TheElmores
N.C.
Mr. Ed;
Our 8.3 Cummins uses no oil between 3000 mile changes with Shell Rotella at 87000 miles.
Theelmores
94 Monaco Executive
PS: leaked some a time or two but got those
stopped.
MNoel
Meridian, Idaho
My V-10 has not used any oil between changes every 3000 miles. I use whatever is on sale, mostly quaker state or valvoline.
MNoel
03 Southwind 37U W22
98 Durango or 20' Mariah on Behind
dolce far niente
JoeG
Henniker, NH
My first class A was a Chev 454. Sold it at about 60K miles. Used less than 1/2Q between changes at typically 3,000 miles.
My present class A is a Ford, 460, with about 40K miles. This uses no oil that I can detect between changes.
I use Amzoil (spelling looks wrong) 15-40 in the summer, 10-30 in the spring and late fall.
Joe
rvten
Crossville,TN
I have noticed that depending how one drives will also effect oil useage. Flat land driving is easyer on the engine. Pulling a toad or heavy trailer and big hills will make the engine work harder, run hotter and tends to make the engine use some oil. Most engines will use about a quart between oil changes.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
lluttrell
Longmont, CO
We have had the Ford V-10 in two rigs, and I have yet to add oil between changes. I think it was down about half a quart when I changed at 4000 miles. Currently using Motocraft 5W-20, just like the book says to do.
Lyle & Marilyn
2008 Cambria 29H
mr. ed
Madison, SD (but usually elsewhere)
Thanks for the response, fellas. I thought I had a real good thing going, but it seems that many of you are getting decent mileage from your oil. Of course, low oil consumption is a sign of a good engine. I remember about 2 yrs ago, I was taking a trip to AZ from CA. Hadn't taken a long trip in quite a while. I was suprised to see quite a bit of oil consumption at the beginning of this relatively short trip. After a little while, though, the excessive consumption stopped. I can only surmize (sp) that since I hadn't really run it for a while, the rings had to reseat (?). Anyway, I'm pleased. Happy rving to all of you.
Mr. Ed
Ipanema
Punta Gorda, FL
Mr.ED:
On our Ford 460, we hardly need to addoil between oil changes. Maybe....MAYBE....a 1/2 Qt in 5,000 miles. Thank God because I've heard some horror stories!
Ed and Lilian
Penn State Class of 1956
Old Snipe
Full Timer
2001 Ford V-10, using the factory recommended 5W-20. Was concerned about oil consumption when engine was brand new, but now at 5800 miles, have not used a full quart in almost 3000 miles. Ran VA-FL-VA in January at 60-65 MPH, too.
Paul D
2001 Four Winds 31Z (aka "R SANITY")
Bill S.
Indian River, Delaware
Just returned yesterday from a Delaware-Key West-Delaware trip and used less than a quart. 2001 V-10 has only 6500 miles on now.
Bill, (aka Capt.Bill)
Indian River, De
2002 Horizon 36LD, Cat 330
Practicing retirement!
JR3
Okla
Mr. Ed
My oil usage depends upon my right foot ! My 89 454 (60-k) uses about 1qt every 1200 to 1500 miles if I drive 55 mph. At 70 mph during the summer 1qt every 600-800 miles is not uncommon.
I also use Vavoline Syntec 10w30 9 months out of the year. During the summer I change to 20w50 it seems to cut down on consumption.
