Bobbo
Memphis, TN
But they absolutely refuse to make this a sticky. It is such a wonderful source of ideas for new people.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
JimBollman
Upstate NY
Instead of a bump try posting a hint, most of us probably have lots of things we have done to our campers, they all don't have to be big.
I have a weak front seal on my popup truck camper roof where it comes down. Not sure if my repair today will work but I opened up one end of the hollow seal and slid a soft piece of clear plastic tubing in. Now it has some compression to it. I guess I'll find out next time I drive in a heavy rain. Not sure spraying it with a hose is the same effect.
Same idea should work on other camper seals like around doors, if it is a hollow type seal. Cheap fix if it works, took $2.58 of tubing and about 10 minutes to install.
Jim...
Mule Skinner
Pinconning, Michigan, USA
A friend told me about this it seems to work. A ziplock bag of cold water on the table helps keep the flies away.
Gerry Lori and The Pace Arrow 37 With Banks Power Pack and Trans Command
MSgt USAF Ret. 1985
1988 Goldwing with 2005 Champion Trike Conversion
crazyoldcoot
South of Arkansas
My wife read this somewhere and hung one on the back porch. It seemed to work.Also keeps elephants away.Haven't seen an elephant around since she hung it up there either.
lampooner
South Carolina
You see the bags of water hanging in some restaurants here in SC. I call them "Redneck Fire Extinguishers". When a fire starts, they melt and release the water.
Lampooner
Remember you are only young once,
but you can be immature forever!
crazyoldcoot
South of Arkansas
lampooner wrote: You see the bags of water hanging in some restaurants here in SC. I call them "Redneck Fire Extinguishers". When a fire starts, they melt and release the water.
I like that! I also like your signature line. Sounds like someone I know!
rocknrollpro
Scottsdale AZ
JimBollman wrote: Instead of a bump try posting a hint, most of us probably have lots of things we have done to our campers, they all don't have to be big.
Jim...
Thank you for your suggestion, but I've posted many hints. I've also noticed if you don't post regularly, that you stop getting notified of additions. If they want to "bump" me for "bumping" so be it....
Rocky
"Everydayz a Holiday"
2001 Ford F250 2WD Lariat Super Cab 7.3
2003 Outback 28' fiver 527RLS
1972 Ford F350 22' Beaver C Class!
Jim102
Cabot, Arkansas
We saw an interesting one this past weekend.....The guy next door took a 5 gal. whit plastic bucket (used for paint) cut the bottom out punched a hole in the top and installed one of those work lights( the bulb with the cage around it ~200w) and hung it away from his camper. It lit the whole site and the open bottom attracted all the bugs into it, I may have to try it out...
Jim
2007 29' Maverick 292 DS
A 12 yr. old long haired Doxie, "Digger"..
crazyoldcoot
South of Arkansas
It may also light up your neighbors site who may not appreciate it. I have camped next to one of these lights but the owner turned it off before quiet time so it didn't bother me. I was afraid he was going to leave it on late but he didn't.
ReVoker
Corlista, RJ
The plastic bags of water seem to work very well. I saw those down in New Orleans a few years ago at some of the local restaurants and did not many flies around.
ReVoker
An opinion on every subject...
