zmotorsports wrote: Last February with our new coach we were about 1/2 mile from home just leaving for a weekend shakedown run with the new coach and it died. We coasted to the side of the road and started to troubleshoot. After about an hour and a half of diagnosing and testing I found the wire that goes to the front television lockout was shorted and kept tripping the circuit breaker for the main power soleniod. I unhooked it and off we went. By this time it was pitch black outside and I was frozen, my wife was sitting in the nice warm coach reading a magazine and I asked her if she still wanted to go and she said hell yes we are on vacation(even though I could have thrown a rock and hit our house). So off we went and had an enjoyable weekend. I guess you take the good with the bad. Still wouldn't give up my RV. Mike.
Sounds like my grandmother...we told her we were looking at motorhomes and she said, "You don't want to buy one of those things, they'll nickel and dime you to death."
But when we told her we were buying one (no longer looking) her words turned into, "Will you take me camping with you??"
2008 Itasca Meridian 37H, All. 3000MH (6-auto), Freightliner XC Chass., Cummins 6.7L Turbo, (Sweet! Delivery 03/12/08). Tow: '07 Dodge Gr. Caravan, Me, Him; Sugarbear, Apr. Toy Poodle; Pepe, Blk Toy Poodle; Hero, fat Siam.-mix polydactyl cat/Alarm Clock.
Bev&Dan wrote: WORKHORSE BRAKE FAILURE On February 7/08 we left Lazy Days in Seffner, FL, drove North about 55 miles to our destination - an RV park in Port Richey, FL. We drive a 2004 Pace Arrow 37C towing a Malibu Maxx with a Brake Buddy. A few miles before our destination we started smelling something (smelled like melting plastic to me), wern't sure if it was something outside or coming from the coach. A couple of miles later ABS light came on and brakes went to the floor. We managed to get into the park by pumping brakes. Diagnosis was left rear caliper locked up, causing master cylinder fluid to boil over onto radiator, abs sensor melted, heat caused damage to hoses, pads,wheel bearings, rotors and differential fluids. All was replaced on both rear.
This coach had only 22,000 miles on a Workhorse 22 chassis. Searches on this and other forums show this to be a serious problem and there is an open investigation by NHTSA. If you have had a similar problem, please report it.
I'm curious... have you ever had the wheel positions weighed (4 corners)? Somewhere I read that with ABS brakes the weight distribution of the chassis must be well balanced for the ABS to function properly. If the coach is overloaded or out of balance on one side or the other, I am wondering if that would affect brake function.
For years the tire manufacturers have been blamed for tire malfunction when the culprit was/could have been an overweight axle at a wheel position.
454 chevyengine--Backfired and quit while traveling at 60mph on us90 traveling thru South Carolina.Would not restart.Assumed out of gas(because of offset in tank and gauge readings).Added gas still no start.
Good old boy mechanic replaced ignition control module and we were on our way.
2000 HR Endeavor DP 46000 miles.
Cat 300 HP w/ Allison 6 Speed Tranny.
Problem: Driving along and engine was losing power. Would idle and sometimes get up to full power but would ultimately "chug chug" down the road. Finally made it to a rest stop and got some family to come help me. Chugged it to the nearest diesel mechanic who immediately diagnosed the problem as a fuel separator (filter?). Changed separator and the thing ran like a champ. The mechanic said it is good practice to change the fuel separator once a year under normal driving conditions as diesel fuel is mighty nasty stuff. He also mentioned that when taking off the old filter there was visible trash in and around the filter. I got off luck with a $20 filter and $75 in labor.
1995
Newmar Mountain Aire
21000 miles
Cummins c8.3
Spartan chassis
Problem. Shift lite inop, Tail id lites inop. Found worn broken wires in the harness that connects the instrument panel to the front electrical box. When the left headlite assembly was installed the harness was pushed and pinched against the air fitting on the front air manifold. Travel vibration caused the harness to wear through the harness wrapping and two wires causing the problem. The broken wires were spliced, the harness rewrapped and repositioned.
