TonyMin
Walnut Creek CA
What chemicals? I don't use any but a little soap every once in a while.
I have a cleanout in the driveway. I couldn't quite get to it with the MH so I took some three inch pipe and I have a couple of lenghts I screw together for a temporary, above ground extension. I store the pipe next to the garage in between use. It is nice to have really clean tanks every time we head out on a trip.
Works great.
'98 Shasta Cheyenne 280 highrise, widebody
Economical Handyman
S. California
Good Sam RV Club
Ray,
The cons....... is the labor, since you have mostly sand makes for easy digging. This time of year, with the HEAT it is a morning job.
Just dig down to you main sewer pipe, no need to go to the tank, plus the tank will be deep. The closer you stay to the house the less digging you will have to do.
Go to HD by the airport and explain what you are doing, make sure they have two no-hub fittings for you.
Good Luck
DeWayne & Judy
04 3810 Dutch Star
ISL 370 9.3 mpg
Frank's autoformer
01 Sahara Jeep-toad
Blue Ox Aventa II
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
JUrban
Delaware
Just don't use chemicals on the home run. Any cleanout or access works just fine.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
horacebcupp
Johnson City, TN
Fun story. The tree roots finally got to the sewer line from my house (circa 1924) to the alley main. Had to dig up the terra cotta and bypass the obstructions with a new PVC section. Had hired the city folks to do this afterhours, an accepted practice in our community. I asked if they would include a "dump station" for my coach, sitting right there. The reply was,"no, that's against the law, but you really should have an inspection port right there" near where my RV is parked. Voila! Instant dump station.
2003 Foretravel, U 320
2003 Honda CR-V
TexasShadow
Spring Branch, TX USA
re hurting the septic system's breakdown action with chemicals.....
i just use more Rid-X than I used to use in the past. After 6 years, still no problems.
TexasShadow
Holiday Rambler Endeavor LE/ 3126B Cat
BMW K75 on Rear Carrier
Jeep Grand Cherokee Toad
M&G aux brake system
Datastorm 3990
611 watts solar power
Always remember you're unique, just like everyone else.
Geezer2
Arizona
I have one installed in my RV garage, one installed at side of house in my guest rv area, and one outside of gates to dump when arriving home from a dry camping trip. All of them empty into the sewer line and they were all permitted and inspected by the city.
no rv any more
Shyla and Samson,
Ron & Cathy
hasbeen
Everett, WA.
If you are on a septic system it is important to have properly functioning outlet port with filter, rid x is a enzyme which should be unnecessary if your system is functioning properly, we put a dump "T" on our sewer line but it was during construction so we got it right where we wanted it- it is so convenient. Hiring a contractor can be a nightmare and big expense so I would recommend finding a good plumber that doesn't charge like a doctor or lawyer.
HiTech
SE Michigan
In this case I think the Rid-X is instead of other tank chemicals to be compatible with dumping into a septic tank.
Jim
2002 Gulfstream Conquest Class C
Rolling wired and wireless network
david_42
Oregon
So long as you call it a "clean out", you can have one installed anywhere. I haven't bothered putting one on the driveway, as I had a cleanout in the front yard at my last place and at my current place, so I just blue tank it over.
TonyMin
Walnut Creek CA
Hmm, then you could call a proctologist an inspection port technician?
Sorry, I couldn't resist.
'The reply was,"no, that's against the law, but you really should have an inspection port right there" near where my RV is parked. Voila! Instant dump station.'
