well its going to be here and we can take delivery next wednesday and I can't wait. We are taking delivery of an 06 Allegro Bus and I am concerned about a PDI list, does any one have any suggestions on alist that is all inclusive?
Stuart & Zoe Ann
Carly & Dana (teenagers)
2 Pugs
2006 Allegro Bus
Jetta toad
I found this in a search try sending him a message.
-Russ Ritenour
All,
I have a very detailed PDI list for factory pick of diesels and also another list for used (D or G)units. If interested pls PM me, give me your URL and which list you want.
RR
Stuart,
Congrats on your purchase! I know you must be excited to get it and get to the places you have been dreaming about. But...you have a big investment and right now is an important time to be VERY practical.
Copy this list, modify it to suit your rig, send an advance copy to the dealer or factory rep to let him know that you know what you are doing and then do a complete PDI - PRE-Delivery Inspection. In other words, don't make the deal complete until AFTER the PDI is satisfactory! It will save A LOT of possible future grief. If you have not done a PDI before (a PDI is sort of like getting married to your rig), then here is a list you may find helpful.
Below is one I found somewhere on the Internet when I was getting my MOHO. It's long, but it worked for me - you will need to modify as appropriate for your rig. Print it and keep it for future reference.
Here is an extensive PDI for you. Takes quite a while to complete but is well worth the time.
RV PDI
1. STARTING POINT - A flashlight with a strong beam is a very useful tool to have. A screwdriver with a straight, Philips and square bits will come in handy as well. You should also have available the delivery invoice for the RV. It will show all the standard equipment and ordered options and should be compared to what you thought you ordered and should be referred to during your inspection. Pictures from the glossy brochure will also help in your inspection.
Make a list of anything you find wrong, needing adjustment or unacceptable. This will serve an important role when you go to discuss the next step with the dealer's salesperson.
You will need the understanding & cooperation of your dealer for this process, as it probably involves far more depth & detail than they normally anticipate and schedule for. Make sure they know about it in advance & try to schedule your visit to allow enough time to perform your inspection & actually get some things fixed (if necessary). You may get a better prepared rig if the dealer understands your intentions. At the very least, tell the person doing the “owner inspection” or “walk through” what you intend to do, give him or her a copy of this checklist and work with them to plan the time accordingly. A sense of humor will also come in handy!
Finally, my assumption for this PDI is that both (if fitted) propane tanks are full, shore power is available, city water and a hose are located close by and sewer connections, a drain or a dump station is available. A fully charged battery must be connected as well.
OUTSIDE WALK AROUND - The outside walk around should take around one hour. At this point, you're generally searching for anything that does not look right
2. Roof Sealing & Fixtures - You will need to get up on the roof here, so round up a ladder or carefully inspect the one on the back of the unit if you are going to use it. Check that all the mounting points are solidly attached to the body and the rungs are firmly fixed to the frame. Climb on the roof and inspect all seams, gaskets and any other place that the roof material has been cut or holes drilled. Check that all shrouds & covers are intact, unbroken and properly seated on the roof. Proper polyurethane caulking should have been used to seal all places where the roof has been penetrated. Check closely around air conditioners, vents, antennas, sewer vents, and side seams. Look for any signs of bubbles (large and small), delamination, foreign objects or protruding screw or nail heads under the membrane (if a rubber roof).
3. Windows - Check closely around each window to make sure it has been properly aligned and sealed. A gap between the trim ring & the window frame is acceptable, but it should be nearly even all the way around the window.
4. Entry Doors - Check the gasket used on all doors for proper adhesive and coverage. Look closely at the door from the inside and confirm that it sits flush against the inside of the doorjamb. Confirm that each key works in the appropriate lock. The main door should open & close smoothly and lock with out undue effort. Check that the screen door opens smoothly alone and locks to the main door without any extra effort.
5. Baggage Compartments - Open and close each door checking for alignment & gasketing. Confirm that each key works in the appropriate lock. All hinges should be tight and secure and the latches should hold the door tightly closed and still be easy to open. Feel the floor or carpeting and look for any signs of moisture that might indicate rain leakage. Verify that compartment lighting (if fitted) works properly. Any gas cylinders used for keeping the door open should be properly installed so as not to interfere with items stored in the compartment. If clamp type door hold-opens are used, make sure they are present and hold the door correctly.
6. Sewer & Fresh Water Connections - Inspect this area on the trailer to make sure that nothing is broken or deformed. If appropriate at this time, make certain you understand how each valve or fitting works. Understand the proper function of the black and gray water valves. If tank flushing is installed, understand how it operates. Understand where the low point drains are for the fresh water system.
7. Telephone & Cable TV Connections - Find and understand the telephone and cable connections. Make sure a weather cap is present for each connector and that connectors are properly identified & mounting plates are properly sealed.
8. Propane - If the tank(s) are contained in a compartment, there should be no possible way for propane to enter into the RV or any other compartment. Understand how the regulator works and how it switches between cylinders. Confirm that a leak test has been performed on both pigtails between the tanks and regulator and the rest of the system. Locate and understand the operation of the main shut off valve (if any).
9. Battery - Check the battery box to verify that it is ventilated and that any compartment slide mechanisms work properly. Verify that no battery cables are rubbing on any part of the frame because that will eventually end up with a short circuit and possible fire. Understand the battery type provided and how to maintain them.
