Jayshack185
Midwest
This is a test. I hope it works!
edited 10/12/08 06:19pm by Jayshack185 *
2002 GMC Envoy
Prodigy Brake Control
Equalizer Hitch
2005 JayFeather 165M Sport
Myself & 18 year old DS in College
Wife and DD, they don't Camp (their loss)
GO CUBS, THIS IS THE YEAR!!
Jayshack185
Midwest
Try this again.
edited 10/12/08 06:06pm by Jayshack185 *
2002 GMC Envoy
Equalizer Hitch
pulsar
Lewisville, NC
Jayshack185,
Webshots is a little more technical to use than some of the host sites. Here are some pointers.
When using the size praramters, use only one of them - generally use the width. In one of your posts you use "height = 640 and width = 480" The display engine will only look at the first one it sees.
Note: The forum's recommended maximums are width = 640 and height = 480
Webshots is not my choice of websites, but here is a post on how to use webshots as of last march.
I find TinyPic.Com must easier to use. You may be interested in
Posting Pictures Using TinyPic.Com For The Host Site
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
ValkSmile
Cincinnati Ohio
This is a test
last
edited 10/16/08 08:43am by ValkSmile *
View edit history
2006 Dodge 2500 CTD 4x4 Quad Cab
2009 WildWood XL 286FBSRV
1999 Custom Valkyrie
pulsar
Lewisville, NC
ValkSmile,
Your second attempt failed because you used a URL for a page that contains the picture instead of a URL to the picture itself. On the lower-right side of the page, select the IMG Code and paste it into a post.
Tom
dixietrain
St Augustine, FL
test. http://picasaweb.google.com/dixietrain99/Chixie#5257908450450352658
Summer and George Williams
1999 Tradewinds
Towing 2001 Turbo Beetle 5sp
dixietrain
St Augustine, FL
Test again.
1999 Tradewinds
pulsar
Lewisville, NC
dixietrain,
It appears that you are posting a URL to a page that contains a picture, not to the picture itself.
I don't use Picasa, so I'm not sure of the Picasa way of doing things.
I right-clicked on the picture (on the page your URL leads to). I selected properties and then copied the URL and use the message window's Image tool, to get this.
I can see the picture, but I don't know if others can. (I went to the page and could have recieved a cookie that lets me see it.)
Tom
campguy3040
midwest
test
last
edited 10/26/08 01:58am by an administrator/moderator *
View edit history
2005 Silverado 2500HD,D/A 4X4 crew cab 2LT
2005 Terry Quantum, 33ft double slide TT
Second RV: 2008 Palomino Maverick M-8801 TC
TorkLifts and FastGuns, Ride Rites, EU2000i
pulsar
Lewisville, NC
campguy3040,
I corrected the size parameters for your picture. You had height=640 and width=480. The recommended maximums are width=640 and height=480. Since your picture was already 640 by 480, I simply removed both parameters - they can be left blank.
Even though you had the heigth parameter larger than the width, you may have noticed that your picture was wider. That is because the display engine uses only the first parameter it sees, height in your case, and adjusts the second to keep the two in proportion. Thus, if you need to adjust the dimensions of the picture, only use one parameter, usually the width.
Tom
