RV.Net Open Roads Forum: Class C Motorhomes: LP on or off?
 > LP on or off?
AnnH
Kansas City, MO
Good Sam RV Club
Posted: 01/31/06 09:26pm Link  |  Print  |  Notify Moderator
When I picked up my Navion on Saturday, the guy doing the walk through said I never have to turn the LP off unless I'm going to store the RV. The only other time it needs to be turned off is when it is filled or services. But, I've read on the internet that you should never drives with the LP on. But,...the refridgerator runs on LP while your driving, right? I'm confused.
Also, he said that new refridgerators don't need to be level all the time, just most of the time. Is this right?
Can anyone help?
rgraham
Missouri
Posted: 01/31/06 09:43pm Link  |  Print  |  Notify Moderator
You can get a lot of different opinions on here about having the gas on and your refrigerator running while going up and down the highway,
my refrigerator is on when I am traveling after all that is what it is designed to do, a good ideal to shut the gas off while refueling as a spark could cause a fire at a gas station, and most Tunnels want
it off, Richard
Richard
1987 ford f250 6.9 diesel
1997 Innsbruck by Gulf Stream 28ft fifth wheel with slide
and the wife and co-pilot Trudy
driveby
Vancouver BC Canada
Posted: 01/31/06 10:05pm Link  |  Print  |  Notify Moderator
A search on propane or running a fridge while driving will give you many hours of opinions. Some heated some not as much.
As for the fridge, the fridge manufacturer has ultimate say but generally I understand the limits to be 3 Degrees left or right and 6 Degress fore and aft.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
Bethers
Alabama
Good Sam RV Club
Posted: 01/31/06 10:11pm Link  |  Print  |  Notify Moderator
Depends on the make of the fridge - I'm told mine doesn't have to be level all the time - and I think they're right - as I've never had a problem - although I do try to be level.
Loving the rv lifestyle!
Beth
CloudDriver
New Jersey Shore
Good Sam RV Club
Posted: 01/31/06 10:12pm Link  |  Print  |  Notify Moderator
Driving with the propane on increases the risk of a fire in an accident since a broken propane line would release a lot of flammable gas. A lot of people see this as a small risk and drive with the propane on to keep the fridge going. Most tunnels require that the propane be shut off before entering due to past problems with major fires in these confined spaces. Some tunnels don't allow RVs with propane to go thru at all. Gas stations are a high risk due to possibility of the small flame in the refrigerator igniting gasolne fumes, especially if there is a spill.
It is true that refrigerators don't have to be perfectly level. The Dometic fridge in our MH has limits of 3 degrees side to side and 6 degrees front to back (of the fridge, not the MH). For our MH this allows us to be about 7 inches out of level both front to back and side to side of the MH, which is a lot of slope. I usually try not to be out of level by more then 2-3 inches in either direction, both for the fridge and personal comfort.
2003 Winnebago Minnie 24F - Ford E-450
hwybnb
Posted: 01/31/06 10:37pm Link  |  Print  |  Notify Moderator
The biggest danger is the potential of a line being ruptured in an accident, and ignition of the escaping gas. Your tank should have a safety valve that shuts off the supply if a high flow rate occurs, thus preventing venting of the gas.
Previous discussions on this topic have shown that most people leave the propane on when driving.
2oldman
Las Vegas
Posted: 01/31/06 11:10pm Link  |  Print  |  Notify Moderator
Here's a few discussions on the subject.
Bubby's RV
CA
Good Sam RV Club
Posted: 02/01/06 09:03am Link  |  Print  |  Notify Moderator
We leave our propane on while driving to keep the refrigerator cold. I shut the power off to the refrigerator, heater and water heater when refueling. That's a must!
The arguments are:
  • Leaving it on increases the fire hazard.
  • The tanks have an excess-flow check valve to shut off the flow in case of rupture.
  • Propane is no worse than gasoline, and there are propane powered vehicles on the roads.
  • A frige will stay cold all day with the door closed.
  • It won't if you keep opening the door.
  • What if you forget to shut it off when you refuel.
  • You better find a way to remember.
I'm sure there are more arguments, and some are quite heated (no pun intended ), but it's a matter of choice.
John, Winnebago Minnie 24V
Love Boat II
Some where in the USA
Posted: 02/01/06 09:13am Link  |  Print  |  Notify Moderator
The arguments are:
Does not your refrigerator run on 12v also ?
bfast54
Traverse City ,Mi.
Posted: 02/01/06 09:30am Link  |  Print  |  Notify Moderator
Love Boat II wrote:
The arguments are:
NO, mine is 110/ L.P. Gas ONLY.
It is safe to run , with your Ref. on, propane.
Being a Firefighter, 23+ years, I have NEVER responded, nor has any of the other Firefighters I know, EVER responded to a Vehicle/camper fire/explosion, on the road caused by L.P. Gas!!!!!!!
You are more likley to have a fire explosion from your GASOLINE in the tank, leaking , or fumes from your gastank exploding, from a spark, than to EVER have it from Propane !
There are Thousands of Vehicles on the road Running on Propane, and you dont hear about them just "exploding for "no reason"-- Urban Myth!!!!
If you choose , to not run with propane on, fine!!! But, all the Fridges ARE built to run , while traveling--plus if the fridges are not built to run on propane-- ALL fridges WOULD have 12 VOLT!!!
1994 Dodge Cummins Turbo Diesel,3500,Dually (Oh YEA )
2000 Cardinal 27RK LX
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR Thermometer,Garmin C-330 Nav./GPS
Doran Pressure Pro
VU Qube Satelite
Rally's attended so far- 8
My Blog
 > LP on or off?