10. Paint & Siding - Carefully check the paint finish on the RV. Any problems can be verified and corrected at this point with a lot less hassle. Site down the side of the unit to check for bumps or depressions in the siding. Divide each side of the unit into 2, 3 or 4 sections and inspect for siding issues: color variations, dents or irregularities. Do the same for the ends of the unit look at places where vinyl film is used for graphics to make sure it is free of any air bubbles? Check ends of any decals for uniformity or “mistakes” that may have gouged the siding. Look closely where masking tape was used for paint graphics to make sure there is no over spray. Carefully check for surface smoothness and any place when paint coverage is marginal or where there are bubbles.
11. Tires and Wheels - Closely inspect the tires and wheels and understand the proper inflation pressure. Verify the torque of the lug nuts or have the PDI person do it while you watch. Find out the proper jacking point for the trailer and what kind of jack to use. Determine if your tow vehicle lug nut wrench will fit the lug nuts on the trailer or if another size is necessary.
12. Spare Tire - Check the condition & pressure of the spare tire. Understand how the carrier works if it is the fold down type.
13. Awnings - Extend and retract each awning paying particular attention to how the awning is locked in the retracted position. Make sure all springs, locks and supports work well and are properly aligned. Wiggle the mounting points for the support arms to get a feeling for how solidly they are mounted to the body.
14. Chassis Inspection - Put on some old clothes or coveralls and get a good sized piece of cardboard or carpet to make it easier to lie on you back while checking around under the trailer. If it's possible to do so without jacking up the rig, it's a lot easier, but do what makes sense to you? You want to be able to Inspect all air and / or hydraulic lines, electrical wiring, shock absorber attachments, and in general every place that a wire or pipe could rub against something that could cause a problem later. All wiring and piping should be properly fastened.
15. Slide Out Operation - If your RV includes a slide-out or slide-outs then spend the time it takes to understand their operation. Start by checking the seals while the slide is retracted. You should not be able to find any places where you can see light or detect airflow. Use a flashlight to look into dark corners. Understand the mechanism that extends and retracts the slide. Operate it several times and understand any restrictions on operation. Understand the manual retraction process and actually perform the retraction as if the automatic mechanism had failed. Look for proper alignment of any wheels that may ride on carpet or other flooring, to insure proper clearance. Confirm that no screws or bolts are cutting into the carpeting during operation. Understand any locking mechanisms that are used to hold the top of the slide out tight against the top of the RV. Do your best to make sure the seals are properly installed and operational when the slide is retracted and also when it is extended. Check the area under the slide for proper routing of wires or cables. Confirm that nothing rubs on the tires (parts of the slide, wiring, insulation, Etc.) when the slide is retracted.
INSIDE FIT AND FINISH - Now its time to go inside. In general you are looking for things that are not finished correctly since it is really too late to inspect the design of anything.
16. Cabinets - Inspect & open all of the cabinets to insure that all the hinges and latches work well. Pull each drawer out to its stop, return it closed and then try to open it like road vibration might do. Makes sure that there have been no water leaks and that all the wiring and pipes are well fastened. Inspect the linings (if any), to insure they are fastened securely. Run your hand along all edges, front & back to check for and delamination or loose edges on molding or vinyl wraps (you may want to wear gloves for this part)
17. Molding & trim - Go over all the trim on walls, doors & furniture. Make sure that everything is fastened on well and not loose or ready to come off. Check that no nail heads or staples are protruding.
18. Lighting - Operate every light switch and observe its function. Use the monitor panel to check battery levels. Understand and verify any battery disconnect switches. (At this point, only 12V lighting can be tested, as the unit is NOT connected to shore power yet)
19. Closets - Open and close all closet doors checking for free operation and proper alignment. Hanger rods should be properly fastened and secure. Check out any lighting that is provided and any switches that are used.
20. Furniture - Examine every piece of furniture to check for construction, upholstery, pattern and cloth matching. Check out the dinette by making it a bed with the appropriate cushions. Do the same with the couch or sofa.
21. Blinds - Operate each blind and check for alignment. Look at all valances and trim to be sure they are secured.
22. Counter Tops - Inspect all counter tops for alignment and fastening. Make sure that any trim pieces that should be there are in fact tight. Check for caulking quality everywhere there may be water, especially edges near a sink. Check the installation of sinks and faucets.
23. Windows - Open and close every window and operate the latches. Pay particular attention to the two safety egress windows or emergency windows and make sure they operate smoothly & easily.
24. Floor Coverings - Inspect carpet and other floor coverings in all corners to insure that they have been properly fastened down. Check areas that slide outs may roll over for pulled threads, cuts or other problems. Check closely for gouges or cuts in linoleum tile.
25. Wall Coverings - Check to make sure that all the wall coverings actually cover and join properly. Look for any discoloration or patch jobs that may cover hidden problems. Try to find any places where there are problems, as now is the time to get it fixed while matching patterns are in stock. (Some folks suggest ordering extra fabric, carpet, and wallpaper now so that matching material is available to make small modifications or repairs at a later date.)
OPERATION TEST OF ALL HOUSE SYSTEMS - You should be about two hours into to the PDI by now and you are ready to test all of the house type systems.
26. Shore Power System - Now is the time to connect up to shore power. Pull out all of the AC cord, confirm the length and inspect the plug for proper attachment. Inside the unit, check any 110V lighting and switches. (If you have a 110V receptacle tester, check all outlets for proper wiring/polarity.) Find the GFI protected outlet and test using the push button. Understand which receptacles “down stream” from the GFI are protected. Any electrical problems here should be corrected immediately.
26a. If there is a generator, start it and check the correct operation. Check that the changeover from 12 to 110 and back is done correctly. Check the voltage to charge the house batteries (to be sure the thing does not 'cook' them).
