RV.Net Open Roads Forum: Class A Motorhomes: Goodyear G670 RV tires
 > Goodyear G670 RV tires
Page of 6
rjohn91ron
Hanover,Ma
Posted: 04/16/05 07:57am Link  |  Print  |  Notify Moderator
I just returned from a trip south. Before I left I purchased 6 new G670's for my rig as the tires I had on were 7 years old and I did not want to take a chance with tires that old which I knew had to be replaced. Tires cost me $1290 for 6. During this trip I had one blow out (not flat) on the way down and one Blow out on the way back. Dot inicated the tires were made in nov 04. I checked to make sure air pressure was properly inflated and had rig weighted before I left to make sure proper air pressure was in tires. Not very happy with these tires. Wrote goodyear and have had no response. I did have the tires replaced at no charge to me during this trip as I did not want to travel without a spare. Anyone else have problems with the G670's. Should I get rid of them and get something else. Now I have that fear that another blowout is in the future. Should I feel safe using these tires with the experience I just had. One blowout on the dules which was controlable but the other blowout was on the front right and it wasen't easy controling the rig to a stop. Don't know what to do. Any suggestions?
Ron 98 32ft Georgetown
Towing 2001 saturn SL2
Brake buddy assist
4wheel
Walnut Island, Grandy N.C.
Posted: 04/16/05 08:37am Link  |  Print  |  Notify Moderator
I have been across country and back on my
G670's with no problems at all. I have only
had to ajust the air pressure twice in
almost two years.
2003 Bounder 32W
V-10,Steer Safe
Davis Tru Trac
Henderson's Rear Trac-Bar
02 Xterra 4X4 Auto
They say it can't be towed,
but I Toad it anyway,
Aventa II & Brake Buddy
And now, Centramatic
golfman 1
Mount Juliet,Tn.
Posted: 04/16/05 08:51am Link  |  Print  |  Notify Moderator
I've have a lot of miles on mine and have had zero problems.
Roger
2000 Mountain Aire 4093 Double slide DP"the Dreamweaver"
2001 Honda Odyssey
Retired and living life to the max.
See you on the road.
Sully2
Cincinnati
Posted: 04/16/05 08:54am Link  |  Print  |  Notify Moderator
A question if I might? You said you had your tires "properly inflated". Were they at the inflation that the MEASRED WEIGHT indicated them to be...or were they are the MAX pressure that the chart inside your coach says they are to be?
Oh! BTW...what size tires are they?
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
LVJ58
Las Vegas, Nevada
Posted: 04/16/05 09:16am Link  |  Print  |  Notify Moderator
This is the first I've heard of anyone having problems with the G-670's. Could you give us some more details on the blow-outs, what size tires, and was the blowout on the sidewall or tread, also the location of the problem tires, ie., front, rear, inside or outside dual.
Thanks, Jim
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
topflite51
In The Desert of Nevada
Posted: 04/16/05 09:17am Link  |  Print  |  Notify Moderator
Also were these tires the same size that came off? And were they front or rear that blew?
">David
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to fish
Simply Despicable ">
Any errors are a result of CRS.">
dicnic
Boynton Beach, FL
Posted: 04/16/05 09:21am Link  |  Print  |  Notify Moderator
Sumptin' funny here if you only paid $1290.00 for six (6) Goodyear G670s unless they are a teeny tiny size. Everyvody on RV.net has paid a little over 2 grand for 6 22.5 size, the 19.5s are not much cheaper. Perhaps you bought seconds? Or had someone other than a truck tire place mount them? This is the first I have ever heard of ANY problems with these tires. I have 6 and they are great. But, I only need 90 lbs of air in them. Perhaps, as the previous poster asked, they were inflated to the maximum shown on the sidewall?
Sold our 2001 National Tradewinds, might buy a new on someday.
One Bald-Headed Old Guy (me)
One Jewish-American Princess (DW)
Two Birman Cats, Mocha & Coco
I speak three languages: English, Sarcasm & Profanity
Tcloud
Oak Hills Calif
Posted: 04/16/05 09:42am Link  |  Print  |  Notify Moderator
I also had 6 of them put on the Motorhome last Oct. and have had no problems at all. I did order the next weight up from what was on it. I went from an F to a G. The F was rated to match the weights on the spec. sheets for the Motorhome. putting on the G made the weight about 400 lbs more per tire. I always have the Motorhome weight checked before leaveing on a long trip with water propane and fuel tanks full,and I stay with in the weight on the spec. sheets. By going to the G means the tire is rated for more then its carrying. The price from the F to the G was the same.
We just got back from a 10,000 mile trip with not one problem.
Dave
1999 Adventurer 275 Cummins Model 34V
Old Snipe
Full Timer
Posted: 04/16/05 10:05am Link  |  Print  |  Notify Moderator
I have now over 25,000 miles on my Goodyear G670s (19.5s) and have had no issues. I check the tire pressures (cold, in the morning) before each trip and over the last 2 1/2 years have only needed to add air, just a couple of PSI, twice. I run 5 PSI higher on each tire than the coach plate says, just a little extra insurance. I can't tell any difference in ride quality at the slightly higher pressure. My rig is not overweight and I drive around 62-65 mph on the open highway. I am sorry to hear you've had so much trouble when you endeavored to prevent tire problems. Could it be a faulty installation or bad valve stems causing the problems? Have the replacement tires had any further problems? We'd love to hear the outcome of this unusual problem.
Best Regards!
Paul D
2007 Winnebago Journey 39K, Cat C7 350 HP
(aka "R SANITY")
2003 Honda Element 4WD Toad
www.rsanityrvtravels.blogspot.com
Milo006
Alcalde, NM
Posted: 04/16/05 03:34pm Link  |  Print  |  Notify Moderator
Try this site for inflation information tires on your G670s.
Milo and Di
2004 Georgetown XL 370
Ford V-10
2005 Chevy Colorado 4x4 Crew Cab towed vehicle
Page of 6
