RV.Net Open Roads Forum: Tech Issues: Generator will not run Microwave/convection oven
 > Generator will not run Microwave/convection oven
Gene Kautzman
Seattle
Posted: 08/22/12 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
My generator used to run my Microwave/convection oven but now it will not. The two lights dimly blink erratically but that is it. Any suggestions to try? Works fine when plugged in to AC power. Thanks. gk
old guy
Oregon (pronounced Or e gun)
Posted: 08/23/12 12:02am Link  |  Quote  |  Print  |  Notify Moderator
I might ask what elevation you are parked at. only thing that comes to mind is all genny's loose a percentage of power for every 1000 ft up you go.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 08/23/12 03:35am Link  |  Quote  |  Print  |  Notify Moderator
Try plugging it in directly rather than through the system. You may have your inverter running, and hot water heater too? Air conditioner?
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
pulsar
Lewisville, NC
Posted: 08/23/12 05:18am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
Kpackpackkelley
Bryan tx
Posted: 08/23/12 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Give model and serial number on gen experts will help you
Big Katuna
Deland, FL
Posted: 08/23/12 05:39am Link  |  Quote  |  Print  |  Notify Moderator
What kind of genset? If its a Quiet Diesel, you probably have a clogged fuel filter.
My Kharma ran over my Dogma.
dougrainer
Carrolton, Texas
Posted: 08/23/12 06:08am Link  |  Quote  |  Print  |  Notify Moderator
HOW the devil could a fuel filter cause a Voltage problem????? Doug
dougrainer
Carrolton, Texas
Posted: 08/23/12 06:11am Link  |  Quote  |  Print  |  Notify Moderator
You need to check the APU voltage(122 to 132 is spec) AND frequency (60 Htz) The Frequency is critical for some electronic appliances. Depending on the APU, speed governs voltage and Frequency. 1800 RPMs for a gas model. Doug
mikestock
Vestavia Hills, AL, USA
Posted: 08/23/12 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Did I miss something? What brand and capacity generator? If it's a 4kw you have a problem. If it's a 1kw you may have marginal capacity.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
Gene Kautzman
Seattle
Posted: 08/23/12 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for everyone's input. What a great site. My generator is an Onan 5K Emerald Aire with 48 hours on it. After reading the posts I went out and started the generator and the microwave/convection oven worked. We are in Seattle at sea level. when we were traveling we were in the Siskyou mountains at about 3,000 to 4,000 feet altitude. I had nothing else on that would draw any power off the generator. Could altitude make that much of a difference on a 5,000 watt generator? Could it be something else? Is there something else I should check? Thanks everyone for taking the time to respond to my problem. Gk