27. Converter - Confirm the operation of the converter/charger that is installed. Turn on several interior lights to create a load for the converter and confirm no excessive converter noise or vibration. Have the PDI person explain the operation of the converter, the AC circuit breakers and the DC fuses. Make sure that there is a written list of the loads connected to each fuse or breaker.
28. Water Pump - Your PDI person should have filled the fresh water tank, so now you can test the function of the water pump. After turning it on, you should hear it pump for several seconds, even up to a minute to create enough pressure in the system. If the pump does not shut off, there is a problem. Run water in the kitchen and bathroom sink and notice that the pump will come back on until proper water pressure is restored. Now is the time to fix a noisy pump if it is vibrating or making any irritating sounds.
29. City Water System - Turn off the pump, connect up to city water (use a regulator if overly high pressure is suspected) and confirm that the connection works correctly. Look for leaks under sinks and confirm the operation of all fixtures again while on city water.
30. Holding Tanks - Re-fill the fresh water tank if necessary and run water into the gray tank to verify the gauge reading and that there are no leaks. Filling the gray tank until water comes up in the shower will make it easier to find leaks inside & out. Do the same thing to the black water tank, including filling so that water comes up inside the toilet. Check for leaks (if the toilet is installed correctly, there will be no leaks!) You can fill the black water tank by using the tank flushing system (if fitted), by using a garden hose adapter for the sewer connection (through a backflow preventer) or by bringing the water hose inside and filling the tank through the toilet. This last method can be a little cumbersome, and I don't recommend unless you've done it before. Check the gauges for accuracy while you are filling. Now is the time you want to find leaks if there are any! Drain the gray and black water tanks using the sewer hose or the garden hose adapter.
31. Water Heater - Try the water heater on propane first. A few seconds after you turn it on, you should hear the click of the igniter and the small pop when the burner lights. The red light should stay on until that process happens. If it does not ignite, then there is a problem. Turn on the AC element in the water heater (if connected) and confirm operation. Make sure you know the location of the electrical switch at the water heater and the correct operation of the interior switch. If your unit is so equipped, understand the operation of the bypass valves for winterizing. Confirm that hot (or warm water depending on how long the water heater has been on) comes out of the hot tap at the various sinks.
32. Furnace - Now its time to understand the operation of the thermostat that controls heating and sometimes the air conditioning. Turn the furnace on and set a temperature that is at least 10 degrees hotter than the ambient temperature. In about 30 seconds, you should hear the furnace fans come on. Shortly thereafter you should hear the click of the igniter and the sound of the burner. If not then there is a problem. It could also be taking a while for propane to get to the heater, so don't worry yet! Let the furnace blow and you should get hot air at about 110 degrees coming out of all vents. Check each one. Now turn the furnace down and the hot air will gradually turn cooler and the fans will eventually stop after the furnace has cooled sufficiently. During this process have someone with a good nose checking for any smell of material getting too hot, or heater exhaust coming out. On a very new heater, there may be the smell of oil burning off internal metal surfaces. This should only last a short time. Have the windows & doors open.
33. Air Conditioners - Some air conditioners also have a heat strip or heat pump feature so now is the time to verify these functions. Turn on the air conditioner. After a couple of minutes, cool air, 20 degrees cooler than ambient, should be coming out of the registers. If you unit has ducting in the ceiling, make sure a good airflow comes out of each register. Learn how to clean the filters at this time.
34. Propane and Carbon Monoxide Alarms & Smoke Detector - Now is a good time to check the function of these alarms. The PDI person should have a small canister of gas that can be sprayed at the alarm to test its operation. Have them perform this test while you watch and learn how the alarms work. Confirm that there is a new battery in the Smoke Detector. (Write the date on it for reference) Activate the test button to check operation of the smoke detector. Understand how to turn it off.
35. Refrigerator - Most modern refrigerators work on propane or AC and have an automatic mode that gives preference to AC and then will switch to propane if AC power is not available. Understand the controls and the status lights and set the unit on propane. The RV may need to be unplugged for this to happen. Go outside to the refrigerator vent grill and make sure that the propane heating column is lit and heating. While the refrigerator grill is open, check to make sure the drain line is positioned for proper drainage. Set the temperature at the highest cooling setting, because setting it to lowest will typically cause the coils to collect moisture and ice up. Come back in about 10 minutes to feel that the coil/fins are actually starting to cool.
36. TV VCR Antenna and Switching - For the most through test, bring a small AC/DC TV with you for the initial test. Review and understand the switching system that allows the selection of viewing channel on the front and rear TV. Raise the TV UHF/VHF antenna and learn how to turn on the amplifier and the DC outlet. Find out the power rating of the DC outlet and compare it to the load of the equipment you will connect to it. Activate the control on the front TV that scans for local stations. Learn how to rotate the antenna to maximize the quality of the picture.
37. Air Vents - Test the operation of kitchen and bathroom air vents making sure they open and turn on properly (if powered). Verify that they retract and close tightly. Check any other vents for proper operation.
38. Microwave - Put a cup of cold water in the microwave and set the timer for 3 minutes. The water in the cup should boil in less than 3 minutes. Make sure there are no unusual sounds coming from the Microwave.
39. Propane Stove - Turn on one burner of the stovetop while the air conditioners and Microwave are running and the automatic igniters should cause a strong spark to light the burner. Turn on the other burners to verify that there is enough propane flow to operate the refrigerator, water heater and all the burners. If everything is OK, turn off the burners on the stove. If your unit has an oven, then understand how the pilot is lit and verify its operation now. Note: Sometimes the burner igniters interfere with the operation of the thermostats for the roof AC. This is the time to find this problem.
