Too_Tall_Ford
Reno, NV
test
last
edited 03/11/08 12:59pm by an administrator/moderator *
View edit history
2000 F350 DRW 4wd CC 7.3l PSD
37" Tires w/ 5.13's
Suncoast 4R100
2007 Host Yellowstone
Democracy is 2 foxes and a sheep deciding on what to have for lunch, liberty is a well armed sheep contesting the vote.
pulsar
Lewisville, NC
Too_Tall_Ford
I removed the width and height parameters from you picture specifications, to return it to the original size.
One should only use one of the two parametes. The forum's display engine will use only the first one it sees and adjust the other dimentsion to keep the two dimensions proportional.
If the picture is already smaller than the forum's recommended maximum size, there is no need to use any size parameters; the picture will be displayed as its acutal size when the size parameters are left blank. (Note: the recommended maximums are: width = 640 pixels, height = 480 pixels.)
Your use of the parameters reversed that actual sizes. Your original picture is 500 X 331. The first number is width, the second number is height. You entered parameters of height=500 and width=331. That is why the picture was blown up, changing height from 331 to 500 and scalling the width proportionally.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
refloyd
Baqubah Iraq
Test
Wonderful/Beautiful Wife (25 Years this coming Nov 2008)
Four awesome children
Wannabe 5th Wheeler
PrivatePilot
Courtice, Ontario, Canada
Test
30' Keystone Cougar 5'er, Triple Bunkhouse, SuperSlide.
Chevy 3500 1 Ton long box crew cab dually
6.5 Turbo Diesel, 4.11 Rears, LSD
Miles towed in 2008: 12,900 Kilometers, 7990 Miles
Checkout my blogs, adventures, and more here!
Mark
d schmincke
Manchester md
d schmincke
Manchester md
it worked
Camper_Jeff_+_Kelli
Seattle
Winter camping in Levenworth WA for the Christmas Tree Lighting Festival. 15 Degrees Farenheit that night.
Had just completed a winterization project adding 1" pink foam board insulation on exterior sides and under the wings over the sides of the truck bed walls. Also removed stove to install insulation board on entire inside of left wall under countertops and installed foam tube pipe insulation on all water lines. Worked great. Inside of camper was considerably warmer than trip two weeks before to Oregon coast. Stayed 70 degrees inside easily. RV park was nice. We plan to return in the summer but will most likely need reservations then.
Concludes this test of a first posting attempt.
JB
Shendoh
Baltimore
LisaCSCO wrote:
I hope this works, feel free to adjust this or send some words of help on posting pics.
Lisa
Lisa '67
(Sister of 2 State Troopers, Don't mess with me )
my DH Doug '67
Doug, can you tell me in what one/two states your DW's brothers work?
Steve
Shendoh
Shendoh
Baltimore
pulsar wrote: garmp1,
Your two attempts at posting pictures failed because the URL was a URL to a page of pictures instead of the direct URL to one picture.
I chose one of the pictures on that page. By using right-click and selecting properties, I was able to copy this URL, http://farm3.static.flickr.com/2260/2302272931_4409c201c1_m.jpg
Pasting that URL into the message window's image tool,  , I get this picture.
Tom
I don't care what you say....That's a nice piece of pork there!
Shendoh
Eurocamper
Salt Lake City, Utah
Testing posting of pictures.
Moderator's edit: Reduced the width of the picture to the forum's recommended maximum of 640 pixels.
edited 04/06/08 06:03pm by an administrator/moderator *
2008 Fleetwood Evolution E1
2007 Nissan Xterra
1992 Isuzu Trooper
Ex 1997 Volkswagen Eurovan Camper
