clucey
Chestermere, AB, Canada
Does anyone have a real world curb weight for a 2006 Chev 3500 DRW ? Either loaded with fuel and family or completely empty. I know these trucks are lighter than the Dodge but want to see how much over i will be with a big toy hauler.
NewsW
US
The gross weight is on the door sticker.
Your best bet for the "loaded" is to go and weigh it.
blt2ski
Kirkland, Wa
It will vary, there are/were three of us with 05 duallys, one empty was 7200, mine at 7300, another at 7600. One a reasonably stripped 2wd, mine a mid level 4wd, the heaviest a leather pkg.
Generally speaking, about 3500-4000 lbs of payload to the gvwr, another 1500 or so until you hit the axel wt ratings.
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
JIMNLIN
out here
Don't assume a scale weight from Joe Smiths same truck will be anywhere close to your trucks actual gross axle weights.
What you need is your trucks seperate front and rear axle weights. That way you know how much pin weight is sitting on the trucks rear axle/tires.
A single scaled gross weight won't give you that info.
As news says its time to weight the rig so you know exactly what your looking at.
'97 Park Avanue 28' 5er 11200 gvwr two slides
clucey
I don't have the truck. It will be over GVW but not quite sure how much. Most likely in the 600-800 lb range. I found a real weight thread and it seems like this truck is in the range of 7300-7500 range empty. Curb is advertised as 6600lbs so i think the 73-7500lb range is reasonable.
KD4UPL
Swoope, VA
My '05 crew cab dually 4 x 4 diesel Chevy has an aluminum flat bed with tool boxes and tools. Like that it weighs 8,500. That makes me think your 7500 range is reasonable. I had a reg cab '07 long bed 4 x 4 diesel that weighed 6,800 full of fuel and a 200 pound driver.
ib516
Up here!
That gen GM 3500DRW GVWR is only 11,400#.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
larry barnhart
wenatchee. wa usa
If the truck is a 4x4 it should be 12000 GVWR because of the E tires. 2wd came with D tires and 11400 GVWR.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
hoopers
Loveland, CO
My chevy 2011 crew cab 4x4, with a full tank and just me (I am under 200 lbs) in the truck weighs 8600 svelte pounds at the scales.
2011 Silverado CC DRW 4x4
2013 Bighorn 3670RL
Texas gulf coast, Colorado, or on the road camping somewhere
vietvet66-67
southeast penna.
I have a 2006 3500 Ext Cab dually DMAX ALLISON:
trailer rate for fifth wheel 16,600
gvwr 11,400
payload aprox 5,169
curb weight aprox 7,000
2006 Chevy 3500 DRW LBZ/ALLY LT2 The "DREAM CATCHER"
1999 Newmar American Star Newmar Kountry Klub #19708
Curt Q20 P-2 Controller Vietnam Veteran 1966-1967
LIFE MEMBER OF THE VFW PROUD MEMBER 335 "DUALLY CLUB"
"GOD, GUTS, AND GUNS KEEP AMERICA FREE"