40. Summary - You have now done a simple test of the major house systems and can shut everything off. By now, you will probably have a list of things that you feel need correcting, but it may also be near the end of the day. Decide if you are going to accept the trailer as is or if it needs to stay with the dealer. If you accept the unit and it is appropriate, plan on camping near the dealer for the night. This will give you a chance to further test the various functions. Prepare yourself for waiting until these things are corrected and don't be tempted by the PDI person to sign the acceptance paperwork just yet. For a really serious checkout of your new trailer, you should "dry camp" the first night and not be tempted to hook up to shore utilities just yet. Bring enough kitchen equipment and food so that you can prepare an evening meal. There is no better way to test the living facilities than to actually use them. Don't be tempted, since you've had a tough day, to go out to eat.
41. ACCEPTANCE - When you are satisfied that all systems are "go" then sign the acceptance papers that the PDI person will anxiously provide for you. Schedule your first return trip to the dealer for about a week to a month from now. You are now ready to take your "shake down" cruise.
42. SHAKE DOWN CRUISE - Select an interesting destination about 100 miles away for your maiden voyage. Actually use all the systems multiple times to try to detect any infant failures (electronic equipment fails at greater rates at the beginning of its life). Carefully note any problems or discrepancies in a list and make a copy for the dealer when you take the RV in again.
The Rev - Retired
'88 Limited - an 'oldie', but everything we need!
(Click to see the best view of my rig!) That's Me - Going Away!
Chassis by Deere-Drive by Ford-Coach by Fleetwood-Security by Smith&Wesson.
Never Give an INCH until you can get a MILE!!
Here's one of two I'll post. Between ccxnola's post and these two you should be covered.
rr
Pre Acceptance Checklist
This cklist is designed from the "So you want to pick it up at the factory cklist by http://208.55.19.51/ArtFactoryPickup.html
Bob Gummersall". Warning: You should study Bob's article before using this checklist.
This checklist is intended for field use on the day of delivery. With two copies you will
have one for your records and one to give the dealer of repairs needed before
signing any paperwork. This is designed for a Diesel Pusher Motorhome
Pass Fail
Check weight and balance.
Front Axle wt: __________ Lt. Front:_______
Rear Axle wt: __________ Rt. Front:_______
Actual wt: __________________ Lt. Rear:_______
Rt. Rear:_______
Outside Walk Around
Roof Sealing, Ck. Sealing on seams, gaskets, screwheads.
Ck. Around AC, vents, antennas, sewer vents and side seams.
Findings:___________________________________
__________________________________________
Doors: Ck. Gasket, adhesive and coverage. Ck. Alignment of
door. Findings:____________________________
Baggage Compartment: Ck. Operation of doors, cylinders for
holding door open. Hinges for tightness and secure. Ck. That
door is held close tightly. Ck. For moisture. Ck. Lighting
Findings___________________________________
Engine Compartment: Ck. Door for alignment and latches hold
door closed securely.
Generator Compartment: Ck. Door for alignment and tight fit.
Ck. That everything is tight and rattle free. Ck. That exhaust is
not under window or slides. Operate power slide a few times to
insure proper operation.
Fuel Doors: Ck. For alignment and proper locking. Make sure
there are lanyards for holding caps from falling on ground during
fueling. Ck. Proper way to fuel vehicle.
Utility Compartment: Ck. Closely how each valve works.
Ck. How sewer hose is stored. Ck. Proper function of black and
gray valves. Understand how tank flushing works. Ck. Water
filters for proper installation. Ck. Electrical reel operation. Ck.
Propane: Ck. For downward ventillation. Ck. That tank is
secure. Ck. That propane can not enter coach or compartments.
Ck. Operation of main shutoff.
Battery: Ck. For proper ventillation. Ck. All slide mechanisms
are working properly. Ck. For cables rubbing or binding.
Understand the type battery and proper maintenance.
Tires and wheels: Inspect tires for proper inflation. Have
torque on lugnuts checked by dealer.
Tire PSI: _________
Windows: Ck. Each window for alignment and proper
seals.
Paint: Ck. Closely for bubbles, pits, chips. Ck. Vinyl
films for bubbles. Ck. For overspray of paint. Ck.
surface for smoothness and even coat of paint.
Awnings: Operate awning several times. Ck. Springs
locks, supports for alignment. Ck. For tears and
punctures.
Chassis Inspection: Ck. Exhaust pipe for proper
shielding from propane lines and tank. Ck. Wiring
and piping for proper fastening. Ck. Undercoating is
not sprayed on brake calipers and sight glasses.
Ck. Brake calipers for alignment and operation. Ck.
for fluid leaks. Ck. All operating fluid levels.(hyd.,
transmission, fuel, oil, coolant.) Understand how to ck.
drive belts and their types.
Slide-Out operation: Ck. Seals while slide is
retracted. Operate each slide several times.
Understand the interlocks that might be present. Ck.
the manual retraction process. Ck. Proper alignment
of wheels and for clearance. Ck. Locking mechanisms
for proper operation and alignment. Make sure seals
are properly installed and operational when slide is
retracted and extended.
Awning and Step operation: Ck. The operation of
each awning and automatic step. Ck. The operation of
all manual awnings. If equiped with wind sensors then
ck. With compressed air while awning is extended.
Inside Fit and Finish
Pass Fail
Cabinets: Inspect outside of all cabinets for scratch's nicks,
loose handles. Ck. That all hinges and latches operate properly.
