eweege
San Jose, CA
Hi Lou, could you send me (hitchnfish) your rv checklist as well? Thanks a bunch!
2000 F350 PSD, CC, Shortbed, Gold, Lariat, Snowbird 26RLBW
eweege
San Jose, CA
oops.. Let's try that email address again..
Hi Lou, could you send me (hitchnfish@aol.com) your rv checklist as well? Thanks a bunch!
DougnDee
Corvallis, OR USA
Lou you are a real trooper! Thanks not only for the lists, but all your hard work and willingness to share!
The Walk Through list will help us. We heard yesterday that our new Cameo is shipping. In fact it was in Cheyenne, WY, in a snow storm, on it's way to Salem, OR. It will be an experienced traveler by the time it gets out here! Trouble is, I'm worried about it going all that way in the winter storm that has been raging between Indiana and Idaho. I'm crossing my fingers and toes that it won't be damaged. It left the factory on Feb. 22, and was in Cheyenne on Mar.1. Sounds like something held them up.
If it were here we would be camping today. Out here on the left coast it has been beautiful weather for about 2 weeks. It has been clear and cold (20's at night is cold for us!). During the day it is so Spring like I've got most of my Spring yardwork done and am ready for camping. The coast is only 57 miles away, and it is warm enough for beach walks there.
Thanks again, Lou. You & those like you are what make this forum so helpful.
Dee
*This Message was edited on 02-Mar-02 11:42 AM by DougnDee*
Doug,Dee & Shoni
'02 Cameo LXI,
'07 Dodge Cummins 2500,6Spd,Quad,4X2,LWB,PacBrake,AirLift, Bright White
Brenled
Southeastern, MA
Still deciding on a new 5'er too. Can you share your checklist once again? Thanks
Brenled@aol.com
jjt14
Washington, Michigan 48094
LLeopold
I am yet another who is picking up a new 5er in about two weeks and could use a copy of your checklist. Thanks. (jjt14@comcast.net)
Almost Retired
Somewhere in the USA
Excellent list!!!
A couple of things I would add. Check the Fantastic fan rain sensor by spraying watter on the rig to make sure it closes when it rains.
Listen for the operation of the watter pump to make sure it doesn't turn on when your not running watter. I had a problem with a check valve in the pump in that it would let the watter run into the holding tank when the unit was hooked to a water source. The pump would run about every 2 minutes trying to re-establish pressure in the system. If you spend the first night in the rig without using shore water then you should find the problem. I also noticed it because my fresh watter tanks would fill up and then drip from the fill location even though they were empty when I parked.... filling up from the shore watter line through the watter pump.
Thanks again for the list. I'm currently looking for a good used 5er and this will help to make sure I know what I'm getting/paying for.
1998 Travel Supreme 40' DBSS 5th wheel... beached, sold truck getting a semi to pull the monster, F-350 was to small. Retiring 1 Sep 06.
Boater
Wichita, Kansas
Can I get a list too? I just bougt a 282 keystone two pullouts 5er. e-mail fhayden@kscable.com
F-350 extended cab Dually. V-10 4.3
282 Keystone 5er
AL & Judy
Virginia
Saw your post on the 5er check list. Sounds great. We are picking up our new 2955RL Montana next week and would like to use your check list. Would you please forward a copy to me? (conlecru@aol.com)
Thanks
2005 Winnebago Voyage 35A
L44SPD
Springfield, IL.
LLeopold;
Can I also have a copy of your check list sent to
my e-address Pselvagg@ameritech.net. This is the most detailed list I've seen and I want to thank you
for you generous response.
Thank you
2002 Ford F350
2002 Excel 33RSE
Retired and Loving It
Oldbuc
Coatesville, PA USA
Lou,
Picking up my 2002 Titanium, 29e34rl in 2-3 weeks. Thanks for the check list. Can't wait to hook up & hit the road!
*This Message was edited on 23-Mar-02 04:29 PM by Oldbuc*
Ron C.
Coatesville, PA
2002 Titanium 29E34RL Fiver
2002 Silverado 2500HD, 4x4, Duramax/Allison, CC
