Leeann
Maryland
Also, the exhaust manifolds are known to warp a little and the gaskets do fail - check that, too.
'73 Concord 20' Class A w/Dodge 440 - see profile for photo
ALnCORY
Idaho
If the manifold is warped will a new gasket cure that or will I need a new manifold?
next question: my blinkers work fine unless the headlights are on then the blinkers don't work... brake lights do but not the blinks.... any ideas on where to start looking for that problem. I just discovered that one the other night.
I don't think anyones dying statement ever contained the words "I wish I had spent more time in the office", so lets go somewhere!
79powerwagon
S.E. Wisconsin
Al, first try a new set of gaskets, it's cheap insurance. If the manifold is warped, pop it off (no easy task) and have a local machine shop straighten it out. It won't be much money.
Your lights, I'd bet you a hunnert bux it's a ground issue. MAYBE the turnsignal switch, but most likely grounds.
She ain't purdy, but at least she's slow!
Leeann
Maryland
I'm with Eric on this one
Jer&Ger
Kuna, ID.
Al, as you know. I have a 77 Brougham and I had a very similar problem this summer on mine. I started by traceing and checking all my wiring from the rear forward. I redid all the grounds I found. Then under the chassis, about halfway forward, I found where someone had spliced all the wires going to my rear brake, turn signal lights,etc., using butt connectors. I redid all of it with solder connections and all seems good to go now. I did have a small problem with connections under to dash, but I think most was under the chassis....Jerry
1977 Brougham 22' Class C / Dodge MB400 chassis / 360 engine
DW - Gerry DH - Jerry
Pets, 3 yr. old Flat Coat Retriever (black), 2 yr. Lab mix (black),
9 mo. old min. Schnauzer (silver/grey)
goreds2
OH H ..... EYE OH
Last night, I camped out in a farm pasture setting for a birthday party. It was very unlevel where I had to park. Does anyone have any leveling jack suggestions for these older motor homes? Can they be used on dirt/grass?
1976 Dodge Sportsman/Travel Mate (16 Ft.)
Purchased 9/11/2008 for $1800
Came with an external Champion 3500 Generator
* See picture of this SHORTY in my profile
XM Satellite Radio since 12/25/2004
Opie and Anthony on XM202
XM Cross Country Petition
Leeann
Maryland
The best/easiest option is leveling blocks, either purchased at Walmart or Camping World or made by you. We have both - the bf's mom gave us a set of the blocks and our RV came with a ton of boards with angled ends for driving on.
We don't use leveling jacks but we do use regular car jacks for stabilizing the RV once level.
goreds2
OH H ..... EYE OH
Thanks LeeAnn,
Also, I am still trying to figure out how to drain my water system completely on my 1976 motorhome after camping .
Do I drain the water heater first?
After that, do I just drain via the water pump turning on water faucets?
Thanks,
edited 10/13/08 12:54am by goreds2 *
Leeann
Maryland
We pull the drain on the water heater and open the drain on the tank. Then we'll open a line near the pump and blow some compressed air through. Finally, put a little hose through the water heater drain and get a siphon going to get the last little bit out of the heater.
That's worked for us. I'd be careful running your pump until everything's dry - I'm not sure if you can burn up the pump that way.
goreds2
OH H ..... EYE OH
goreds2 wrote: Last night, I camped out in a farm pasture setting for a birthday party. It was very unlevel where I had to park. Does anyone have any leveling jack suggestions for these older motor homes? Can they be used on dirt/grass?
Forgive me for adding to this but I have to mention that the next morning as expected, the pasture grass was dewey and somewhat slick. Suv's etc. were having some trouble turning around getting out of the very sloped unlevel acreage. I had a small audience waiting to see if I could get the motorhome out of there. I was somewhat nervious myself. I put it in first gear as I had to make a sharp turn around to the right going upward. I thought I was stuck for a moment but those rear duel wheels kicked in and I got out of there with no problem at all. I heard the campers cheering in the background as I honked the horn departing.
When I started looking for an older motorhome, I had my heart set on a Toyota chasis. I don't think a Toyota MH would have stood a chance getting out of there. I am very happy with this old Dodge as I know there may be issues in the future as with anything with age. The Dodge 360 motor rules! The campers could not believe I only paid $1800 for it.
Thanks for listening.
(Also, thanks LeeAnn for your previous response to my draining water question.)