Pull drawers all the way out several times. Try to open them like
road vibration would. Ck. For water leaks and make sure wires
and pipes are fastened securely. Ck. The lining to see that it is
attached securely.
Lighting: Operate every lightswitch. Operate battery
disconnect switches and understand there function.
Closets: Ck. The operation of all doors and there alignment.
Ck. That hanger rods are securely fastened. Ck. All closet
lighting and switches that are provided.
Furniture: Ck. Furniture for construction, upholstery, pattern
and cloth matching. Ck. Out dinette by making into bed.
Ck. Closely the drivers and passenger seats. Inspect all seat
belts. Locate all other passenger seat belts.
Blinds: Operate all blinds and ck. Alignment.
Ck. All valances and trim for security. Ck. Pull drapes that cover
windshield for operation.
Counter Tops: Ck. All countertops for alignment and fastening.
Ck. All trim pieces are there and tight. Ck. Caulking for quality
anywhere water is possible. Ck. Installation of sinks and faucets.
Finings____________________________________
Windows: Operate every window and window locks. Inspect
and Operate each emergency window. Locks and latches
should work freely but securely.
Floor Coverings: Ck. All carpeting and floor coverings to see
that it is properly fastened down. Ck. Grout in tile flooring is
complete and clean. Expecially under any sliding cabinets.
Wall Coverings: Ck. All coverings to insure joints meet.
Ck. For nicks, scratches, tears. Order extra fabric, carpet and
wallpaper for future small repairs or modifications.
Operational Test of Home Systems
Generator: Learn how to start & stop generator. Know where
the remote stations are located and how they work. Start the
generator and listen for unusual noises or vibrations.
Understand any power relays and test incoming ac power prior
to cutting through. Ck. The electrical status panel. Put load on
generator by running microwave, turn on and off all ac powered
lights. Leave generator running.
Inverter/converter/charger: Understand the operation. Have
PDI person explain the function of all controls, displays, lights.
Ck. That house batteries are being charged. Now shut down
generator. Leave inverter in on position. Ck. To see that inverter
took over all ac voltages. Test by turning on microwave for a
minute. Turn on TV and leave on for rest of inspection.
Water Pump: Insure that fresh water tank has water. Turn on
pump and listen for pump to start. After pump stops open faucet
and let run till pump starts then close faucet. Ck. For noisy,
vibrating or making irrating sounds.
Water Heater: Test operation on propane. Test operation on
ac. With no shore power and generator off you should see the
dc lights dim. Turn off water heater when done.
Furnace: Understand the operation of the thermostat as it
relates to heating and cooling. Ck. The operation of the furnace.
You should have heat coming from all vents after a few minutes.
Ck. For the smell of material getting hot or exhaust.
LP,Carbon Monoxide, Smoke Alarms: Have PDI person test
each one of these items and explain how you can test them.
If one of these alarms fails this test, stop and make them fix
before continuing as these are life savers.
Refrigerator: Understand the controls and status lights.
Set unit to propane and ck. Outside to see that heating column
is lit and heating. Set temperature to highest setting and come
back and see if coils are cooling after about 10 min.
TV VCR Antenna & Swithing: Test the switching system that
allows viewing of channels on front and back TV's. Test the
raising, lowering and rotating of the TV antenna system. If you
have DSS satellite system test it out. Understand the operation
of all remotes.
Air Conditioners: Start the generator and verify that the ac
control system switches the ac over to the coach. Ck. That the
inverter switched to charging mode. After generator has settled
down turn on Front AC after a few minutes cool air should be
coming out vents. Turn on back AC and after a few minutes cool
air should be coming out. Switch both unit over to heat mode
and ck. For heat after a few minutes. Insure that air comes from
all vents. Leave running.
Air Vents: Ck. The operation of both kitchen and bath vents.
Ck. That both vents close and retract tightly.
Microwave: With both AC's running heat cup of water for 3
minutes. Generator should hold strong and water should be hot.
Ck. For unusual sounds from microwave.
Propane Stove: Ck. Operation of one burner while microwave
is still running. Turn on other burners and note if there is
adequate propane flow to burners. NOTE: whether AC interferes
with there operation. Operate the oven.
Vehicle Operating Test
Pass Fail Before doing any of the following tests do a quick walk
around coach to check clearance in all directions.
Cockpit
Test each control for seats and mirrors.
Test adjustment of steering wheel.
Have PDI person explain anything you don’t fully understand.
Instrumentation
Turn on Ignition but don’t start motor.
Test each gauge and know what their normal operating range is.
Ck. All lights and alarms.
Ck. Rear monitor and test all its controls.
Have PDI person explain fully how each control and light operates
and what they mean.
Start Engine
Wait till "Wait to Start" light goes out.
Start vehicle (it should start within 2 to 4 seconds)
Ck. Oil pressure is within normal range.(no oil pressure shutdown
now.)
Ck. Voltage gauge (should read 13.2 volts)
Ck. Air pressure gauge (should come up to 120 psi and remain
steady.)
Ck. That all warning lights have went out.
Dash Air & Heating
Test dash AC and related vents
Test dash heat and related vents
Test dash mounted fans if so equipped.
Air System Test
Test air suspension system
Have PDI person fully explain how this is done on your coach.
Test air leveling system.
Test Emergency brake
With Emergency brake applied put in drive and try to pull forward
1200rpm coach should not move. Put back in Park.
