RV.Net Open Roads Forum: Tech Issues: What is an "Aromat PMH Timer"?
 > What is an "Aromat PMH Timer"?
crrroger
Spring Creek, Nevada/Rainbow Acres, Arizona
Posted: 08/18/05 05:48pm Link  |  Print  |  Notify Moderator
Has anybody heard of this timer?
I have one attached to the converter in my old Lazy Daze Class C motor home.
It appears to have been professionally installed in a cutout next to the 115v circuit breakers. It is about 2" square and has a round adjustable dial that is graduated in tenths of a second.
I can't figure out what it is timing.
Anybody have an idea?
Thanks,
Roger
2005 Triple E Regency Class C with a 1990 Daihatsu Rocky toad.
daBear
Brandon, MS, USA
Posted: 08/18/05 05:54pm Link  |  Print  |  Notify Moderator
I may be mistaken but I think its a blow back indicator for a flux capacitor. The duration must be timed exactly.
Leave bread crumbs along the way only if you want to come back down the same road.
tripledir
Payson AZ
Posted: 08/18/05 06:08pm Link  |  Print  |  Notify Moderator
Some sort of power on - delay
1988 33' Four Seasons Tourcrusar
Ford 460 / GEAR VENDORS / John Deere Chassis / 4 Wheel Disc Brakes / Air Suspension
Onan 6.5 / HONDA EU2000i / Freedom 458-20 Invrtr / 6-6V Batteries / 3-120w Kyocera Solar Panels w/4 way tilts
HONDA XR650L / Tilt A Rack
Jacksons
columbus,ohio
Posted: 08/18/05 07:38pm Link  |  Print  |  Notify Moderator
I love your reply,remember, If you can't dazzle them with brilliance,baffle them with BS
NGRRFan
Colo. Spgs., CO
Posted: 08/18/05 07:41pm Link  |  Print  |  Notify Moderator
Here's the website for that
Aromat timer
What it's used for in your case... I don't know.
Rich,and Tobi (the rescued dog)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
Argosy24
MI
Posted: 08/18/05 07:48pm Link  |  Print  |  Notify Moderator
Converter boiling the batteries, PO used it to limit the charge time? Check 120v to the converter with it on and off.
dmartin@newarts.com
Ames, IA
Posted: 08/19/05 03:04am Link  |  Print  |  Notify Moderator
Delay relays are often used with generator switching circuits so the generator can get up to speed before the switch to the electrical load is closed and to provide a little off time to avoid voltage spikes.
In general it is wise to "break before make" & have a little "off time" so that when switching from one AC source to another the circuit being switched doesn't see a sudden change in voltage due to a difference in phase between the two sources.
My 1980 Born Free had such a relay. Perhaps that's what you have too.
Dave
1980 Born Free 22' Class C (minus) - 1985 Honda Scooter
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
