RV.Net Open Roads Forum: General RVing Issues: Handy Hints, Gadgets, Products & Gizmos
 > Handy Hints, Gadgets, Products & Gizmos
Page of 134
General RVing Issues Related Tips
BirdSongPlace
San Diego County, CA
Posted: 09/13/09 01:04am Link  |  Quote  |  Print  |  Notify Moderator
NAUTIQUE wrote:
map40 wrote:
So, here is my contribution: An RV Bidet.
Works great. Now, let the flaming start!!!!!
Uh...... Way T.M.I.!!!
Back in the day my dentist had something that looked like this!
2000 Ford F350
2004 Adventurer
map40
MI
Posted: 09/13/09 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
OK, let's see if you like this one.
As my RV gets older, I keep trying to avoid problems. As I have a window in the cabover bed, I decided to directly avoid water from going over any of those openings, by putting an RV Gutter over everything in the front of the cab over. Here are the pictures:
As you see, I put an RV gutter arround the window, and a small one over every marker light. This should avoid any water to drain directly into the opening, avoiding one of the biggest sources of water damage.
2007 Four Winds 31F
Life rocks when your home rolls
mike54
Woodstock,IL
Good Sam RV Club
Posted: 09/13/09 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
what no demonstration on how to use it.
Mike &
Dunkin (cocker retriever mix)
WCA East Troy Campers
2008 ZT25RK CrossRoads Zinger
2002 Silverado crew cab 2500HD 6.0 4:10 gears
rj7388
ri
Posted: 09/13/09 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
my water/moisture input seems to be coming from "underneath" the cabover...will those rain gutters work upside down?
ham radio,bluegrass mandolin wannabe
woodworking,photography & fishing
'08 4Winds chateau 28A
map40
MI
Posted: 09/14/09 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Sure, but only for the rain that goes downside up.
dogcomestoo
Massachusetts
Posted: 09/25/09 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
After reading all these great tips I thought hard about one to contribute. If you are bringing CDs and DVDs you do not need the hard plastic cases they come in, which take up a lot of room. You can get a binder with pages of pockets and fit a whole lot of discs. Sort of like the ideas with documents or recipe cards, but with CDs and DVDs. Wonder what else could be stored in a binder like this?
PGR_Skye
Indiana
Posted: 09/26/09 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
I store my very favorite recipes that I might want to use on a trip in one of the smaller photo albums so they take up less room in the fiver.
Dutch_12078
Great Sacandaga Lake, NY
Posted: 09/26/09 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
It's not uncommon for marker light and cabover window leaks to run down between the inner and outer walls, not showing up until it reaches the bottom.
Dutch
'95 Coachmen Catalina 322XL
F-53 chassis, 460 V8
Jeanne M
Good Sam RV Club
Posted: 09/27/09 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Me too! I use those plastic photo wallets with pages that have double sided sleeves and are approximately 4X6". I've found them in the photo section at WalMart and also at Joanns Crafts for about a $1.00 each. I can get 36 recipes in one of those. I have one for Crockpot recipes, one for main dishes, one for desserts and I even have one specifically for recent photos!
As stated above...you can carry a bunch of these in less space than a regular cookbook and much less weight too!
Jeanne & Kenny
2005 Itasca Horizon 36GD, Freightliner Evolution Chassis, Cat 350
1992 Honda Accord
And Bailey, our furry traveling companion
Good Sam, TT/Naco,PA,RPI,AOR,C2C,FMCA #F151328
Our Pictures
Denise in Ark
Tulsa, OK
Posted: 10/02/09 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Save weight on canisters - use the nesting style tin ones. All of the ones I have right now are antique, but I just ordered some new ones and will be spray painting and decoupaging to match the interior.
Page of 134