Test Braking
Release emergency brake and pull forward slowly and apply
brakes firmly. Coach should stop immediately. Reset
emergency brake. Pump brakes repeatedly till air pressure
drops to 90psi.
Ck. That air recovers to 120psi.
Turn off vehicle.
Pump brakes till warning beeper sounds between 90psi & 60psi
If any of these tests fail don’t drive vehicle till fixed…
Hydraulic Brakes
Apply Parking brake and put in drive, apply lightly on throttle.
Coach should not move at all.
If everything in vehicle Operating Test
is checked pass you are ready to take it out for
test drive. If anything is checked fail then have it
fixed first.
Road Test
Ck. Handling and steering wheel movement needed to maintain
lane.
Ck. For noises from engine, transmission, flapping awnings.
Ck. Engine brake operation.
Ck. Instrumentation for normal readings.
Ck. For road noises, vibrations and wind noises around door.
Camp at factory or dealers lot over night to test living facilities
and to allow any needed repairs to be done.
Here's the other one. Some day I might merge all this info.
rr
RV Initial checkout
Assumptions:
• Both propane bottles are filled
• All batteries are charged and connected
• Shore power is available
• City water and a hose are located close by
• Sewer connections, a drain or a dump station is available to test water systems
• You will probably be given a “Starter Kit” which includes a sewer and fresh water hose and a pressure regulator among other items for the holding tanks. Use these during the checkout.
You should have available the delivery invoice for the unit. It will show all the standard equipment and ordered options and should be compared to what you thought you ordered and should be referred to during your inspection. Pictures from the glossy brochure will also help in your inspection.
You will need the understanding & cooperation of your dealer for this process, as it probably involves far more depth & detail than they normally anticipate and schedule for. Make sure they know about it in advance. At the very least, tell the person doing the "owner inspection" or "walk through" what you intend to do, give him or her a copy of this checklist and work with them to plan the time accordingly.
Notes or problems found:
________________________________________________________
OUTSIDE WALK AROUND
At this point, you're generally searching for anything that does not look right.
1. Roof Sealing & Fixtures-
( ) Carefully inspect the ladder on the back of the unit. Check that all the mounting points are solidly attached to the body and the rungs are firmly fixed to the frame.
( ) Climb on the roof and inspect all seams, gaskets and any other place that the roof material has been cut or holes drilled.
( ) Check that all shrouds & covers are intact, unbroken and properly seated on the roof. Check caulking around air conditioners, vents, antennas, sewer vents, and side seams. Look for any signs of sealant bubbles, delaminating, foreign objects or protruding screw or nail heads under the roof.
2. Windows –
( ) Check closely around each window to make sure it has been properly aligned and sealed.
3. Entry Door –
( ) Should open & close smoothly and lock with out undue effort
( ) Check the gasket used on all doors for proper adhesive and coverage.
( ) Look closely at the door from the inside and confirm that it sits flush against the inside of the doorjamb.
( ) Confirm that each key works in the appropriate lock.
( ) Check that the screen door opens smoothly and locks to the main door without any extra effort.
4. Baggage Compartments –
( ) Open and close each door checking for alignment and gaskets.
( ) All hinges should be tight and secure and the latches should hold the door tightly closed and still be easy to open.
( ) Feel the floor or carpeting and look for any signs of moisture that might indicate rain leakage.
( ) Verify that compartment lighting (if fitted) works properly.
( ) If clamp-type door hold-opens are used, make sure they are present and hold the door correctly.
5. Sewer & Fresh Water Connections –
( ) Inspect this area on the trailer to make sure that nothing is broken or deformed.
( ) Make certain you understand how each valve or fitting works.
( ) If tank flushing is installed, understand how it operates.
( ) Understand where the low point drains are for the fresh water system.
6. Telephone & Cable Connections –
( ) Locate and understand the phone and cable connections.
( ) Make sure a weather cap is present for each connector and that connectors are properly identified & mounting plates are properly sealed.
7. Propane -
( ) Understand how the regulator works and how it switches between cylinders.
( ) Confirm that a leak test has been performed on both pigtails between the tanks and regulator and the rest of the system.
( ) Locate and understand the operation of the main shut off valve (if any).
8. Batteries –
( ) Understand the battery type provided and how to maintain them.
( ) Check the battery box to verify that it is ventilated and that any compartment slide mechanisms work properly.
( ) Verify that no battery cables are rubbing on any part of the frame because that will eventually end up with a short circuit and possible fire.
9. Gel Coat & Siding -
( ) Carefully check the Gel Coat on the RV. Any problems can be verified and corrected at this point with a lot less hassle.
( ) Site down the side of the unit to check for bumps or depressions.
( ) Divide each side of the unit into sections and inspect siding issues: color variations, dents or irregularities. Do the same for the ends of the unit
( ) Look at vinyl film graphics to make sure it is free of any air bubbles.
( ) Check ends of any decals for uniformity that may have gouged the siding.
( ) Look closely where masking tape was used for paint graphics to make sure there is no over-spray.
10. Tires and Wheels –
( ) Closely inspect the tires and wheels
( ) Verify the lug nut torque of _________,inflation pressure __________
( ) Find the proper jacking point for the trailer and what kind of jack to use.
( ) Determine if your truck lug wrench will fit the lug nuts on the trailer.
11. Spare Tire - Check the pressure of the spare tire. Understand its mounting and workings
12. Awnings –
( ) Extend and retract each awning paying particular attention to how the awning is locked in the retracted position. Make sure all springs, locks and supports work well and are aligned.
( ) Wiggle the mounting points to get a feel for how solidly they are mounted.
