RV.Net Open Roads Forum: How many of us are there? Owners of Dodge based RV's?
 > How many of us are there? Owners of Dodge based RV's?
Page of 306
Kendas
Tucson AZ
Posted: 09/23/08 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Doug in CA wrote:
My 76 Dodge "Concoure" has 2 drain valves. The forward most being the grey water and the rear one black water. I have the operating instructions for it if you think it will help.
Mine has two tanks and two valves... When I originally got the RV they were separate but they face each other. The 3" (black) had a swivel elbow on the end and the 1.5" (grey) ended at the gate valve. It is still legal to dump grey water in NFs as long as you don't dump within 200ft of any body water so I ass/u/me that one of the POs changed the grey valve and just did not put an end on it. I ordered the 3"-1.5" "Y" valve assembly from PPL and added some black ABS pipe to the grey line so the two now connect.
Ken
* This post was edited 09/23/08 10:11pm by Kendas *
1978 21ft Tioga Dodge 440 Motor,
4.5kw Generac and 80 watts Solar
1984 Goldwing Interstate (Daily driver)
Misc Things I've done to my RV pictures
USAF Retired
To Err is human... To Forgive is not SAC Policy.
goreds2
OH H ..... EYE OH
Posted: 09/23/08 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
ALnCORY wrote:
I have a uni-tank as well... I think alot of these older smaller C's have one tank...
I don't think my 1976 Dodge Sportsman has a gauge where you can tell how much water is in the holding tank etc. If this is the case, how do I tell when the waste water level is sufficent enough to dump. I have heard you should wait until it is 2/3 full before dumping.
Sorry for all the questions. Thanks,
1976 Dodge Sportsman/Travel Mate (16 Ft.)
Purchased 9/11/2008 for $1800
Came with an external Champion 3500 Generator
* See picture of this SHORTY in my profile
XM Satellite Radio since 12/25/2004
Opie and Anthony on XM202
XM Cross Country Petition
Griff in Fairbanks
Alaska
Posted: 09/24/08 12:42am Link  |  Quote  |  Print  |  Notify Moderator
Look in the toilet -- virtually all are mounted above the black water tank and empty directly into the tank.
And, yes, you should wait until the black water tank is over half full before emptying ... 2/3 to 3/4 full is best. Even when you're in a full service campsite with plumbing hookups, you should keep the black water valve closed until the tank is at least half full.
No need to say "sorry" ... all of us have had questions that were answered by others and we're just passing on the favor; in time, it'll be your turn to answer other's questions.
1970 Explorer Class A on a 1969 Dodge M300 chassis with 318 cu. in. (split year)
1972 Executive Class A on a Dodge M375 chassis with 413 cu. in.
1973 Explorer Class A on a Dodge RM350 (R4) chassis ... no engine or tranny (yet)
ALnCORY
Idaho
Posted: 09/24/08 08:40am Link  |  Quote  |  Print  |  Notify Moderator
goreds,
Yeah don't worry about asking lots of questions, I am still asking lots of questions because I haven't figured it all out yet either. My rig doesn't have a guage for waste tanks either, but like griff said the toilet connects directly to the top of the tank.
I don't think anyones dying statement ever contained the words "I wish I had spent more time in the office", so lets go somewhere!
Old & Slow
Posted: 09/24/08 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
I just looked at my 78 Tioga tank set-up. No way to tell if PO did a mod. The two tanks have seperate read outs on the panel. Two cut off valves, one for each tank before the main outlet. I think 78 was perhaps a large advance year. I had no knowledge of these things before buying. Just got lucky. The 200' rule is also new to me. I think most folks dump gray water (shouldn't say this) at night. This is what I notice in State Parks.
Floyd
ALnCORY
Idaho
Posted: 09/24/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Question: I need to rebuild a cargo door. I have all the framing, I just need something to build the door out of. Any ideas for something that would be solid and water-proof. Its the door where my coach batteries go and where I assume a gen-set would be if I had one. I think the framing would allow for about 3/8" thickness or so. I haven't found anything at the building stores that I thought would work... plywood and paint just doesn't sound like a good idea and I can't think of anything else... anyone out there ever done this?
thanks.... Al
79powerwagon
S.E. Wisconsin
Posted: 09/24/08 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Fiberglass laminated plywood. Call a local case company (one that builds ATA type shipping cases, there are 1000's of them out there) and buy a remnant.
That's what I used!
She ain't purdy, but at least she's slow!
TreeSeeker
San Diego
Posted: 09/24/08 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
RE: Replacing house window weatherstripping
Has anyone replaced the house window weatherstripping? It is called "Pile Weatherstrip for Jolousie Windows." Mine is completely falling apart. I found a source for it here:
Vintage Trailer Supply
There are two sizes listed and the above one fits my 79 Fleetwood Jamboree (I just received it and checked). However, it does require removing the entire window frame from the RV and then dismantling the frame to get the sliding window out. It appears that in doing this you will also have to remove, or at least partially remove, the fixed window. I fear that removing the fixed window will damage the very old rubber seal and that I will end up having to replace that too. This is turning into a lot more work than I anticipated.
Has anyone done this before? Did you have to replace the rubber seal also? How hard was it, and would to attempt it if you had to do it now knowing what you learned? Where can I get the rubber seal and how expensive is it?
Jer&Ger
Kuna, ID.
Posted: 09/24/08 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
thanks.... Al
Al, go to a sheet metal shop and have them make one out of maybe 18 guage metal. They can cut and form to size. Should be pretty reasonable and will last forever, also make for easy mounting of hinges and so forth.....Jerry
1977 Brougham 22' Class C / Dodge MB400 chassis / 360 engine
DW - Gerry DH - Jerry
Pets, 3 yr. old Flat Coat Retriever (black), 2 yr. Lab mix (black),
9 mo. old min. Schnauzer (silver/grey)
ALnCORY
Idaho
Posted: 09/25/08 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Thanks powerwagon and jerry.... both good suggestions.
Page of 306
