RV.Net Open Roads Forum: Truck Camper University - Everything You Ever Wanted to Know About TC's
 > Truck Camper University - Everything You Ever Wanted to Know About TC's
BradW
Flat Rock, Alabama
Posted: 07/30/05 09:41am Link  |  Print  |  Notify Moderator
OK, per Joe’s (growler67) suggestion, we started a thread back in July of 2005 for Truck Camper Project Ideas. It has grown to include lots of helpfull information.
I stay pretty busy, so if anyone has a thread they want to add to the list, just send the address to the thread to me (BradW) in a PM and I will add it.
Just remember, every thread can't be added, so a nominated thread may not make it. But the goal here is to capture links to the really helpfull info before they fade away into cyberspace.
Thanks to all who have contributed!
Also, don't forget the Frequently Asked Truck Camper Questions Thread - See Section 24
Camper Interior:
Homemade Sky Light (Spott)
Frig Reair and Fan Upgrade(bbnate804)
Water Heater Drain Mod and Bathroom Soap Holder (Spott)
Bigfoot Pantry Mod For Canned Food Storage (tightline_101)
Dinette Replacement with Sofa (gsutton)
AF990 Seat Mod for More Interior Storage (FF1063)
LCD TV Installation (Spott)
Carpet and New Drawer for Northern Lite (Spott)
Shower Curtain/Door Mod (Spott)
Shower Screen (jjinatx)
Maglite Storage (DakotaCamper)
Table Pedestal (Rays Popup Projects - rlchenry)
TV / DVD System (Rays Popup Projects - rlchenry)
Couch Installation in AF1140DB (jimandsue60)
Camper Exterior:
Entrance Window Repair (c.traveler2)
Compartment door vent cover project (Spott)
Insulating Exterior Camper Compartment Doors (Spott)
Ladder Repair (Spott)
Lance Camper Wing Dry Rot (Eric)
Low Pressure Camper Leak Test (joec)
Lance Sealant / Caulk (Wasatch Lance)
Lance Caulk (wsdepa)
Clear Window Glass Retrofit (Spott)
Outside Shower Mod (Spott)
Compartment Drain (ogrer)
Side Awning Project (Stretch67)
Roof Rack and Kayak Roller (Rays Popup Projects - rlchenry)
Camper Back Up Camera Install (BlueBehemoth)
Repairing Filon (silversand)
Camper Entrance Ramp (Ibeme)
Camper Sealants (sleepy)
Camper Structural Wall Repair (2nakiller)
Replacement Rubber Camper Bumpers (luv2skyski)
Rotted Camper Wing Repair
Recalking Your Camper and Removing Old Calk (traxtermax)
Storage Compartment Mod (Spott)
Camper Steps, Porches and Bumpers:
Bumper Steps (AKSledhead)
Combination Porch, Steps and Generator (Steve Curet)
Back Porches & Steps (1)
Back Porches & Steps (2)
Back Porches & Steps (3)
Another Rear Deck w/Steps (4) (Popkorn)
Hitch-Haul / Extension and Custom Steps (Stretch67)
Northernlite Bumper Mod (Spott)
Free Standing TC Porch
Camper Electrical:
Dual Battery Mod (SoCalDesertRider)
LED Lights (sleepy)
RV Battery Solenoid Installation (BCSierra)
Back-Up Camera Install (BlueBehemoth)
A/C Units and Generator Combinations That Work
Honda EU2000i Generator and Polar Cub (msiminoff)
Honda EU2000i Generator and A/C (xp8103)
Another Meter Panel Project (Spott)
Homebuilt Sliding Dual Battery Tray (INSAYN)
Magnetek 12V Converter Replacement with PD9140 and Charge Wizard
Magnetek Coverter/Charger Replacement (1)
Magnetek Coverter/Charger Replacement (2)
Lance Camper/Truck Bed Plug Wiring (1)
Bed Plug Wiring (2)
Electrical System (Rays Popup Projects - rlchenry)
Camper Bateries
CB Antenna Mounted on Camper (infamousterry2)
Another CB Antenna Thread (Spott)
Camper Air Conditioning:
How to Remove a Camper A/C Unit (Spott)
Camper A/C (1)
Camper A/C (2) (Windwalker55)
Camper A/C (3) (Windwalker55)
Mini Air Conditioner (Rays Popup Projects - rlchenry)
Polar Cub and EU2000i Honda Generator (msiminoff)
A/C and Honda EU2000i Generator (xp8103)
Camper Loading / Jacks / Hauling / Tiedowns:
Truck Capacity - Truck Camper Weight Certificates
Home Made Tie Downs (SoCalDesertRider)
OEM Camper Jacks
Camper Loading Alignment Guide Rods (D.U.H) (FarcticOx)
Camper Loading String Alignment Guide (Heavy_Hauler)
Tork Lift Tie Down Install on 2007 Dodge (CumminsDriver)
Ford Truck Camper Payload Information (GFritsch)
Camper Centering Guides (1) (Spott)
Camper Centering Guides (2) (ogrer)
Camper Centering Guides (3) (radarcody)
Camper Centering Guides (4) (Crumm)
Real World Truck/Camper Weights (Left_Coast*9)
Home Built Tie Downs (Spott)
Happijac Tie-Down Install on 2006 F-350
