exteneded my tube to divert drippings out side the compartment. Simply slide it through a vent on the cover. No it doesn't drip on the side of the RV.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
 > Refridge Tube ??
