Keystone Outback has several models that could suit you. See my signature below, I have 4 bunks, sofa slide and a queen slide towed by a Ram 1500 (note that you do need to have the 1500 set up correctly to tow a trailer of this size).
Go to Outback Owners forumYou can ask a lot of questions from owner that have the combination type you are looking at.
We purchased a Starcraft Homestead 285rsqb. We love it. Traded in our other trailer after only 7 months. With 2 girls , friends , and cousins, it became apparent that wew needed an upgrade. Plenty of room and exceptional workmanship inside and out .. Good luck
38 yr old surfer/ truck driver
wife.. 2 girls..6 / 15
97 GMC 1500 suburban
2005 Homestead Settler 285RSQB
1994 ford explorer
9 surfboardshttp://community.webshots.com/user/gfyfoot24
I have a Dodge Ram QC 1500 Hemi, tow package 3.92 gears and tow a Forest River Cherokee lite 23dd. He is the manufacture stats for the 23dd. It has a queen up forward, full kitchen, a dbl bunk wiff twin over and the dinette ofcourse turns into a bed. No couch area though.
The manufacturer stats on the camper :
ID 18
Model 23DD
Hitch Weight 600 lbs.
Axle Weight 3,610 lbs.
Ship Weight 4,210 lbs.
GVWR 7,600 lbs.
Length Exterior 26' 5"
Exterior Height w/AC 10 ft. 3 in.
Bedrm Interior Height 76 in.
Furn BTU 20,000
Gray Cap 27 gal.
Black Cap 32 gal.
Fresh Cap 50 gal.
Awning Size 15 ft
The Camper Tag :
gvwr 7370
uvw 5090
ccc 1974
lpgas 9.75 x 4.2 41
water 32 x 8.3 266
My Ram and the Camper weighed in at a GCW of a rounded 10200. Did add a Tru-cool max tranny cooler (2 aftermarket and manufacturers). Us Reese WD hitch and Dual Cam sway. Pulls very nicely. Down side. The truck is a bit over GVWR, ~200 lbs with the five of us loaded, fuel and hitch weight. So what I do is take off the tailgate and put the truck spare in the camper.
Regards
Chris
08 Keystone Passport 280BH
09 Dodge Ram Quad cab 2500 ST 4X4 6.7L/3.73:1
I pull a 2004 timberlodge 27 bhs with a table slide with 1/2 ton Suburban. The wieght in 6000 lb. I it has a front bedroom and three bunks. I try not to fill the water till I get to the campground due to the weight. Of course it would pull a lot better with a F250
Rockwood 8318SS, best floorplan out there today! We love ours! Two slides, one on each side! Best thing is that the trailer only weight #6500 dry! We pull with our F150, no problem! Check them out, they are great! $18,5K brand new, fully loaded 2005 model!
