I want to have my 23.5 RV recarpeted. Anyone out there able to tell me what they paid, what they thought of service, and what should I look for in an installer, other than previous practice on some other fools rig? My carpet i sclean but dated, and since we had a non RV type overflow my toilet tank all over the floor I just don't like that carpet no more. Just seems icky. I would like to know price, did you use padding or not, finish work, work around cabinets, etc? And perceived value for the price.
We have a 23 ft itasca, and when we found the floor squeking we descovered that when they put in the flooring plywood they used very thin plywood,and it didn't cover the joint crossing so over time it started making the noise which we thought might of been dry rot, so hubby took heavier plywood over the old carpet and then we layed vinyl squares and he put down extra adhesive so they would stick better, we found that vinyl with throw rugs is much easier to clean than carpet specially in a smaller motor home, plus we also have cats, so easy clean with a brook specially when your limited to space....Broom and sweep out the door....sorry i know that wasn't really your questions, just a suggestion from me...
For those that want to know about Oregon http://groups.yahoo.com/group/campinginoregon/
We ripped the carpet out of our old Class A with just a razor kinfe, and put in new carpet with a thin pad. All I did was staple it down in a few places, picking a carpet pattern where staples did not show. A cut to fit carpet almost wants to stay in place all on its own due to the irregular shape and small size.
I had never done carpet before. It was really easy and cheap since it was very few square yards. There was a lot of waste since I bought one big piece. I just laid it down the center aisle and cut it down to fit as I went.
Jim
2002 Gulfstream Conquest Class C
Rolling wired and wireless network
As HiTech pointed out, laying what is essentially a wide runner doesn't require the same skills as laying wall-to-wall carpeting. Rip out the old carpeting and use the pieces as your pattern for the new stuff. Mostly, you need sharp tools and lots of patience: In a small space, small errors look big.
I have carpet in my rig. I like the idea of having a smooth floor that can be easily cleaned, but there is more prep work involved for putting down vinyl or wood laminate.
I never have liked the idea of carpet in the bathroom.
Bob, Martha, and Matt
'95 Coachmen Catalina Sport 275QB (soon to sell)
oh, and Tucker, the Toy Poodle Toprudder.com
HiTech wrote: We ripped the carpet out of our old Class A with just a razor kinfe, and put in new carpet with a thin pad. All I did was staple it down in a few places, picking a carpet pattern where staples did not show. A cut to fit carpet almost wants to stay in place all on its own due to the irregular shape and small size.
Jim
HiTech,
I just ordered the carpet for my old class C last week, I have been planning on re-carpeting since I got the RV two years ago, but I wanted to finish all the other major projects first. I have already done the bathroom and entry steps in vinyl.
My plan is to cut out all the old carpet, fix the various squeaks and imperfections and paint the plywood floor with an oil base to seal it from spills. The carpet I ordered is so plush I am not going to use any padding except for the front driving area I am going to insulate the floor from noise and heat with foil backed jute insulation. I ordered my carpet big enough so I won’t have to seem it, I have an air staple gun for the edges.
HiTech, did you fold under the edges of the carpet before stapling it (I have seen this done in new Lazy Daze)? Or did you just try to stuff it under the cabinets? Any strategy on cutting that first big hallway piece? I was thinking I would just sort of rough trim it then let fold up the walls and start to trim at the corners.
BTW I ordered a 12" X 14" piece of carpet and it cost $519 and yes their will be lots of waist that I plan to trim to the bath floor shape and have the edge sewn for a custom bath carpet inlay.
You might want to think twice about painting or otherwise sealing the floor. Sure, it would keep moisture out -- but it will also keep moisture IN if the flooring gets damp -- such as from humid weather underneath, or a spill getting into cracks.
Can you tell me a little bit more about foil-backed jute insulation? Where can I get this, and does it have any tehcnical or breand name(s)?
joanne0012 wrote: You might want to think twice about painting or otherwise sealing the floor. Sure, it would keep moisture out -- but it will also keep moisture IN if the flooring gets damp -- such as from humid weather underneath, or a spill getting into cracks.
joanne0012
Thank you for the input, I agree it could be a problem if everything were completely sealed. But I am only going to seal under the carpet, all around it under the cabinets will still be bare. I am not going to gut the RV just to put in carpet, I am afraid it would never end on an old rig like mine.
I first found the insulation at Camping World and it had foil on both sides and it is intended for Doghouse insulation but it is twice the price as JC Whitney. The stuff from JC Whitney has foil only on one side, but the jute is the same. After that I found the same product at Home Depot with the foil on one side and it was sold as a Water Heater Blanket.
Here is the link to the JC Whitney product. click here
I found this from another member on the forum who posted pics of an entire insulation project with the stuff from JCW, if you are interested you might do a search.
In mine I did a rough cut as you suggest then forced it into place and cut away the extra, always cutting a but large until I got it progressively right. Folding over might work well but I simply cut it as if it were a big runner.
