RV.Net Open Roads Forum: Class A Motorhomes: What battery to hook up to
 > What battery to hook up to
Mody n Domy
Michigan
Posted: 08/18/12 06:49am Link  |  Quote  |  Print  |  Notify Moderator
I just purchased a Toad Charge system. Should I connect it to house batteries or the starter batteries? Or doesn't it make a difference?
2008 Damon Challenger 378 on Workhorse chassis, 2008 HHR panel toad.
accsys
Green Cove Springs, FL
Posted: 08/18/12 07:08am Link  |  Quote  |  Print  |  Notify Moderator
We hooked ours to the house batteries as it was more convenient. The main thing is to hook it batteries that the MH alternator is charging. In our unit, both house and chassis batteries get charged by the alternator so it doesn't make any difference.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
Wherever I happen to park
Posted: 08/18/12 08:42am Link  |  Quote  |  Print  |  Notify Moderator
In your case I do not think it makes a difference.. but starting would be normal.
Page 2: If your Damon is like My Damon, the converter is in the rear, I'd connect to it. Saves on wire that way.
crasster
Dallas
Posted: 08/18/12 10:46am Link  |  Quote  |  Print  |  Notify Moderator
I'd do it from the house batteries to reduce wire run and complication. Also I like to protect the start battery from any possible drains.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
tomousecap
Wherever the Bounder is
Posted: 08/18/12 11:39am Link  |  Quote  |  Print  |  Notify Moderator
I picked ours up at the rear mounted Onan Genny heavy 12V terminal and it works fine. Be sure to fuse both ends, Coach and toad.
Bob
2007 Fleetwood Bounder - Full Paint 35E
Workhorse 6 Speed 496 Cubic Inch V8 - W22
Ford fans - RPM is a poor substitute for Cubic Inches!
2013 Chev Volt - Towing on a Master Tow Dolly
Gracie = Adopted longhair Amazon Chihuahua
Scavenger Power Exh. Installed.
Mody n Domy
Michigan
Posted: 08/18/12 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your input I will hook to house batteries.
bluwtr49
Green Valley, AZ
Posted: 08/18/12 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
I would hook it to the chassis batteries as that is charged by the engine alternator and used when running. Actaully probably makes no differance just seperating running and living functions.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
TJP
Brea Ca
Posted: 08/18/12 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
I would hook it to the chassis batteries with a solenoid.
bluwtr49
Green Valley, AZ
Posted: 08/19/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
That makes the most sense if you need a toad charging wire. Of course the first thing to do is make sure you even need one.
Leewhiz
On the Road
Posted: 08/19/12 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Almost all, if not all, manufacturer's of supplemental breaking systems will state in their manuals to hook up to the chassis batteries. The reasoning behind this is that should have a problem with your charging system, you will get a warning from your coach. You will not get a warning if your house batteries have a problem. And if your house batteries loose their charge then you toad will also not have brakes!
Lee
2008 Tiffin Phaeton QDH
