RV.Net Open Roads Forum: Fifth-Wheels: Wheel Bearings - Have them checked!
RV.net
 > Wheel Bearings - Have them checked!
Flywaterguide
San Jose, CA
Posted: 09/19/03 10:25am Link  |  Print  |  Notify Moderator
I just brought my 5th wheel in to have the undercarriage checked, brakes looked at, and so on. Got a call from the service department that a wheel bearing had failed. Luckily, it is a Dexter wheel bearing and there is a 5 year warranty, so I won’t have to spend a dime. Bad news is that I won’t have it this weekend.
How often do you folks out there check your wheel bearings? How can you tell if there is a problem?
If you haven’t checked yours in the last year, I’d suggest that you have them looked at.
Best,
Flywaterguide
Flywaterguide
25' Sunnnybrook CKFS(Brookie)
2002 Chevy 2500HD 4x4 (8.1L/Allison/4.10, 45 gal tank, Wester's reprogrammed PCM, Gibson Headers, Flowmaster Cat-back)
My Pics
My Fly Fishing Web Site
fppf
Buffalo, NY, USA
Posted: 09/19/03 10:30am Link  |  Print  |  Notify Moderator
You should be repacking and inspecting your wheel bearings at least once a season or I beleave 6,000 miles.
A good visual inspection goes a long way. Also check to see how much drag there is on the wheel and if there is any play.
1997 International 9800 Flat Floor COE
2004 Fleetwood Terry Quantuim AX6 365FLTS
Trailair Air Ride Pin Box with custom Fab auto ride height leveling
Trailer Wire Convertors:
2 wire to 3 wire
3 wire to 2 wire
larry barnhart
wenatchee. wa usa
Posted: 09/19/03 10:51am Link  |  Print  |  Notify Moderator
this is a reason the no lube axles can be a bad thing. If the bearings aren't checked and greased yearly the brakes might not get a look either. It just depends on the owner.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
Derry
Largo, Florida USA
Posted: 09/19/03 11:04am Link  |  Print  |  Notify Moderator
does anyone have the reason why the fivers need annual bearing repacking,, seems that current technology would offer bearings and lubes allowing more than one year or 6k miles,,
compared to other bearings our fivers are high mntc,,
how often do you redo your front wheels on the tow vehicle,,??
thanks,,
[blue]2005 Ford F350 King Ranch, 6.0, SRW, LB, Crew Cab, 72 Gal fuel, Centramatics,, 1995 Alpenlite 33rk Tea Cup Poodle & Yorkie:) [img]http://img78.photobucket.com/albums/v326/Derry/newtruck.jpg[/img]
Note: Due to invalid formatting, all formatting has been ignored.
texatDurango
North Texas
Posted: 09/19/03 11:29am Link  |  Print  |  Notify Moderator
I repacked the right side bearings last weekend and will repack the left this weekend. My trailer is a little over a year old and has seen a little over 10,000 miles.
When I pulled the bearings, they still looked brand new, and looked like they were packed last week. But I still plan on doing the left side just so I will know they are freshly packed and have been looked at. I figure a few hours repacking them is a lot better than spending several hours or days stranded on a highway during vacation!
Good topic and recommendation, Flywater.
2006 Duramax Diesel 1 ton dually tugging around a 2006 Mobile Suites 36TK3 #2609. Retired and just travelling around now and then seeing the sights.
k1cd/7
Lemmon Vally, Nevada
Posted: 09/19/03 11:35am Link  |  Print  |  Notify Moderator
If you look at the requirements for your tow vehicle you will likely find that bearings on it need attention something like every 30K miles or two years.
Trailers bearings need an annual go-over every year because they tend to sit more and can collect moisture which leads to rust which leads to grit which leads to failure.
Doing an annual bearing job also provides a good opportunity for inspecting and repairing the rest of the running gear, especially brakes.
see bearing maintenance - the photo gallery has some pics of typical rust and a failed bearing.
Bryan
twerner
Midletown, CT
Posted: 09/19/03 11:51am Link  |  Print  |  Notify Moderator
O.K., Dumb(?) question here: Should the bearings be repacked at the end of the season, or before the season starts? Will there be any condensation during the winter months which needs to be addressed?
I always did it in the Fall as a part of my winterizing procedure, but what do the rest of you think?
Ted
Ted & Jan
2002 Arctic Fox 21-5R
2006 Ford F-350 CC, DRW, Diesel
(Overkill we know, but ready for the new FT trailer)
NJ Hillbilly
Flemington, NJ
Posted: 09/19/03 01:53pm Link  |  Print  |  Notify Moderator
I do all my trailer bearings(all 6 trailers' worth) in the spring. I think it's more important to check everything in the Spring to make sure no wires are chewed and no critters made any winter accomodations in the drums.
Granted some may have the valid viewpoint to grease them in the Fall while winterizing so fresh grease and no moisture are present in the winter, but I think there will be a lot of condensation forming during the Spring thaw.
Snow Birds or those that live in warmer climates can do them whenever, as long as they get done annually.
John
'02 GMC K-3500 Crew Cab DuraMax / Allison Banks Monster Exhaust
'03 Montana 3255RL
Honda Eu2000i patiently waiting for it's twin to arrive.
Volunteer Fire Chief
"Without COURAGE, all other virtues lose their meaning"
There is no "Land of the Free" without the "Home of the Brave"
fppf
Buffalo, NY, USA
Posted: 09/19/03 05:13pm Link  |  Print  |  Notify Moderator
I like the spring my self. Get the new grease in there for the most use.
Semi's use a wet system. The hubs hold gear oil and do not need repacking. The do recommend changing the oil every so offten.
Applecore
Austin Mn
Posted: 09/19/03 05:38pm Link  |  Print  |  Notify Moderator
Almost every time I stop, rest stop, campground, fuel stop, etc. I walk around and feel the wheels of the 5er. On hot days they will all be quite warm, but if a bearing is giving trouble, that wheel will be warmer than the others. Nothing is better than preventive maintenance, but in between time, a feel is a good test.
Big SkyMontana 3670RL
Traded 2001 DMax for 2004.5 Chev Duramax 2500HD
Banks Exh., Boost and EGT guages, Airlift air bags
Trailair Pin Box, PullRite Superglide Hitch
Juice installed, 35 gal Aux Fuel Tank
"Yesterday is History, Tomorrow is a Mystery, Today is a Gift"