2003 Winnebago Adventurer on W-22 Workhorse chassis belonging to neighbor:
Tried to start after sitting for two months in an Arizona RV resort.
Nothing!
Found 2 black boxes under the dashboard with "reset fuses" on them. Pushed both reset fuses. Started fine and still starts fine. Had tried many things, don't know what these black boxes are or the reset fuse deal, but for some reason this worked.
Phred42044 wrote: 2000 HR Endeavor DP 46000 miles.
The fuel separator is actually a filter to separate water from the diesel oil fuel...when they get full, the water has to be released, and the filter changed--most engines mfrs. recommend doing this whenever you have an oil change at a minimum, whether it needs it or not--you don't want water in a diesel engine...
Lil Truckr wrote: Unfortunately I have to be a contributor to this thread.
Last August when we were north bound on I-39 somewhere between Bloomington, Ill. and Rockford, Ill. I went over a bump in the road caused by road construction.
All of a sudden my coach had no power. No electrical, no transmission, no engine, no nothing. I managed to coast to the side of the road and their we sat. When I turned my ignitions switch, to attempt to start the coach, nothing happened. I waited a few minutes and tried again and it started only to stop running again. I then went and looked into the battery compartment to see if maybe a battery had came loose and was shorting out against something but they were okay.
I then went back and attempted to start the coach and it started right up. It kept running so we headed out and made it back to Stevens Point, Wisconsin without further incident.
I took the coach up to my dealer who looked the coach over from front to back but they couldn't find a thing wrong with it. So, somewhere in my coach I have a problem waiting to jump out and bite me and there's nothing I can do to prevent it. Scary ain't it.
I also had a similar problem, Started my coach to warm it up before a trip. After 3 or 4 min, it shut down no power to any engine or fuse panel. Coach batteries were OK so tried to jump it with no luck. Then I got my volt meter out, Should have done that first but it was in my other truck at home. Anyway found a dead short in + cable to ground. Traced out wire and found underside of coach most wires and hoses run on frame members but on my 95 Vectra the positive wire from the inverter to the batteries j block is run on the bottom of the floor panel with 2 1/4" screws clips that came loose after hitting a bump in the road the previous day . Here is the kicker it was laying on the drive shaft, so while I was moving it would bounce on and of but when I put it up the night before, it welded itself to the drive shaft, DEAD SHORT. So I lost the engine battery but it could have been worst. If I had moved the coach it would have riped the cable out of the inverter. I will have to get a longer cable to run along the frame members the way it should have been done at the factory but for now I installed new clips and more of them
RV particulars:
Driveline (Engine, Transmission): Cummins 275 hp, Allison 6 speed
Miles: various
Year:1997 Fleetwood discovery
Break Down Description: I had several fuel lines break on my old Discovery over a 4 year period. Finally, in El Paso, tx one night, a young hispanic mechanic, who spoke no english, was able to show me that the engine was missing the brackets/clamps that held the fuel lines on the engine so the engine vibration wouldn't break the lines. There should have been several brackets, and all were missing. Four years of grief, with 28 warranty claims on the engine for broken lines or related issues, like fuel damaged gaskets, oil seals, fuel soaked turbo sensor, etc.
Effect: much disgust...
Cause: poor engine assembly/mechanic error.
Outcome: After four years, problem was solved with the fuel line clamps.
Coach: 1998 Country Coach Magna w/ DD Series 40 engine
Date: May 2008
Problem: Engine lost power and began to smoke very badly. Smoke was white. Engine continued to run at idle but had no power. Any increase in RPM generated hugh volumes of smoke.
Resolution: Had coach towed to local diesel engine facility. They diagnosed problem as failed turbo. Replaced turbo, replaced all injectors and changed oil and filter. Problem resolved but at major cost.
Cause: Coach sat for extended time in early 2000,s and turbo was evidently rusted from lack of use. I purchased vehicle in 2005 and had driven it regularly since then for 15K miles. Failure happened at 47K miles.