SuperDuty Cab Lights Clearance (Steve Curet)
Happijac Drill Adapter
Adjusting Happijac Tiedowns (Hoko)
Tips on Loading a Truck Camper
Loading on a Slope (1)
Camper Jack Spacers - SRW
Towing / Extended Hitches:
Towing a Vehicle Behind a Truck Camper (jgorm)
F-350 Front Hitch Install (Spott)
Reese 2-1/2" Tow Beast Hitch Install - 2006 Ford Dually
Torklift Super Hitch Install - 2006 Dodge Dually (kwinterb)
Bodiak Front Hitch Installion (kwinterb)
Hitch Extension >> Added Rear Axle Load
Hitch Extensions (2)
Towing Another Vehicle
Hitch Extension Photos
Front Bumper Hitch - F350 (Mighty Thor)
Super Hitch Extension Mod (Spott)
Truck Suspension:
Fixing Leaking Firestone Airbag Fittings (jgorm)
Ford Factory Overload Spring Bumper Extension (Crumm)
Timbren Install on 1/2 Ton Chevy (1) (B-n-B)
Timbrens Overload Springs/Bumpers (2)
Timbren Install on a 2006 F-350 DRW 4X4 (3)
Airbag Issues (Kober)
Truck/Truck Camper Suspension Terms (dalej)
Approximating Truck/TC Vertical CG (dhackney)
Rancho 9000 Shock Settings 91) (leighc)
Rancho 9000 Shocks (2) (Surferkim)
Rancho 9000 Install on a 2006 F-350 DRW 4X4 (3)
Rancho 9000 Adjuster Knob Problems (littlebigbar)
Rancho 9000 Adjuster Knob Photos
Calculating Added Weight on Rear Axle from Hitch Extension
Super Springs Brand Overload Springs
Dodge Overload Springs
Broken Air Bag Frame Bracket Bolts (EdFil)
Air Bag Valve Location (1) (Chewyj)
Air Bag Valve Location (2)
Airbag Pressure (tri5ron)
Airlift Airbag Failure (brain)
Tires & Wheels:
F-350 - 33" E-Rated Tire Upgrade (SoCalDesertRider)
Tire Pressure (HaulinFun)
Toyo Tires (ScottCO)
285/75R16E & 70R17E Tires - 3,750 lb (SlideInDad)
Airing Up Dually Tires (1)
Airing Up Dually Tires (2)
Goodyear Tire Inflation Chart
19.5" Wheels - Pros & Cons (1)
19.5" Wheels & Tires (2)
19.5" Wheels & Tires (3) (luv2skyski)
19.5" Wheels & Tires (4) (tahoe2006)
Truck - SRW or DRW:
SRW or DRW? (1) (woodhog)
SRW or DRW? (2) (DmaxCamper)
SRW or DRW? (3)
SRW or DRW? (4) (ktmrdr85)
Truck - Other:
Truck Mud Flaps (Spott)
GPS Bracket (Spott)
Real World Truck & Camper Weights (Left_coast*9)
Ford Heated Seat Switch Location (Spott)
Lifted Trucks and TC's
The Cost of Outfitting a TC Hauling Truck
Real World Ford V10 w/TC Mileage (jgaylor)
Dodge Headlight Adjustment
F-250 vs F-350 SRW Trucks
Ordering a New Truck
$etting Up a New Camper Hauling Truck
Sprayed In Bed Liners
Truck Back Seat Storage Mod
TC Hauling Trucks - 2WD or 4WD
Truck Camper Reviews:
Lance 861 Review (SlideInDad)
Lance 8CSC - 2007 (#20 Home Depot)
Lance 1181 - 2007 (Heavy_Hauler)
Member's Project Pages:
JoeChiOhki's Truck Camper Projects
Camper Project Page (Netboy)
Camper Mods (mjgcamper)
Rexford's Projects (rexford)
General:
Truck Campers on Goose Neck Trailers - General
Truck Campers on Goose Neck Trailers - Tie Downs
Motorcycle Carrier (SoCalDesertRider)
Pet Ramps for Your TC (misskate)
Towing Your Broke Truck and Camper (BradW)
Rinsing the Black Tank (Spott)
Winter Mods (hoondoog)
RV Service Reviews (dalej)
Hard Side TC vs SoftSide TC - Pros and Cons
Truck Campers on Half-Ton Trucks (gbutala)
Truck Camper on a Flat Bed Truck (Downrivers)
Leasons Learned for Newbie Truck Camper Owners (orourkmw)
Supporting Your Camper While Off the Truck
Inexpensive Roof Rack (c.traveler2)
Camper Dolly (1) (Eric&Lisa)
Camper Dolly (2) (Spott)
Accepting the Advice of a TC Salesman? (northernbnd)
Matthew B Projects - (Matthew B)
Misc NL 10-2000 Projects W/Photos (Spott)
NL - Battery box leak repair, door upgrade & sliding trays (Spott)
Rear Hitch Rack / Camp Table (INSAYN)
Shell Camper Top One-Man Lift (Steve Curet)
20 lb Horizontal Propane Tanks
12V Air Compressors
Dog Ramp / Steps (armpics)
Camper Struts (saileyboy)
Camper & Vehicle Acronyms (Spott)
Off-Truck Camper Storage Trailer (Prominion)
Wind Deflector Project
7 Gallow Water Jug With 12 Volt Pump
Low Overhead Clearance Obstructions to Look Out For
Aluminum or Wood Camper Frames
Truck Camper Insurance
Printable RV.net Window Sign (woodworker414)
Truck Camper Forum Old Timers (Dually)
Truck Leveling Ramps
Truck Cabp Storage Mods W/Dog Ramp
* This post was last edited 10/08/08 07:46pm by BradW *   View edit history
Caution: Possibel defective spelling above; spell checker is DOA.
Our Truck Camper Photos
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Visit the RV.net Blogs
