RV.Net Open Roads Forum: LP on for fridge going down the road,
 > LP on for fridge going down the road,
77Casual
Berlin Wi
Posted: 05/11/05 05:48pm Link  |  Print  |  Notify Moderator
When we are on the road I have the fridge running on gas and somtimes the water heater is going to. I have been told that the LP should be off and line unhooked on the road to be safe. What are some of your opinions on this? The fridge has 12 volt but it don't work so I use the gas on the road and plug it in when sitting in the yard so we don't have to unload and load the fridge all the time. It is also a good place to hide during the day to watch TV or take a nap lol. Tom
We have a 84 27ft Midas Kingston, a E350 Ford with 460 and a C6.
2oldman
WA
Posted: 05/11/05 05:54pm Link  |  Print  |  Notify Moderator
I just did a quick search for 'refer on gas' and found these topics, some of which may be of interest:
refer on gas search
fizikpal
East Northport NY USA
Posted: 05/11/05 06:01pm Link  |  Print  |  Notify Moderator
I have left the gas on for the fridge whenever we went from one spot to another.
I never left the furnace or the hot water heater going though.
no problems
tom
The Lynch's
2002 Shasta Cheyenne 308
TOAD: 2003 Honda Civic
Sterling Tow Bar with Brake Buddy
Wizzard_of_Odds
Northern Lower Michigan
Posted: 05/11/05 06:03pm Link  |  Print  |  Notify Moderator
I run my refer and water heater on LP while I'm in route, but I turn off the LP at the tank when I stop to refuel.
I know many others who do the same, and haven't had any problems. I wouldn't dare say that it's 100% safe, but if you're careful and always trun it off prior to refueling you'll have eliminated the biggest risk.
...Wiz
* This post was edited 08/08/05 10:08pm by Wizzard_of_Odds *
1994 Jayco 23' E350 7.5
Thorley headers, Intellipower 9160, Bilsteins, Brembo brakes, K&N filters, Mobil 1, Satellite TV & Internet & WAP, MP3-CD, Generac 5KW, Kipor KGE3500TI, Honda EZ2500
2005 Four Winns Horizon 190 (fully loaded)
Dixie Col
Palm Harbor, Florida
Posted: 05/11/05 06:22pm Link  |  Print  |  Notify Moderator
Tom,
My wife and I have always run our refrigerator on LP while we are on the road since we started RV'ing in a pop-up in 1987, and have never had any type of problem whatsoever with doing so. I generally have the hot water heater on only when we are parked. As a matter of fact, I generally turn the hot water heater on about 30-45 minutes before I need it (bathing, dishwashing, etc.), and leave it off the rest of the time.
Dixie Col
HiTech
SE Michigan
Posted: 05/11/05 06:55pm Link  |  Print  |  Notify Moderator
Whatever you do, don't turn OFF the LP at the tank to refuel, while leaving the LP gas appliances powered up. They will run the electronic spark igniter.
Jim
2002 Gulfstream Conquest Class C
Rolling wired and wireless network
77Casual
Berlin Wi
I only have the water heater on if we are going somewhere real close by to stay, One less thing to do when we get there. I don't really see anything wrong with having the gas going on the road. Only problem would be if it was in a bad crash or something and broke a gas line, that wouldn't be to cool. Tom
Wizzard_of_Odds
Posted: 05/11/05 06:58pm Link  |  Print  |  Notify Moderator
Jim
I should have definately been more clear.
I turn off all of the appliances, and then I turn off the gas at the tank.
Thanks for catching that HiTech.
...Wiz
DavidG
near Seattle, Washington, USA
Posted: 05/11/05 09:19pm Link  |  Print  |  Notify Moderator
I think this is about the fourth or fifth post this month alone on this topic. If you do a search, you’ll have plenty of reading to do. My opinion, if you prep the fridge before putting already chilled items in it and it’s the last thing that gets turned off before you hit the road, the food and the fridge will stay cold enough until you get to your destination and can plug back in and you don’t need to worry about running with the propane on.
David and Laura G
Click here for RV Towing Tips and more
2003 Suburban K2500LT 4WD, 8.1L, 3.73, Autoride 14-16 mpg hwy, 10-12 city, 8 towing
2008 Adirondack 31RL
Prodigy brake controller, Surge Guard
Old Retired Coastie
Washington state
Posted: 05/11/05 09:28pm Link  |  Print  |  Notify Moderator
If you are concerned about forgetting to turn off the propane at the refrigerator or water heater when you refuel, you can install a device called Flaimout that does it automatically. I just put one in and it is fairly straight forward. It will work with a TT or M/H. I have no ties to the company other than as a customer.
Flaimout
Dave and Jan
Zoey the mutt
2005 Born Free Built for Two
2001 VW Cabrio
If you keep doing what you did, you're going to get what you got!