13. Chassis Inspection - You want to be able to Inspect all air and / or hydraulic lines, wiring, shock absorber attachments, and in general every place that a wire or pipe could rub against something that could cause a problem later. All wiring and piping should be properly fastened.
14. Slide Out Operation - Spend the time it takes to understand its operation.
( ) Start by checking the seals while the slide is retracted. You should not be able to find any places where you can see light or detect airflow. Use a flashlight to look into dark corners.
( ) Understand the mechanism that extends and retracts the slide. Operate it several times and understand any restrictions on operation.
( ) Understand the manual retraction process and actually perform the retraction as if the automatic mechanism had failed.
( ) Look for proper alignment of any wheels that may ride on carpet or other flooring, to insure proper clearance.
( ) Understand any locking mechanisms that are used to hold the top of the slide out tight against the top of the RV.
( ) Do your best to make sure the seals are properly installed and operational when the slide is retracted and also when it is extended.
( ) Visually check the under-slide area for proper routing of wires or cables.
( ) Confirm that nothing rubs on the tires (parts of the slide, wiring, insulation, Etc.) when the slide is retracted.
15. Cabinets –
( ) Inspect & open all of the cabinets to insure that all the hinges and latches work well.
( ) Pull each drawer out to its stop, return it closed and then try to open it like road vibration might do.
( ) Make sure that there have been no water leaks and that all the wiring and pipes are well fastened.
16. Molding & trim - Go over all the trim on walls, doors & furniture.
( ) Make sure that everything is fastened on well and not loose or ready to come off.
( ) Check that no nail or staples are protruding.
17. Lighting –
( ) Operate every light switch and observe its function.
( ) Use the monitor panel to check battery levels.
( ) Understand and verify any battery disconnect switches.
18. Closets –
( ) Open and close all closet doors checking for free operation and proper alignment.
( ) Hanger rods should be properly fastened and secure.
( ) Check out any lighting that is provided and any switches that are used.
19. Furniture –
( ) Examine all furniture to check for construction, upholstery, pattern and cloth matching.
( ) Check out the sofa by making it a bed with the appropriate cushions.
20. Blinds –
( ) Operate each blind and check for alignment.
( ) Look at all valances and trim to be sure they are secured.
( ) Make sure attachments to walls are solid
21. Counter Tops –
( ) Inspect all counter tops for alignment and fastening.
( ) Make sure that any trim pieces that should be there are in fact tight.
( ) Check for caulking quality everywhere there may be water.
( ) Check the installation of sinks and faucets.
22. Windows –
( ) Open and close every window and operate the latches.
( ) Pay particular attention to the two safety egress windows or emergency windows and make sure they operate smoothly & easily.
23. Floor Coverings –
( ) Inspect carpet and other floor coverings in all corners to insure that they have been properly fastened down.
( ) Check areas that slide outs may roll over for pulled threads or cuts
( ) Check closely for gouges or cuts in linoleum tile.
24. Wall Coverings –
( ) Check to make sure that all the wall coverings actually cover and join properly.
( ) Look for any discoloration or patch jobs that may cover hidden problems.
( ) Try to find any places where it is not perfect since now is the time to get it fixed while matching patterns are in stock.
Now and you are ready to test all of the house type systems.
25. Shore Power System - Now is the time to connect up to shore power.
( ) Pull out all of the AC cord, confirm the length and inspect the plug for proper attachment.
( ) Inside the unit, check any 110V lighting and switches.
( ) Using a 110V receptacle tester, check all outlets for proper wiring/polarity.
( ) Find the GFI-protected outlet and test using the push button.
26. Converter –
( ) Confirm the operation of the converter/charger that is installed.
( ) Turn on several interior lights to create a load for the converter and confirm no excessive converter noise or vibration.
( ) Have the PDI person explain the operation of the converter, the AC circuit breakers and the DC fuses.
( ) Make sure that there is a written list of the loads connected to each fuse or breaker.
27. Water Pump –
( ) Your PDI person should have filled the fresh water tank, so now you can test the function of the water pump. After turning it on, you should hear it pump for several seconds, even up to a minute to create enough pressure in the system. If the pump does not shut off, there is a problem.
( ) Run water in the kitchen and bathroom sink and notice that the pump will come back on until proper water pressure is restored.
28. City Water System –
( ) Turn off the pump, connect up to city water using a regulator and confirm that the connection works correctly.
( ) Look for leaks under sinks and confirm the operation of all fixtures.
29. Tanks –
( ) Re-fill the fresh water tank if necessary and run water into the gray tank to verify the gauge reading and that there are no leaks.
( ) Filling the gray tank until water comes up in the shower will make it easier to find leaks inside & out.
( ) Do the same thing to the black water tank, including filling so that water comes up inside the toilet. Check for leaks.
( ) You can fill the black water tank by using the tank flushing system.
( ) Check the gauges for accuracy while you are filling
( ) Drain the gray and black water tanks using the sewer hose or the garden hose adapter.
30. Water Heater –
( ) Try the water heater on propane first. A few seconds after you turn it on, you should hear the click of the igniter and the small pop when the burner lights. The red light should stay on until that process happens. If it does not ignite, then there is a problem.
( ) Turn the AC element in the water heater (if connected) and confirm operation.
( ) Make sure you know the location of the electrical switch at the water heater and the correct operation of the interior switch.
( ) If your unit is so equipped, understand the operation of the bypass valves for winterizing.
( ) Confirm that hot (or warm water depending on how long the water heater has been on) comes out of the hot tap at the various sinks.
