I have read on our site that using a Mr Clean Magic eraser works wonders for cleaning the awning. My question is how do you get at the top of the awning both inside and out? Any help would be greatly appreciated.
To clean the outside disconnect the arms from the camper at the bottom and let the awning hang down against the rv. Then use an extended brush that the water runs through.
On the bottom side I have found the best way is to spray it heavy with cleaner then roll it up and let it set for about an hour then open it and it should come clean pretty easy.
Extend the awning then disconnect the support legs from the latches at the bottom and ease them under the TT. This will allow the fabric to hang like a sheet on the line.
2001 Ford E-350SD 6.8L V-10
707 Executive Conversion
Superchip 1715 Max Micro Tuner
K&N Cold Air Intake
Alpine Navigation System
2004 Fleetwood Pioneer 30TSB8
