RV.Net Open Roads Forum: Annual Brake Inspection and Axle Re - Lube (Pic's)
Search only in Towing
Open Roads Forum  >  Towing
 > Annual Brake Inspection and Axle Re - Lube (Pic's)
Page of 5
Fred Engle
MD
Posted: 05/16/06 01:09pm Link  |  Print  |  Notify Moderator
I thought i read a slide hammer could be used to remove locks can you please tell me how to do this. thank you.
autoxracer
Cincinnati,Oh-USA
Posted: 05/16/06 02:01pm Link  |  Print  |  Notify Moderator
Won't do anything for the brakes but switching to DEXTER "NEVER LUBE" bearing sets will eliminate a lot of the dirty work in what you are doing-just a thought.
dbLD250
Fred Engle
MD
Posted: 05/16/06 05:33pm Link  |  Print  |  Notify Moderator
I meant in how do i use a slide hammer to remove an ignition?
JBarca
Dublin, Ohio, USA
Posted: 05/16/06 07:31pm Link  |  Print  |  Notify Moderator
Fred Engle wrote:
I meant in how do I use a slide hammer to remove an ignition?
Fred
The slide hammer puller shown in the post
can be used for pulling gears, hubs, seals, bushings or a variety of other hub type components.
The actual slide hammer part is the large piece of steel with the circular groves on the long rod. This "hunk" of metal makes a hammer and slides along the rod until it hits the end of the T shaped handle. The bottoming out at the end produces an impact force into the long rod and creates a pulling effect to break loose and remove hubs.
The are many attachments that screw onto the end of a slide hammer arrangement.
Your terms, locks and ignition, need a little more description on what you are up to. Are you trying to pull a key cylinder lock out of a steering column?
Hope this helps.
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we where camping!)
IHnutz
Indiana: the home of Purdue University
Posted: 05/27/06 10:32am Link  |  Print  |  Notify Moderator
Excellent article on brake and wheel bearings! Good job explaining the process so even "your Grandma" can do it.
My only caution is when drying the bearings after washing them. NEVER under any circumstances "spin" the bearing with high pressure! The cage used to hold the bearing rollers is only ment to hold the rollers in alignment when installed in the outer race. The rollers can fly out of the cage by centrifugal force when spun at high speeds. If that happens one can ruin a bearing or worse lose an eye or teeth! If you must use air pressure, use "canned air" like is used to clean computer keyboards (Radio Shack), turn down the air pressure to less than 20psi AND hold the bearing cage so it doesn't spin.
IHnutz
2005 Nomad 2520
1999 Dodge 2500 QuadCab SB CTD
1954 IH R-112
1954 IH Farmall Super M
WD9GLK
magnum300
MI
Posted: 06/02/06 08:23pm Link  |  Print  |  Notify Moderator
good information thanks, but make sure you never spin a dry baering with air
* This post was edited 06/03/06 08:08am by magnum300 *
Page of 5