31. Furnace - Now its time to understand the operation of the thermostat that controls heating and air conditioning.
( ) Turn the furnace on and set a temperature demand that is at least 10 degrees hotter than ambient temperature. In about 30 seconds, you should hear the furnace fans come on. Shortly thereafter you should hear the click of the igniter and the sound of the burner. If not then there is a problem.
( ) Let the furnace blow and you should get hot air at about 110 degrees coming out of all vents. ( ( ) Check each one.
( ) Now turn the furnace down and the hot air will gradually turn cooler and the fans will eventually stop after the furnace has cooled sufficiently.
32. Air Conditioners - Some air conditioners also have a heat strip or heat pump feature so now is the time to verify these functions.
( ) Turn on the air conditioner. After a couple of minutes, cool air, 20 degrees cooler than ambient, should be coming out of the registers.
Make sure a good airflow comes out of each register.
( ) Learn how to clean the filters at this time.
33. Propane and Carbon Monoxide Alarms & Smoke Detector - now is a good time to check the function of these alarms.
( ) The PDI person should have a small canister of gas that can be sprayed at the alarm to test its operation.
( ) Have them perform this test while you watch and learn how the alarms work.
( ) Confirm that there is a new battery in the Smoke Detector (write the date on it for reference)
( ) Activate the test button to check operation of the smoke detector. Understand how to turn it off.
34. Refrigerator - Most modern refrigerators work on propane or AC and have an automatic mode that gives preference to AC and then will switch to propane if AC power is not available.
( ) Understand the controls and the status lights and set the unit on propane. The RV may need to be unplugged for this to happen.
( ) Go outside to the refrigerator vent grill and make sure that the propane heating column is lit and heating.
( ) Set the temperature at the highest cooling setting, because setting it to lowest will typically cause the coils to collect moisture and ice up.
( ) Come back in about 10 minutes to feel that the coil/fins is actually starting to cool.
35. TV VCR Antenna and Switching
( ) Review and understand the switching system that allows the selection of viewing channel on the front and rear TV.
( ) Raise the TV UHF/VHF antenna and learn how to turn on the amp and DC outlet.
( ) Find out the power rating of the DC outlet and compare it to the load of the equipment you will connect to it.
( ) Activate the control on the front TV that scans for local stations.
( ) Learn how to rotate the antenna to maximize the quality of the picture.
36. Air Vents –
( ) Test the operation of kitchen and bathroom air vents making sure they open and turn on properly (if powered). Verify that they retract and close tightly. Check any other vents for proper operation.
37. Microwave –
( ) Put a cup of cold water in the microwave and set the timer for 5 minutes. The water in the cup should boil in less than 5 minutes. Make sure there are no unusual sounds coming from the Microwave.
38. Propane Stove –
( ) Turn on one burner of the stovetop while the AC's and Microwave are running and the automatic igniters should cause a strong spark to light the burner.
( ) Turn on the other burners to verify that there is enough propane flow to operate the refrigerator, water heater and all the burners.
( ) If everything is OK, turn off the burners on the stove.
( ) If your unit has an oven, then understand how the pilot is lit and verify its operation now.
Summary - You have now done a simple test of the major house systems and can shut everything off. By now, you will have a list of things that you feel need correcting, but it may be then the end of the day. Decide if you are going to accept the trailer as is or if it needs to stay with the dealer. If it is appropriate, plan on camping near the dealer for the night. This will give you a chance to further test the various functions. Prepare yourself for waiting until these things are corrected and don't be tempted by the PDI person to sign the acceptance paperwork just yet. For a really serious checkout of your new trailer, you should "dry camp" the first night and not be tempted to hook up to shore utilities just yet. Bring enough kitchen equipment and food so that you can prepare an evening meal. There is no better way to test the living facilities than to actually use them. Don't be tempted, since you've had a tough day to go out to eat.
SHAKE DOWN CRUISE - Select an interesting destination about 100 miles away for your maiden voyage. Actually use all the systems multiple times to try to detect and infant failures (electronic equipment fails at greater rates at the beginning of its life). Carefully note any problems or discrepancies in a list and make a copy for the dealer when you take the trailer in again.
GOOD LUCK!
edited 06/24/05 05:25am by an administrator/moderator *
We picked our Phaeton up in Dallas, and our shake down trip back to Arkansas was over 300 miles. We didn't have one problem. By the way, we had faxed our PDI list about a week before we went to pick it up. It is a good idea to let them know what you are going to inspect. We had a very nice Tiffin service rep. that showed us the PDI list that comes from Tiffin home office. Ours was 4 pages (from a fellow Tiffin owner I've hopefully connected you with), and the one that Tiffin has for their service rep. to fill out is even longer. All in all, we felt all the details were covered. We are sure there will be some issues, (because usually there always are with just about anything), but we still have a good feeling that any problems will be taken care of.
You can go to my website and download a copy of the pdi form.
Russ Ritenour if you wish to paste my checklist could you please cut and paste the full checklist.
Thankyou
MB53 wrote: You can go to my website and download a copy of the pdi form.
Thankyou
Gary,
A great PDI also! I think the best thing it maybe just send these lists to Johnny T for posting on the FAQ area.
rr
WOW!!! Thanks Russ and MB53. This is obviously not my post but this information is great to have. I think this would be a GREAT STICKY for the forum… Hint.. Hint JohnnyT…
George & Coleen
2000 Damon Challenger 330
2000 Mercury Villager
FMCA #F351182
Not enough time!!!!!
SneakySnake
George & Coleen
FMCA #F351182
