RV.Net Open Roads Forum: Class C Motorhomes: Get Your Front End Aligned First
RV.net
 > Get Your Front End Aligned First
n5tc
Salado, Texas
Posted: 01/11/06 06:47am Link  |  Print  |  Notify Moderator
I realize that this subject has been beat to death, but maybe someone did not get the message.
I just took delivery at the factory on a brand new Class C on the E450 chassis. Having done this before, I scheduled a couple of days in the area checking out the coach before heading home. The front end was badly out of line and pulling strongly to the left. I took it to a knowledgeable front end shop and they found that it came from the factory way out of line. Also, the buhsings had to be replaced because the ones that Ford provides are not adjustable. The company that I bought the coach from footed the bill.
My recommendation. If you buy a coach, new or used, have the front end checked before you drive it very far.
robert46123
Indianapolis, IN
Posted: 01/11/06 06:54am Link  |  Print  |  Notify Moderator
When we bought our Damon Workhorse actually sent us a free alignment certificate for that very reason.
Family: JoAnn, Robert, Shelby and Robbie - Indiana - Texas Bound!
Camper: 2004 Damon Daybreak 3285 WorkHorse 8.1
Toad: 2008 Honda Fit MT - BlueOx Baseplate/Aventa II/Apollo
Toys: 2000 Jeep Cherokee/2006 Ninja 250R/2006 Mustang GT
Rivercabins
Northwest Colorado
Posted: 01/11/06 07:36am Link  |  Print  |  Notify Moderator
Hi, I also had the allignment done on our E450 with only 2300 miles on it & also had to replace the Ford bushings because they could not be adjusted enough to allign the front end, Earl at the Rivercabins.
Earl at the Rivercabins, 2002 Bigfoot 29 slide
BillyP
Cedar Point, NC
Posted: 01/11/06 09:28am Link  |  Print  |  Notify Moderator
I would tend to believe that the Coach Mfg bought the chassis and built the unit and never thought about aligning after the unit was completed. The alignment can also be correct when the empty coach leaves the mgfr but the alignment can be way off after the coach is loaded.
05 Jayco Seneca 35GS/22k Kodiak/6.6 Duramax
04 Jeep Rubicon Automatic
SMI Silent Partner/BlueOx Aladdin
Billy & Sharon's RV Adventures
Deb and Ed M
SW MI, USA
Posted: 01/11/06 03:13pm Link  |  Print  |  Notify Moderator
Our dealer really stressed loading up the then-new MH, filling the tanks, then getting it aligned.
When driving, it didn't "pull" - but felt "floaty" while going down our county roads - enough so that 45 mph was about as fast as I dared to drive :-)
After the loading/alignment, it tracks rock-solid. Feels like a very large SUV....LOL!
Deb
Ed, Deb, and 2 dogs
2004 Gulfstream Conquest LE 28'
2006 Jeep Wrangler toad (Deb's) / S-10 Dragracing Truck! (Ed's)
noe-place
somerset, ky
Posted: 01/11/06 10:48pm Link  |  Print  |  Notify Moderator
I must be the luckiest owner in the world of an E450 as I have not had any steering, alignment or shock problems. Maybe I got that one-in-a-million unit that has everything in place. I hope so and continue to travel with all original equipment still in place except for replacing tire valves with the steel extensions.
jerry noe
skimox
Lake Keystone,Ok
Posted: 01/13/06 04:21pm Link  |  Print  |  Notify Moderator
no jerry you got 2 in a million-
9500 miles and no problems and tires are nice and even.
2004 2450s Sunseeker E450 V10 w/slide and PT Cruiser Toad
Tow dolly and HWH hydraulic jacks
Retired?? but still have 4 bosses-wife & 3 Dachshunds
Greyeagle44F
Stratham NH USA
Posted: 01/14/06 08:45am Link  |  Print  |  Notify Moderator
Ours, purchased new, was right on the mark from the start...as indicated by now 15,000 miles with great handling and even tire wear.
It does happen.
The U.S. Military: "All gave some, some gave all."
The Ancient Aviator
2002 26Q Tioga, Michelin Sneakers, Front XPS, Rear LTX M/S, no chassis "gimmicks" (Wind Machine sold APR 2006...pushing my luck at 84 years and a high performance bird).
murffdog
Poughkeepsie, NY
Posted: 01/14/06 09:07am Link  |  Print  |  Notify Moderator
At 5000 miles I noticed my front tires wearing badly. $185.00 and rotating the tires using the new spare also, things are fine now at 18,000 miles.
Westronics
Redmond, WA
Posted: 01/14/06 09:23am Link  |  Print  |  Notify Moderator
Front end alignments are a well-known issue with Ford E-450s (and 350s, too, I suppose, but am not 100% sure).
One should load up the rig and then see if it tracks true on a level surface - the middle lane of a divided highway with three-lanes on your side is best as you can ride right on the crown of the road.
If it pulls to either side when you let go of the steering wheel, it needs an alignment.
This has to do with Ford's design of the front end.
It is my understanding that Ford's warranty includes one initial front-end alignment. I do not know that for sure, but I do know that I did not pay for mine - whether it was actually Ford, Jayco, or Blade Chevrolet (my Jayco dealer) that picked up the tab for this I cannot say for sure as I never inquired.
2002 Jayco Greyhawk 24SS, Cameras (RVCams), ScanGauge II/Blendmount, 300W Inverter, Airtabs,12' Portabote w/sail, SeeLevel II, Tireman valves, Be kind to septic systems.
Ford motorhome customer service: 1-800-444-3311.
